#241
Old 02-09-2018, 08:57 PM
Kurt L71S's Avatar
Kurt L71S Kurt L71S is offline
Originally Posted by 2002Z4CSS View Post
You will be done before you know it. Once it is you, will have a greater sence of appreciation for the Lemans. Since your doing the work. I am having the same feelings. Can't wait to drive my car again !!!!
Z4,
Thanks for your comments!
Got some more done today and yesterday on both front fenders. Passenger side was perfect, but the drivers side needed a little attention...
Instead of replacing just a small patch, I instead purchased a complete bottom of the fender-minus the brace. It was still good. Did the cutting and replaced the patch and welded things into place...
They are now ready for a coat of etch primer....Forward Progress...
ID:	475109   Click image for larger version
ID:	475110   Click image for larger version
ID:	475111   Click image for larger version
ID:	475112   Click image for larger version
Kurt L71S....1971 LeMans Sport Coupe 350/TH350
  #242
Old 02-13-2018, 07:23 AM
Kurt L71S's Avatar
Fun times yesterday with an 8" DA Sander. Top is done along with the trunk...
Will get photos of the trunk....
Hood and doors are next.....That hood has some real estate on it...
ID:	475387   Click image for larger version
ID:	475388   Click image for larger version
ID:	475389   Click image for larger version
  #243
Old 02-13-2018, 04:56 PM
2002Z4CSS's Avatar
Keep up the good work!!! It is a motivator for me to keep plugging away at my project as well especially over the winter.
1971 Pontiac GT-37
  #244
Old 02-17-2018, 11:11 AM
Kurt L71S's Avatar
I just thought I was done with the top and the trunk. Went over the top again and now it's ready for etch primer...
The trunklid, I discovered, has some rot above the bottom panel. It's not real bad, but bad enough I don't want it on my LeMans. I ordered a new replacement from Tamraz. This one will see eBay some time in the future along with all the "other" parts I no longer need....
Reinstalled the tank after painting the underside of the trunk floor. Put some gas in her and hit the starter.....Four turns of the key and.... Music to my ears!
ID:	475804   Click image for larger version
ID:	475805   Click image for larger version
ID:	475806   Click image for larger version
ID:	475807   Click image for larger version
  #245
Old 02-17-2018, 11:18 AM
Kurt L71S's Avatar
Default Getting Closer
Painted the underside of the trunk semi black...
Squirted some Etch Primer on the front fenders and front valance...
Clark said we should paint her all this green, put a star on the door.....NOT!!
ID:	475811   Click image for larger version
ID:	475812   Click image for larger version
ID:	475813   Click image for larger version
ID:	475814   Click image for larger version
  #246
Old 02-18-2018, 08:57 PM
2002Z4CSS's Avatar
Looking good !
1971 Pontiac GT-37
  #247
Old 02-28-2018, 07:50 AM
Kurt L71S's Avatar
New Trunk Lid in place...
Right Rear Quarter is now in place and welded. ..
After the RR done, I began on the Left Rear Quarter...
Gotta love this look!....Gauges and shifter peeking out...
ID:	476832   Click image for larger version
ID:	476833   Click image for larger version
ID:	476834   Click image for larger version
  #248
Old 02-28-2018, 12:21 PM
the70OOJudge's Avatar
the70OOJudge the70OOJudge is offline
Send a message via MSN to the70OOJudge
Now that is getting er done!!! Looking Good!!!!
  #249
Old 02-28-2018, 08:06 PM
2002Z4CSS's Avatar
Very nice !!!!
1971 Pontiac GT-37
  #250
Old 03-01-2018, 07:43 AM
Kurt L71S's Avatar
Very nice !!!!
Blu Bi Yu Thanks you both for your comments!...
We worked yesterday on finishing the trimming of the right rear wheel house and securing the left rear wheel house, and etch primed in being ready for the final install of the Left Rear Quarter today...
Then it will be time to move forward, removing both doors and stripping them to the metal.....
Sounds like a plan to me!...
ID:	476878   Click image for larger version
ID:	476879   Click image for larger version
ID:	476880   Click image for larger version
  #251
Old 03-03-2018, 07:48 AM
Kurt L71S's Avatar
Default Big Progress this Week
I made some huge progress this week on the '71 LeMans...
Now have both rear quarters installed and welded. We need to adjust the "corners" of each side...
We are test fitting the rear bumper again and with some adjustment, it will look GREAT!.
After it's final fitting, I will install the rear valance and weld the tabs on each quarter...
STILL STOKED!!...
ID:	477065   Click image for larger version
ID:	477066   Click image for larger version
ID:	477067   Click image for larger version
ID:	477068   Click image for larger version
  #252
Old 03-03-2018, 04:42 PM
2002Z4CSS's Avatar
Major progress going on here !
1971 Pontiac GT-37
  #253
Old 03-05-2018, 09:13 AM
Kurt L71S's Avatar
We are trying our best to get her finished...
Yesterday I spent the day sanding the hood of the old paint and primer. She looks pretty good for a 1971. I have looked several places for a replacement 1971 LeMans hood....Not to be found....Thank goodness mine is is good shape.
I have found that from the doors forward, new (repopped) parts simply don't exist for this LeMans....
I did however find a new bumper for the car in case I don't want to use my original....
Oh Well?....Who said restorations are easy! Not me!
ID:	477302   Click image for larger version
  #254
Old 03-05-2018, 05:32 PM
Kurt L71S's Avatar
Had time yesterday to get most of the paint and primer off the hood to find it is in good shape. Today I spent time in the booth finishing sanding/scotch bright all the corners and crevices. It is now ready for Etch Prime. Tomorrow I'll get started on the doors...
ID:	477324   Click image for larger version
ID:	477325   Click image for larger version
ID:	477326   Click image for larger version
  #255
Old 03-05-2018, 06:48 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Your getting close Kurt, and thanks for sharing
  #256
Old 03-08-2018, 09:33 AM
Kurt L71S's Avatar
Thanks Joe,
I AM getting closer. Started on the doors on Tuesday. Should finish cleaning them up today...
Thanks again for looking and your comments....
ID:	477563   Click image for larger version
  #257
Old 03-17-2018, 08:08 AM
Kurt L71S's Avatar
Yesterday I had the time to finish the underside of the hood, which BTW, turned out to be a SOLID hood!....
She also spent the day in the sun as we needed the space to work on other projects in the shop...
Gettin' Closer by the minute!..
ID:	478321   Click image for larger version
ID:	478322   Click image for larger version
ID:	478323   Click image for larger version
ID:	478324   Click image for larger version
  #258
Old 03-17-2018, 07:17 PM
Shiny Shiny is online now
Nice! Glad you got good news on the hood.
Stripping the underside looks like a pain. How did you do that?
  #259
Old 03-17-2018, 08:26 PM
Kurt L71S's Avatar
Time...lots of time...I used a 4" DA sander with 36 and 80 grit. Finished up with a 6" DA sander with 80 grit.
  #260
Old 03-18-2018, 12:47 PM
You are worthy!
