Old 06-29-2019, 03:40 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by LiL Jack View Post
U have a 2.10 first gear in the transmission?
What rear gear?
Yes, 2.10 first gear and 3.89 rear gear.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 06-29-2019, 07:12 PM
GTOGEORGE's Avatar
Yours is like mine a 2.10 first with a 3.73 gears!
GTO George
Old 06-29-2019, 10:50 PM
wreckmastr's Avatar
That's a lot of first gear. But I guess your trying to get wheel speed with slicks.
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
Old 06-30-2019, 07:09 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
But the power that engine cane make is huge.
Is the TB a 1-2 leaver where u could try leaving in second gear?
[email protected]. 3460#s
Old 06-30-2019, 08:30 AM
RAIV-Z's Avatar
I believe it is, I sent a note to Carl last week to confirm leaving in 2nd gear is ok.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 06-30-2019, 02:21 PM
GTOGEORGE's Avatar
Why would you want to leave in second? Your clearly not putting any power to it til the back half of the 1/8.....just wondering.
GTO George
Old 06-30-2019, 02:47 PM
RAIV-Z's Avatar
GTO George
To see what effect is has on building boost sooner with the current tune.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 07-01-2019, 09:14 AM
LiL Jack's Avatar
You need to hit it hard out the gate to get it moving.
Old 06-30-2019, 04:25 PM
John Langer's Avatar
John Langer John Langer is offline
GTO George
So you can put the power to it. It is an acceleration competition, not the salt flats. I would love to not have to pull power out on the hit and leave at a much higher rpm for the first second. I could go much quicker if I could.
Old 06-30-2019, 08:49 AM
RAIV-Z's Avatar
Yeah, it's a lot of first gear. The rear and trans gears were selected years ago based on a many assumptions. Viking took a look as the last set of videos and had us few pointers.
" The only issue I see is the rear appears to have a little bounce right as it starts to roll out. When the bounce occurs I do not really see the wheel/rim move or bounce with it due to improper shock settings, but I think the bounce is more from the rear tire getting squashed hard. I would argue that you are hitting the tire pretty hard and it looks like you are starting to fold the tire."
We need to adjust tire pressure "increase" and then look at suspension settings.
Name:	Raven Launch Viking.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
