Old 06-30-2019, 02:21 PM
GTOGEORGE's Avatar
I believe it is, I sent a note to Carl last week to confirm leaving in 2nd gear is ok.
Why would you want to leave in second? Your clearly not putting any power to it til the back half of the 1/8.....just wondering.
GTO George
  #1622
Old 06-30-2019, 02:28 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by JSPONT View Post
I see my question brought up what I was thinking. I did not want to get to personal and ask to see a time slip(hint) . Grinner TB work in 1st and 2nd gear.
It would be interesting to see what happens with a little more power at the launch in 2nd gear. Car looks great! Thanks for keeping us posted.
Times from the 2nd video.
60 1.246
330 3.345
1/8 5.064
MPH 143.08
1000 6.546
ET 7.846
MPH 167.09
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1623
Old 06-30-2019, 02:36 PM
RAIV-Z's Avatar
Originally Posted by ponjohn View Post
You guys mean that is a lot of first gear compared to a glide?
That is a very tall tire.
Calculated MPH with different transmission 1st gears @7500rpm:
https://spicerparts.com/calculators/...rpm-calculator
T400 2.48 = 77.51
Rossler 2.10 = 91.54
Powerglide 1.82 = 105.62
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1624
Old 06-30-2019, 02:38 PM
RAIV-Z's Avatar
Originally Posted by John Langer View Post
What size rear tire? You use Viking shocks?
33.5x16.5. Yes, I'm using Viking shocks.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1625
Old 06-30-2019, 02:47 PM
RAIV-Z's Avatar
GTO George
To see what effect is has on building boost sooner with the current tune.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1626
Old 06-30-2019, 04:25 PM
John Langer's Avatar
John Langer John Langer is offline
GTO George
So you can put the power to it. It is an acceleration competition, not the salt flats. I would love to not have to pull power out on the hit and leave at a much higher rpm for the first second. I could go much quicker if I could.
  #1627
Old 06-30-2019, 04:26 PM
Me, I would go with a different shock.
  #1628
Old 06-30-2019, 04:36 PM
RAIV-Z's Avatar
If we hit the limits of what these can do for us, I'm open to options. At this point we haven't made any chassis/suspension adjustments from our original starting point.
Which shock/spring vendor? Santhuff?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1629
Old 06-30-2019, 04:42 PM
Real cars need real shocks that respond to change and have repeatability. I use santhuff. Others have found success with afco/menscer, bell/kinetic, Penske, jr1 to name a few.
  #1630
Old 06-30-2019, 04:57 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
No more of a truer statement than that.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #1631
Old 06-30-2019, 05:21 PM
RAIV-Z's Avatar
For now we'll work with what we have, if they become the limiting factor they will be changed. I do expect we'll be able to hit consistent 1.1x 60's.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1632
Old 07-01-2019, 09:14 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
You need to hit it hard out the gate to get it moving.
[email protected]. 3460#s
  #1633
Old 07-01-2019, 09:38 AM
RAIV-Z's Avatar
What RPM are you launching at? I'm at 4800rpm now, planning on increasing to to ~5500.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1634
Old 07-01-2019, 11:20 AM
GTOGEORGE's Avatar
So what kind of boost you running ......leaving and down the track?
GTO George
  #1635
Old 07-01-2019, 11:49 AM
RAIV-Z's Avatar
GTO George
~6lb on the launch with a target of 12lb as the last event, target and a target of 20lb going down the track.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1636
Old 07-01-2019, 08:28 PM
LiL Jack's Avatar
3700
A buddy of mine leaves on 12#, but closer to 40# down the track.
  #1637
Old 07-01-2019, 10:02 PM
wreckmastr's Avatar
Are you pulling any timing on the launch (Launch retard)?
3400 launch at 9lbs here
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
  #1638
Old 07-02-2019, 06:58 AM
RAIV-Z's Avatar
I'm not pulling any timing while on the t-brake in the current tune.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1639
Old 07-02-2019, 07:48 AM
LiL Jack's Avatar
That’s correct you should not be or it won’t go up on the brake. It activates when u let go of the brake. You might want to try lowering the leave RPM, it will hit the converter harder.
Work on the front half and the back half will follow.
  #1640
Old 07-03-2019, 01:05 PM
cgeise's Avatar
cgeise cgeise is offline
You need to pull timing out on the t-brake - it helps spool faster -- Tell LIL Jack to -- stay in his own lane --
