#121
Old 12-03-2019, 08:33 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Another head with great potential at a VERY effective price point and the chamber is too small, volume is not right, aluminum is not shiny enough.....this is crazy.
THIS is why AFR or any of the other cylinder head companies will run away from making a Pontiac head.
  #122
Old 12-03-2019, 08:57 PM
Mike Davis's Avatar
Funny you say that,
I mentioned it to a couple of MFG's at PRI one year that we had a CNC booth there. They said the exact same thing. One guy said--"Have you ever looked at the Forums?... Those guys are stuck on factory cams, 10" converters and Dual plane intakes."
Most said they check the forums to see what peoples wants and needs are. A few said Pontiac people are cheap and have a 70's mindset.
They will pay $500 for a certain date code distributor but won't pay $750 for a cam and lifters.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
The Following User Says Thank You to Mike Davis For This Useful Post:
  #123
Old 12-03-2019, 09:03 PM
slowbird's Avatar
slowbird slowbird is offline
Originally Posted by Mike Davis View Post
Funny you say that,
Agree Pontiac guys are cheap!!
  #124
Old 12-03-2019, 09:11 PM
mgarblik mgarblik is offline
While the above two posts are true, (I have heard these comments myself), that's not the primary reason AFR, DART, WORLD, and many other vendors won't "mess" with "Pontiac" stuff. It's more of a bland numbers game as the reason. These manufacturers have a finite manufacturing capacity. It's much easier to mass market engine parts that have a huge pool of potential buyers than a tiny niche market like Pontiac, Olds, Buick, FE Ford, AMC and so forth. They can sell more of the latest wizz bang LS head than all the ones I mentioned combined and think of how much easier the production is for a single design. I try to commend virtually every part brought to market for a Pontiac V-8. Just because I may not use it personally, or I don't like certain features, that doesn't mean it won't be great for someone else.
  #125
Old 12-03-2019, 09:28 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Funny you say that,
Don't forget a Q-jet carb and if they do fork out the dough for a roller cam there is only one grind they are interested in.
Go fast, see Elvis!
  #126
Old 12-03-2019, 09:39 PM
ponjohn's Avatar
One thing that is a huge benefit today is design time. You can do a proof of concept in 3d printing - THIS has to reduce the cost
Can Dart etc bundle all the other makes into one production run to at least try and make up the volume?
  #127
Old 12-03-2019, 10:49 PM
P@blo's Avatar
P@blo P@blo is offline
Lap it up these heads are taking away your American jobs
  #128
Old 12-04-2019, 12:57 AM
Balderdash!! The heads are finished here in the U.S. Is reading comprehension NOT on your list of accomplishments?
Dr. Thomas Sowell
  #129
Old 12-04-2019, 03:33 PM
dmac dmac is offline
Originally Posted by shaker455 View Post
I can help you boys in that dept if you want to go that route
How?
  #130
Old 12-04-2019, 03:38 PM
If you want to run small chamber heads on a 455 all you have to do it run dished pistons, I've been using small chamber heads on 455s with dished pistons since the 70s. .
Then the job becomes more than a simple head swap. Dished pistons, new rings, more shop costs adds up for the average American making $30k per year. You may as well pay a couple hundred more and just buy KREs with the bigger chamber. Not having the bigger chamber cuts the potential market in half- not good for a company trying to break into the market.
  #131
Old 12-04-2019, 03:56 PM
JLMounce JLMounce is offline
I believe it's been mentioned that a mid 80cc chamber as well as cnc porting options will be coming for those heads?
-Jason
1969 Pontiac Firebird
  #132
Old 12-04-2019, 04:22 PM
Sirrotica's Avatar
I was building the engine from scratch, so dished pistons were the same as flat tops. The gist of the post is that it can be done if you want to run the cheaper, small chamber heads on a 455. Is it the cheapest route to aluminum round port heads, probably not, unless your building the engine in question as you are installing the aluminum heads, it can be done though. The post proceeding my post left the conclusion that there was no way to get to the end result of having a 455 with small chamber heads on it, my post said that the dished pistons were the way to solve the problem.
I'm thinking someone isn't just swapping heads onto a mostly stock short block and trying to run it as hard as they want to without something substantial under it. I'm more used to running on a dirt track, and if you just did a head swap on one of those engines without everything being top notch in the short block, in one night of racing you'd be picking the parts up off the track. I've tried it more than once, and that's the result. Cast pistons and tight clearances won't last when subjected to added strain, (more than squealing tires leaving the Dairy Queen) and higher power.
You may, or may not know, that Pontiac was more selective about parts and clearances when assembling round port engines at the factory. They weren't built the same as a station wagon 455 was, for a reason. The RA IV and the 455 SD also got forged pistons, the SD 455 with the long stroke also got forged rods, again for a reason.
The theory is that if they had the 87 cc heads available, you could pull a head swap and just not worry about the engine self destructing, until it happened...... Did the $30,000 a year guy save any money in the end?
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #133
Old 12-04-2019, 04:29 PM
72projectbird's Avatar
I think that's the next step after the car is back from paint. Aluminum heads and a roller cam!
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #134
Old 12-04-2019, 04:39 PM
Lol, I did exactly that. Threw a roller cam and some KRE D ports on my 455. Granted, it's not a bone stock build, it was built by a previous owner, but retains the factory rods and crank with TRW slugs.
I've been beating the crap out of this thing for a while now. I think this situation is probably a bit more prevalent though than having a bone stock 455 you yanked out of a wagon.
Dish pistons are certainly an option if you're building at the time of purchase. These speedmaster heads wouldn't have worked for me because I needed more chamber size.
-Jason
  #135
Old 12-04-2019, 06:28 PM
tom s tom s is offline
Im planning on a new street build and would like to try a set but refuse to do headers.If the long branch round ports become avail again I would try a set.Tom
  #136
Old 12-04-2019, 07:17 PM
77 TRASHCAN's Avatar
Tom, didn’t you have headers built for you latest project? Did that not work out?
Shut it off
Shut it off
  #137
Old 12-04-2019, 07:37 PM
JC455 JC455 is offline
Tom S-
I spoke w/ RARE earlier this year about Round Port Long Branch manifolds. He said they should be back in production around the first of the year.
John
IG: @crawdaddycustoms
  #138
Old 12-04-2019, 07:55 PM
Paul has said that for awhile,going to buy a set to have on hand if the need comes up.Tom
  #139
Old 12-04-2019, 08:05 PM
RA V headers wont work with D port or round port heads!AND I HATE headers!Tom
The Following 2 Users Say Thank You to tom s For This Useful Post:
  #140
Old 12-05-2019, 02:57 PM
goatman1970 goatman1970 is offline
just don't get the complete cheap Chinese heads from Summit or JEGS, they put cheap Chinese parts on them, buddy bought a complete set of aluminum heads for his SBC and broke a stud fairly quickly, just get the bare heads and go from there
