Old 03-04-2024, 07:53 PM
79 Phoenix's Avatar
79 Phoenix 79 Phoenix is offline
Default Anyone know what this is?
I found a couple of these on the front driver's floor of my car. Does anyone know what it is? It's about 1 1/2" long.
Name:	Mystery Plate.jpg
Old 03-04-2024, 08:53 PM
Held for Ransom's Avatar
Maybe this?
So long, farewell.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
Old 03-04-2024, 09:31 PM
yahooskidoo's Avatar
yahooskidoo yahooskidoo is offline
Maybe this?
Amazing! Mike, what don't you know about our cars?
Old 03-04-2024, 09:45 PM
dataway's Avatar
dataway dataway is offline
I guess my usual McGanzer Flange comment would be pointless now.
Old 03-04-2024, 10:09 PM
He also posted about a loose shifter. I was able to put two and two together. Hard part was searching for a picture...
So long, farewell.
Old 03-04-2024, 11:07 PM
79 Phoenix's Avatar
Okay... So it's a spacer for that thin bolt that goes sideways on the shifter? I was thinking the loose, sloppy shifter question and this piece might be related but wasn't sure.
Old 03-04-2024, 11:35 PM
It's more of a positioner. It keeps things from floating around.
So long, farewell.
Old 03-05-2024, 08:17 AM
79 Phoenix's Avatar
Got it. Thanks so much!
Old 03-05-2024, 12:13 PM
tempest1964's Avatar
I believe it's called a pivot bolt bridge plate.
Old 03-06-2024, 03:02 AM
dataway's Avatar
Are you SURE it's not called a Pivot Bolt McGanzer Plate ?
Old 03-06-2024, 08:48 AM
At this point in my life, I’m not sure of anything. ��
The Following User Says Thank You to tempest1964 For This Useful Post:
Old 03-06-2024, 10:04 AM
Don't worry, you're right. It's a bridge plate. Dataway was just trying to use his standby reply to these type of questions.
So long, farewell.
Old 03-07-2024, 12:52 PM
Tim Corcoran's Avatar
Originally I thought it might be a muffler bearing support bracket
Tim Corcoran
The Following User Says Thank You to Tim Corcoran For This Useful Post:
Old 03-07-2024, 03:53 PM
Bill Hanlon's Avatar
Nah. Those have grease fittings.
The Following User Says Thank You to Bill Hanlon For This Useful Post:
Old 03-07-2024, 08:16 PM
jerry455 jerry455 is offline
Only on the older ones, the removed those on the lubed for life models.
The Following User Says Thank You to jerry455 For This Useful Post:
