Old 08-18-2025, 05:50 PM
Pepi's Avatar
Pepi Pepi is offline
Stuart,
I finally got around to pulling out my paperwork to look at the chart, and mine doesn't have that column for whether or not a spark delay valve was used. That is why I had never noticed it before.
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 08-18-2025, 06:29 PM
Stan65 Stan65 is offline
Pepi,
I did have it staring me in the face. What is the TSB you have?
Old 08-18-2025, 10:46 PM
Held for Ransom's Avatar
Originally Posted by Pepi View Post
Stuart,
DTB (Dealer Technical Bulletin) 73-T-21 and DTB 73-T-21A (chart is the same in the Craftsman Service News 1973- Number 2) list that column.
So long, farewell.
Old 08-21-2025, 10:54 PM
65madgoat's Avatar
What stud or bolt etc is used on the intake manifold to mount the bracket? I am mocking it up and appears you need a spacer on the bolt at the intake maniold (all stock parts by the way for a 55 amp alternator)...
Is this it?
https://www.classicindustries.com/pr...A8700191.html?
Old 08-22-2025, 04:54 PM
Pepi's Avatar
Originally Posted by Stan65 View Post
Pepi,
I didn't have a TSB, I think I was looking at the parts catalog that showed the same chart, but without the last column.
Old 08-22-2025, 06:11 PM
Formulabruce's Avatar
Pic, 1970 on a stud in goose neck. Need a spacer for alternator rear.
" Long may we DRIVE !"
Old 08-22-2025, 06:21 PM
65madgoat's Avatar
I was seeking what bolt/stud/spacer etc is used to mount the bracket on the head side of the intake manifold....
Any pics appreciated.
Old 08-22-2025, 06:43 PM
Other side of bracket. This is a 1970 ONLY set up FYI..
Old 08-23-2025, 10:42 AM
Assembly manuals help...
So long, farewell.
Old 08-23-2025, 10:53 AM
65madgoat's Avatar
Yeah I have one but can't see style of stud in head. The stud must have some thick spacer/head on it as my bracket will not get down low enough without a considerable spacer etc on stud. And when mounting to alternator, rear strap also needs a spacer there as well which 1972 diagram does not show but others pointed out their car having. Photo of stud style used on head appreciated
Old 08-23-2025, 02:12 PM
It's the same stud (9798854) as the 2 on the other side for the A/C bracket. Washer (spacer) (9779596) is used on all three studs. The Inline Tube stud is probably close (the one in your link).
So long, farewell.
Old 08-24-2025, 01:10 PM
65madgoat's Avatar
Ahhh... I now see the kit I got did not have the proper "bolt-studs" used for the coil, alternator bracker and A/C bracket.
This kit has them!
https://www.inlinetube.com/products/inl11353
Old 08-24-2025, 01:19 PM
So you're doing a '72 HO?
https://forums.maxperformanceinc.com...d.php?t=684975
So long, farewell.
Old 08-24-2025, 01:48 PM
65madgoat's Avatar
Thanks as I did just see that page last night actually. Great to add it to this thread
Old 08-25-2025, 10:41 AM
65madgoat's Avatar
Ok here is the deal. No one sells a proper stud/bolt kit for 455HO intake manifolds. Not enough studs and/or bolt-studs.
And actually the photo shown in the inline tube link is incorrect as those stud-bolts shown are really just studs with a washer under the 'nut' on the stud. They are not shouldered like oem.
AMK sells the right "bolt-stud" at a whopping $12 each. Do it once, do it right. Ha.
https://www.amkproducts.com/bulk-fas...oduct_ID=15557
