Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 06-23-2023, 07:09 AM
mysticmissle's Avatar
norwalk delivery available
Old 06-24-2023, 07:46 AM
had a question on what is included for $17000 this is the description.
that is priced wo any heads $17000 gets you head gaskets to pan rail. no oil pan no push rods, but everything else in between. you get fully machined aluminum block ready to assemble, ross pistons grp/mgp rods BWE rings hung on rods, scat stroked crank, rod and main bearings, 55mm comp cam shaft, crower 903 bushed lifters, butler oil pump, sims timing chain, used pontiac timing cover, cometic head gaskets w water holes, if you are going to use these gaskets, water holes will need to be added to block deck surface. this will go to 9000 rpm if you want
machine work was over $4000 alone.
540 is back in the car now, new IA2 block is in garage, most likely switching to pressurized, pump gas combo in next few years, is only reason to not keep this set up. will consider trades
Old 07-08-2023, 12:12 PM
last norwalk bump parts are not coming wo deposit.
Old 11-07-2023, 12:57 PM
still available as the 540 is going strong
Old 01-16-2024, 09:28 AM
spring is coming, available and this is ready to assemble
Old 06-17-2024, 07:43 AM
this is all assembled and ready to go minus timing chain/cam degreeing. will deliver to norwalk and help you install, i mean watch you install in the pits w deposit.
Old 09-18-2024, 11:38 AM
no wait high end short block available
Old 02-02-2025, 05:55 PM
Tax return bump
somebody buy this before it ends up in my car
will consider partial trade, will also sell set of hiports 400cfm and shaft rockers, intake with it for extra
Old 03-20-2025, 03:44 PM
available
The Following User Says Thank You to mysticmissle For This Useful Post:
Old 05-16-2025, 06:03 PM
Short block complete
On the engine
Stand also
Available titan oil
Pump and Steffs pan for
Extra $800
Old 06-11-2025, 08:14 AM
$14000 wo cometics, cam lifters and oil pan and titan pump. $16000 w cometics, head studs, cam lifters, titan pump and steffs pan
Old 09-08-2025, 12:50 PM
available
Old 02-18-2026, 09:54 AM
available complete with 400 cfm hiports, shaft system, victor intake, and dominator if so desired. will also sell rotating assembly, crank, rods, pistons seperately.
Old 05-27-2026, 01:38 PM
hi ports shafts, intake, have sold.
cam and lifters available, rotator available, i am keeping block if not sold as a short block package
