Old 06-02-2026, 12:00 PM
Default cracked block or on crack
Hey fellas:
I got some bad news about my daily from the stealership. It is a 2016 GMC Canyonaro but developed a small coolant leak recently
They thought it was one of the block plugs but after replacing that it she still leaked. Then they put a borerscope down the hole and found that my F@%#%# block is cracked!
I have babied this thing since new and barely drive it as I work from home. Has anyone seen this before? My regular mechanic says the manufacturers are cutting corners and has seen this before.
This is a nitemare scenario. It was hard enough replacing the motor in my beloved Pontipig. I must be cursed.
Old 06-02-2026, 12:58 PM
I would see if there are any silent recalls for this issue.
Though being in Canada with this problem may affect coverage.
Old 06-02-2026, 01:33 PM
mysticmissle's Avatar
so cant fix the leak, but i have used moroso ceramic seal for similar issue in the past. it worked very well. as a back up plan. if you go this route make sure you buy the one for antifreeze, and also follow the drections to the letter. hopefully you can get some more useage out of your canyon
Old 06-02-2026, 01:37 PM
External crack in the casting near the freeze plug?
Then use a block sealer as already mentioned.
Internal crack?
May not be fixable.
So exactly where is the crack located?
Old 06-02-2026, 02:07 PM
KS circutguy's Avatar
Lightbulb
Hey fellas:
Sounds like it's time to go electric.
Old 06-02-2026, 06:16 PM
unruhjonny's Avatar
I'm sorry to hear about this.
If you are thinking of moving on from a depreciating asset, and open to different ideas;
The more I know about the current lot of garbage, which is the new car market, the more a classic truck as a daily driver seems to be a seriously good idea.
In my opinion, there are some decent deals to be had on GMT400's or other pre-1967 GM trucks.
https://www.hemmings.com/listing/195...sley-ma-489340
https://www.hemmings.com/classifieds...son-il-2945836
Just some food for thought.
Name:	Hemmings truck 001.jpg
ID:	671253   Click image for larger version
Name:	Hemmings truck 002.jpg
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 06-02-2026, 10:44 PM
SRGN SRGN is online now
I wanted a truck, you can't buy anything with a V8, manual transmission anymore. I hate screens as well, so I bought a 1965 C10 and should have it done soon. Everything I want, nothing I don't.
The Following 2 Users Say Thank You to SRGN For This Useful Post:
Old 06-02-2026, 11:04 PM
Not that I can find however lots of complaints about the lil diesel.
Old 06-02-2026, 11:06 PM
Did you mean this https://moroso.com/media/instructions/35500_inst.pdf
If so, did you dump your antifreez temporarily with water?
Old 06-02-2026, 11:09 PM
It is tempting with these cheap new units...everything disposable anyways
I'm stuck in the country for at least another year until I can fix/sell this house and its life and death without gas/4x4 at least for now
Old 06-02-2026, 11:11 PM
I've gone down that road before with a number of AMC bEagles. I'm not handy, I'm handsome so two old vehicles are more than I can handle lol
The pontipig is a handful for this computer guy haha
Old 06-03-2026, 08:30 AM
Big Bear's Avatar
Big Bear Big Bear is offline
Used Irontite coolant sealer with success. Sealed larger pin holes in industrial equipment. Bought it from truck parts store but see that Amazon carries it.
Old 06-03-2026, 11:12 AM
I'll look into that as well...thx
Old 06-03-2026, 11:15 AM
Update:
Still waiting for the stealership to put humpty back together.
I think they are hoping for an upsell but I'm broke.
I think I will buy a wreck from the insurance auction and get my buddy to do the swap then let her go.
I will miss her tho...
stealership inspection: https://kmoby.com/Zoqe9MpRV
Old 06-03-2026, 01:35 PM
What exact engine was this? 5.3? 6.2?
Old 06-03-2026, 02:29 PM
3.6 LFX, allegedly same as crapmaro, impaler, equinox, terrain, traverse etc
Old 06-03-2026, 05:27 PM
JimFB400HO JimFB400HO is offline
I would think some kind of a epoxy-based patch would be available for something like that.
Old 06-03-2026, 08:00 PM
As all ready mentioned I have used ceramic seal a few times with good luck. What I used wanted the system flushed first but if they have an antifreeze compatible version I would give it a try. Good luck with it.
Old 06-03-2026, 08:35 PM
Worst case, pour some blue devil in it and send it to the auction like the dealer would. It's a LT 5.3, they're plentiful in the yards near me. Swap isn't bad, if you choose to drop in a junkyard engine it can be done in a weekend at home. Will be a good time to fix broken exhaust manifold bolts too.
