| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Hey fellas:
I got some bad news about my daily from the stealership. It is a 2016 GMC Canyonaro but developed a small coolant leak recently They thought it was one of the block plugs but after replacing that it she still leaked. Then they put a borerscope down the hole and found that my F@%#%# block is cracked! I have babied this thing since new and barely drive it as I work from home. Has anyone seen this before? My regular mechanic says the manufacturers are cutting corners and has seen this before. This is a nitemare scenario. It was hard enough replacing the motor in my beloved Pontipig. I must be cursed. Thanks
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
I would see if there are any silent recalls for this issue.
Though being in Canada with this problem may affect coverage. |
so cant fix the leak, but i have used moroso ceramic seal for similar issue in the past. it worked very well. as a back up plan. if you go this route make sure you buy the one for antifreeze, and also follow the drections to the letter. hopefully you can get some more useage out of your canyon
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
External crack in the casting near the freeze plug?
Then use a block sealer as already mentioned. Internal crack? May not be fixable. So exactly where is the crack located?
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
https://www.flickr.com/photos/197745168@N07/ "Of all ignorance, the ignorance of the educated is the most dangerous. Not only are educated people likely to have more influence, they are the last people to suspect that they don’t know what they are talking about."Thomas Sowell |
I'm sorry to hear about this.
If you are thinking of moving on from a depreciating asset, and open to different ideas; The more I know about the current lot of garbage, which is the new car market, the more a classic truck as a daily driver seems to be a seriously good idea. In my opinion, there are some decent deals to be had on GMT400's or other pre-1967 GM trucks. https://www.hemmings.com/listing/195...sley-ma-489340 https://www.hemmings.com/classifieds...son-il-2945836 Just some food for thought.
| The Following User Says Thank You to unruhjonny For This Useful Post: | ||
| The Following 2 Users Say Thank You to SRGN For This Useful Post: | ||
Not that I can find however lots of complaints about the lil diesel.
Did you mean this https://moroso.com/media/instructions/35500_inst.pdf If so, did you dump your antifreez temporarily with water?
It is tempting with these cheap new units...everything disposable anyways
I'm stuck in the country for at least another year until I can fix/sell this house and its life and death without gas/4x4 at least for now
The pontipig is a handful for this computer guy haha
Used Irontite coolant sealer with success. Sealed larger pin holes in industrial equipment. Bought it from truck parts store but see that Amazon carries it.
I'll look into that as well...thx
Update:
Still waiting for the stealership to put humpty back together. I think they are hoping for an upsell but I'm broke. I think I will buy a wreck from the insurance auction and get my buddy to do the swap then let her go. I will miss her tho...
stealership inspection: https://kmoby.com/Zoqe9MpRV
What exact engine was this? 5.3? 6.2?
3.6 LFX, allegedly same as crapmaro, impaler, equinox, terrain, traverse etc
I would think some kind of a epoxy-based patch would be available for something like that.
As all ready mentioned I have used ceramic seal a few times with good luck. What I used wanted the system flushed first but if they have an antifreeze compatible version I would give it a try. Good luck with it.
Worst case, pour some blue devil in it and send it to the auction like the dealer would. It's a LT 5.3, they're plentiful in the yards near me. Swap isn't bad, if you choose to drop in a junkyard engine it can be done in a weekend at home. Will be a good time to fix broken exhaust manifold bolts too.
