Old 01-06-2005, 09:54 AM
mt. goat mt. goat is offline
I put a tko600 in my 65 GTO this summer. I learned most of what i needed from this forum. Missed shifts refers to 2nd to 3rd and hitting 5th,kinda blows your e.t. Cut the floor pan and rotate it then splice a piece of sheet metal on side gap. Get the optional GM 2" offset shifter, 26 spline clutch disc, 31 spline diveshaft yoke and move the trans mount back 1.5". You should have 1" spacing between the rear rubber boot on trans and face of driveshaft yoke. You'll love it.
Old 01-06-2005, 12:51 PM
charlie66's Avatar
Mountain goat,Are you saying that you do have problems with shifting or you don't.When the sift is missed is it because it won't go in(it binds)or dose it grind,maybe it's just a matter of getting to know the H pattern of the shifter?I'm curious because i want to buy one.
Thanks.
My Half AN Injun.....
Old 01-06-2005, 01:03 PM
tom s tom s is online now
Just to clear up my post,the TKO is the best shifting trans I have ever had.I have a ST-10 in one car and a Muncie in 2 other cars.I have driven the 5 and 6 speed Richmonds and non compare.The problem as I said when "I" try to power shift 3rd to 4th,SOMTIMES I push a little too far and hit between 2 gears.No grinding just a missed gear.I run a Hurst Billet shifter with a Hurst flat shifter arm.Tom
Old 01-06-2005, 01:36 PM
charlie66's Avatar
Thanks Tom,I just don't want to make the wrong choice,I'm assuming by your reply your giving it the thumbs up?Do you have any regrets about buying it?
THANK'S.
Old 01-06-2005, 01:40 PM
NONE,it is the single best thing I did to my car when I built it.In fact,I am thinking of putting one in my 63 Lemans convert.Tom
Old 01-06-2005, 03:17 PM
Tom you just need to swap me for my racing Richmond 5 speed and the Vertigate shifter for it!
Old 01-06-2005, 03:32 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Moutain Goat, Welcome to the board!! Listen to Tom, he has one in his car! I should have kept my big mouth shut and not repeat something unless I am sure. -Jim
Old 01-06-2005, 04:58 PM
Charlie, What I meant was the shift pattern is so tight that you hit 5th instead of 3rd, no grinding just a precipitous drop in rpm.Incidently, getting initially logged on to this forum was harder than installing the TKO. I guess that says something about my computer skills. Good luck, Mt. Goat
Old 01-06-2005, 08:43 PM
charlie66's Avatar
Thank's guy's you've bin more help then you'll ever now.
Old 01-06-2005, 08:48 PM
charlie66's Avatar
MT.Goat did you have to cut out your floor to istall the tranny?
Old 01-06-2005, 08:54 PM
JoePapa's Avatar
JoePapa JoePapa is offline
Howdy guys -
I need to ask a silly question here. The TKO-600 is rated at 600lb-ft of torque. Has anyone here had problems with it not being able to handle the HP/TQ you throw at it? I just got done toasting 1st gear on my Muncie and have been tossing around a few options; the TKO is certainly one of them.
The reason I ask the durability question is the present motor has plenty of torque (broke 2 rearends, twisted axles in two, and now it ate 1st gear). It seems like these Poncho's can hit the 600 lb-ft threshold pretty easily; especially if you're spraying N2O.
Any thoughts on that?
'69 Firebird 400
http://firstgenfirebird.org/show/closeup.mv?CarID=734
Old 01-06-2005, 08:58 PM
bigcountry bigcountry is offline
Just in case any of you guys are interested in a brand new one, I have one with the offset shifter position to work with stock consoles, never out of the box. Also have the clutch, bellhousing, etc.. I will sell for a great price and there is no waiting for tremac (13wks backorder last year when I ordered!)
The light at the end of your tunnel is just a freight train coming your way - Metallica
Old 01-06-2005, 09:16 PM
BigCountry,
What version of TKO is it,
TKO600 with .82 OD ???
Am trying to figure out what trans crossmember mods are needed for '68-72 GTO, then will be ready to order one. Need to PM Tom in AZ he should know the crossmember mods.
Old 01-06-2005, 09:35 PM
it is the TKO 600 with .82 overdrive. Bought the entire kit for a 66 goat from Keisler and then changed directions with the project and sold the car.
Old 01-07-2005, 09:00 AM
Swap for a race Nash and multiple shifters?
Old 01-07-2005, 09:31 AM
I think it is a great trans for the street with some race use.BUT,untill someone comes up with a 5th-rev lockout I would say to go with a Jerico for dragrace use.NO ONE is going to drag race a stick shift serious without powershifting!IMHO,Tom
Old 01-07-2005, 09:32 AM
once the last light goes yellow,LIFTING is NOT a option!
  #38
Old 01-07-2005, 01:12 PM
gearbanger's Avatar
gearbanger gearbanger is offline
Big Country,
I am interested in that tranny and the clutch maybe. Send me an e-mail
[email protected]
  #39
Old 01-07-2005, 02:57 PM
Jim Doran's Avatar
Jim Doran Jim Doran is offline
Big Country, I might be interested as well. I have been checking out the Keisler site for some time now.
Keep me posted should gearbanger not purchase it.
[email protected]
-Jim Doran-
1965 389 Tripower; 4 speed; convertible
2019 Tesla Model 3 Performance
2016 Chevy SS; Sold
2001 Toyota Tacoma 4x4
2008 Infiniti G35x
  #40
Old 01-07-2005, 10:51 PM
charlie66's Avatar
http://[email protected]/ For any one that's interested.Check out this link.
