Seriously John, are you saying this should be a non-issue? Should the opening be cleaned up so the material around the opening is thick enough so it doesn’t flake off? This is my first aftermarket block, are the main caps stamped by the MFG? I agree, I doubt BES re-machined the thrust bearing cap.
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
I talked to a few people including Tony and Bob C. regarding the main caps. The general consensus is that although the hammer marks are ugly they will not weaken the main caps. We’re not sure how the marks or double stamps got there. Tony is also willing to work with me on some of the other issues.
That does NOT answer who did that crap -
Cage is out of the car for final welding.
Shouldn't you have a seat support tube under the driver,from the outer floor tube to the inner floor tube? Looks good though.
Mccarty already put the bar under his seat.
LOL! Now that is funny, very cleaver.
Truly sorry to hear of RamIV-Z continuing issues and not trying to trivialize his situation ,but your comment really made me laugh. |
Maybe he needed a support rod to go with the Titanium Plate I sent him a while back.
Tom Vaught
You're right, there should be a seat support bar. It wasn't installed yet.
Looks good Ed, any updates on the heads?
Thanks, all the major welding is done only a few more bars to add. The cage should be back in the car sometime next week. Regarding the RA-V heads, I’ve had a few conversations with Tony over the last couple of weeks.
Happy New Year to all!
When you are doing a Boosted Engine you don't need a Boosted Engineer just the Internet and some "common sense"! Of course any help is better then no help.
![]() GTO George |
Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” |
Hope you sort out all the problems.
Panos Little Miss G Racing on Youtube |
many years ago, when Dan Whitmore would do a "race port" job on a set of RA IV heads, he would break thru the pushrod hole, and epoxy a bronze sleeve in there to seal the port up.... the same should be able to be done for a head bolt....
just sayin |
So now you have cut away the support structure and you want to put a "push rod bronze sleeve" back in to seal up the hole but you think nothing about the loss of clamp load on the head gasket at that point on the head? I have seen guys narrow the boss between the two runners on a normal cast iron Pontiac head and later they could not hold a head gasket. A cast iron head, not a softer aluminum head. Sorry but I think that you are missing the point here. It is not to seal up the oil leakage, etc, it is to be able to properly clamp down the head and have a head gasket hold under high boost pressures. Tom Vaught
Eric
For an NA application, where cylinder pressure is lower and port flow is more critical, a thinner wall is the correct approach. Every design is a compromise to suit the specific use.
Eric
So what you’re saying is that on a boosted engine, this is not what you would have done? Got any of those billet V heads “with water jackets” or any suggestions to make my V heads work with with at least 25lb of boost? Merry Christmas to all. Ed
