Old 09-17-2011, 09:41 PM
69FIREBIRD76MM's Avatar
Default MUNCIE-4 SPD HURST SHIFTER UPGRADE FOR DRAG RACING?
I HAVE A 69 FIREBIRD 455 WITH A MIUNCIE 4 SPEED,I WANT TO RACE MY CAR FOR FUN ONCE IN A WHILE AT THE 1/8 TRACK, HAS ANY OF YOU GUYS MODIFY OR UPGRADE THE RODS TO MAKE THEM SHIFT BETTER WITHOUT FLEXING THEM...I PLAN TO KEEP THE STOCK ORIGINAL SHIFTER, HOW ABOUT CHANGING TO STEEL BUHINGS....ANY IMPUT WILL BE GREATLY APPRECIATED---JOE
Old 09-17-2011, 10:02 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
The shift rods from a 70 are much thicker and less flexible the prior years.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
Old 09-17-2011, 10:05 PM
GOAT WHORE--LOL...THEY FIT WITH NO ISSUES?...
Old 09-17-2011, 10:08 PM
GOAT WHORE's Avatar
I believe so.
Someone else chime in to confirm.
Old 09-17-2011, 10:12 PM
I THINK THE GUYS THAT RUN PURE STOCK DRAGS..WITH THOSE STICKSHIFT FIREBIRDS AND GOATS CAN PROBABLY TELL ME HOW THEY DO IT....
Old 09-17-2011, 10:18 PM
GOAT WHORE's Avatar
I am sure a lot of them just run stock linkage. I row the crap out ofine with no problems but I have 70 linkage.
Old 09-18-2011, 12:12 AM
A.W.Dille A.W.Dille is offline
Steel bushings hold up better than the nylon ones and I always lube mine with white lithium grease on both ends.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 09-18-2011, 10:07 AM
How do you expect to keep the Muncie together after the 2-to-3 Upshift?
Are you running an OHC-6?
Old 09-18-2011, 10:12 AM
ry57pont's Avatar
ry57pont ry57pont is offline
ihad my shifter rebuilt by percision pontiac, i kept missing gears at the track and now i shfts like a dream. - RB
1970 gto (4spd) 462 500 hp
[email protected] / 1.843 60'/ 3980 lbs
1964 corvette roadster
1968 corvette roadster
1962 corvette
"equal rights, not equal things"
if you want to know the future, read "atlas shrugged"
I dont race a 4spd because it is easy, I race a 4spd because it is hard.
Old 09-18-2011, 10:33 AM
andrewT's Avatar
andrewT andrewT is offline
this
The Educated Fool
Old 09-18-2011, 01:41 PM
What about "this"?
Old 09-18-2011, 02:00 PM
andrewT's Avatar
What about "this"?
as in I agree
The Educated Fool
Old 09-18-2011, 04:47 PM
JoePapa's Avatar
JoePapa JoePapa is offline
I don't know what power level you're running but with spray I put about 525 to the back tires. I upgraded my munchie by adding the Autogear case and iron midplate and M22W gears (after I shattered the factory case and 1st gear). Then I welded some small angle iron to the shifter rods becuase they were flexing and I'd get stuck in 2nd gear which sucked.
http://forums.maxperformanceinc.com/...=540777&page=2
After these mod's it took the abuse I threw at it.
'69 Firebird 400
http://firstgenfirebird.org/show/closeup.mv?CarID=734
Old 09-18-2011, 06:37 PM
Dragncar Dragncar is online now
Dude, dump the all caps.
No one like being yelled at the whole time.
It makes for a bad read.
Old 09-18-2011, 06:53 PM
Default muncie
MOTOR IS A 455 , 060 OVERBORED, #96 HEADS PORTED MATCHED TO RA IV GASKETS, CROWER HYD CAMSHAFT, #60211, 12 BOLT WITH 3.55 GEARS, MUNCIE M20, NEW CLUTCH AND REBUID TRANS, THINKING OF RUNNING 255-60-15 DRAG RADIALS, NOT SURE OF THE HORSE POWER THIS THING IS MAKING....BUT I JUST WANT TO BE ABLE TO SHIFT THE MUNCIE AS SMOOTH AS POSSIBLE...
Old 09-19-2011, 10:21 AM
JoePapa's Avatar
Wow, that was the cam from my first build - she rumbled nicely with that.
'69 Firebird 400
Old 09-19-2011, 01:34 PM
JOE PAPA---YES IT IS A PRETTY NICE SOUNDING CAMSHAFT FOR MY STICK CAR , IT PULLS PRETTY GOOD TOO, THE PROBLEM IF I REV THE MOTOR HIGH, THE 2ND GEAR WONT ENGAGE, SO I THINK FONNA TRY TO FINE TUNE WITH STEEL BUSHINGS, AND MAY BE DO SOMETHINK LIKE YOU DID....IF NOT THERE IS ALWAYS TH400 WAITING...LOL
Old 09-19-2011, 02:03 PM
JoePapa's Avatar
If you can't get it to go into 2nd gear at RPM then maybe your clutch adjustment is wrong or your syncro's arn't grabbing properly. Are you running synthetic or regular gear oil?
'69 Firebird 400
Old 09-19-2011, 05:55 PM
Default linkage muncie
JOE PAPA----THE TRANS WAS REBUILD..HAS LESS THAN A MILE ON IT...I THINK THE PROBLEM CAN BE THE NYLON BUSHINGS IT HAS, SO I AM GOING TP BUY A NEW SET OF BRONZE--STEEL BUSHINGS, SEE IF THAT WILL HELP...THANKS FOR YOUR IMPUT BRO-->>>JOE
Old 09-19-2011, 05:57 PM
JOE-PAPA.....I FILLED THE TRANNY UP WITH REGULAR GEAR OIL IF I RECALL---DO YOU RECOMMEND SYNTHETIC??
