Old 10-09-2011, 01:22 PM
TEMPERMAN67 TEMPERMAN67 is offline
Default Msd pro Billet Distributor caps
Has anyone had a problem with the distributor caps getting
corrosion on the inside terminals?
Old 10-09-2011, 01:29 PM
ry57pont's Avatar
ry57pont ry57pont is offline
mine always look like crap, i also had the washers on the rotor split into about 6 pieces.
1970 gto (4spd) 462 500 hp
[email protected] / 1.843 60'/ 3980 lbs
1964 corvette roadster
1968 corvette roadster
1962 corvette
"equal rights, not equal things"
if you want to know the future, read "atlas shrugged"
I dont race a 4spd because it is easy, I race a 4spd because it is hard.
Old 10-09-2011, 01:44 PM
Yea,well mine gets a skip to it in the higher
RPMs, then I can clean it and scrape
The corrosion then it's runs great.
Didn't know if there was a cure or not.
Old 10-09-2011, 02:05 PM
455firebird1969's Avatar
Yeah, happens all the time...
Yesterday mine developed a slight miss when I was warming the car before time runs. I cleaned it with 600 grit sandpaper. After doing that, on the first time-pass it ran like a raped ape. The car ran awesome all night, made 9 passes in all, two time runs and seven eliminator rounds...
The MSD reluctor will corrode and the cap & rotor will show arc wear, 600 grit works on both...
After having to clean the cap several time, I'll replace the cap & rotor, and start over...
Old 10-09-2011, 03:28 PM
TinInjun's Avatar
TinInjun TinInjun is offline
Location: American by birth, Southerner by the grace of God
John, my first cap and all of the internals of the distributor had surface corrosion. MSD has added a vent to the top of the new caps. Don't know if this helps as I haven't had my cap off this year.
Less said,,,,,,,, Less mended.
Old 10-09-2011, 03:53 PM
bryansMtngto's Avatar
bryansMtngto bryansMtngto is offline
Default terminal corrision
yea just think of it as normal maintaince. I check my terminal about once a month specially with the humidity we get here in the midwest. I've started carring a a spare or 2 in trailer so i can just swap them out if i feel a need and clean it after rounds are done. keep them in vac. sealed bags. Can get them at grocery store with a little hand vacuum pump work great.. For parts and Meat!!!!
Old 10-09-2011, 04:20 PM
Thanks George, both of mine have the
Vents, but still gets corroded on them.
Hey Axle Chuck and I are going to SGMP
On Saturday for the Havok race you and
George ought to check it out on their
website.
Old 10-10-2011, 08:14 AM
You can put a touch of dielectric silicone on them and the tip of the rotor and it will help. Just dont gob it on there.
Old 10-10-2011, 08:32 AM
Looks like a good event John, have fun and good luck...
Tell Chuck, and your Dad I said hello...
Old 10-10-2011, 11:23 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
I went back to the MSD caps because they are vented. Didn't cure the corrosion issue though. Last time I cleaned mine was before Norwalk, started to act up again so she be getting some attention this week. I sprayed a light coat of WD-40 on the distributor internals, then wiped down any excess.
Old 10-10-2011, 12:33 PM
cgeise's Avatar
cgeise cgeise is offline
If you have room - the large cap with the cap-adapt system works better
Old 10-10-2011, 01:09 PM
Region Warrior's Avatar
Region Warrior Region Warrior is online now
2nd that.
Old 10-10-2011, 02:23 PM
60man's Avatar
60man 60man is offline
Agreed....but no can do with Wenzler tunnel ram ...
Going to try the dielectric deal next clean job...It's Sun Tuned endorsed !
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 10-10-2011, 02:24 PM
60man's Avatar
Can it be used on the pick up ??
ECM member.
MANDRA
Old 10-11-2011, 07:47 AM
Sure.
Old 10-11-2011, 12:34 PM
Vince GTO's Avatar
Vince GTO Vince GTO is offline
I just drill an extra vent hole has worked fine for the race car but i would not do this on a street car.
Vince
Old 10-12-2011, 05:04 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
I was having problems with mine as well msd sells a adapt a cap for the pro billet that lets you run a ford cap.I had no further problems after the swap.
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 10-12-2011, 06:22 PM
67cruiser 67cruiser is offline
Every cap be it any Bran MSD OR stock HEI ive drilled at least 3 holes into the cap between terminals, i never had any corrosion at all so far, ok start out with a pilot hole 1/4 inch and go to 3/8, i would not be afraid to put 4 or 5 holes in the cap.Before anybody asks me yes around perimter or o.d. of cap not on top!!
Old 10-13-2011, 09:49 AM
PONTIAC DUDE's Avatar
Red face
Todays High voltage ignitions + humidity + inclosed non vented area = corrosion.
I used to drill a small hole in the side of the cap. Was recommended back in the day by MSD & Accel.
