Old 10-02-2012, 09:10 PM
TomMcCrea's Avatar
TomMcCrea TomMcCrea is offline
Last week I called a parts warehouse I used to deal with and asked if they would check old catalogs for part numbers. I was told that the rebuilder's common number for the Tempest shoes is 193 which they have not stocked or sold for many years. I had no luck in finding 193 shoes anywhere.
I am in the process of rebuilding my wheel cylinders and installing 189 Corvair shoes. Since the cylinders have some pitting, I will probably go enough oversize that the pistons will be too loose, in which case I will make some new pistons.
Old 10-02-2012, 09:13 PM
GaryK's Avatar
GaryK GaryK is offline
Originally Posted by slowride66 View Post
Hi I know this is a old thread but.
I called the Auto Zone & theey said 4 cly was unavailable but for the V~8 they are .
Rear Shoes.
Is there a difference from 4 to 8 cly? & can you direct me to the information
Thanks So very much
SR66
It has been discussed here before, they will not fit. You will not be able to get brake shoes from any local auto parts store. Call Ames.
  #43
Old 10-02-2012, 09:34 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default Tempest brakes
I purchased a complete set of brake shoes from a business called Pacific Brake Bond Inc.
The part number was 2069-193. They measure 9" diameter X 1 3/4" width. Eight shoes cost $90.00 with no cores. They are on my car and work fine. Talk to Warren at PB Brakes, 605 E. Garvey Ave. Ste. B, Monterey Park, CA 91755-1984. Hope this helps answer the question of where to find brake shoes for our Tempests!
  #44
Old 10-04-2012, 09:35 AM
GaryK's Avatar
Thanks C5 - That is a great deal! Based on the name of the company, I am thinking these are bonded, not rivited. Am I correct?
Gary
  #45
Old 10-04-2012, 10:52 AM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
Sometimes you can find some NOS brake shoes on ebay. I found some for our 61.
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
66 GTO Conv 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
  #46
Old 10-04-2012, 06:43 PM
c5farmer's Avatar
Default PB brakes
The PB brakes are bonded, and use heavy duty lining material. The brake shoes are original #-193 Tempest pieces. I don't worry about modern bonded brakes because they are made with bonding material that is much better than the glue was used in the "old days".
  #47
Old 10-04-2012, 07:34 PM
mechanickeith's Avatar
mechanickeith mechanickeith is offline
I only run bonded brakes. I had a couple of times my brakes wore down to the rivits. Didnt hear any noises. By the time it did make noise, the rivits had grooved the drums so bad they were unservicable.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
  #48
Old 10-07-2012, 08:52 PM
slowride66's Avatar
slowride66 slowride66 is offline
Hey Y'all
Thanks for the great advice.
Keepyou updated
SR66
SLOWRIDE "take it easy"
https://www.robharleydetailer.com/
I'm not prejudice, I hate everyone Equally.
The best proof that there is intelligent life in outer space is;that they haven't made contact
  #49
Old 10-13-2012, 12:16 PM
TomMcCrea's Avatar
Yesterday I installed a set of 189 shoes on the rear of my '63 and found that they would not seat on the top pin. The problem was the parking brake strut being too long so I had to cut the notch a little deeper. This was done with both struts sandwiched in a vise so that they would be equal side to side. I tried the original push rods and found that the pistons were at the edge of the bore so the longer ones were installed.
Another modification being made is the use of non-stock rear hoses. Since I am replacing all the steel lines, I figured I could make the ones from the hose to the wheel cylinder a little shorter and used longer hoses. A front hose will work fine on the LH side and I found a 10" hose for the 1958 - 1960 full size cars with two female ends for the RH side. This is NAPA number 26960. I have fabricated to brackets to attach the hoses to the lower control arm, all this because I am too cheap to pay $30 -$45 each for custom hoses.
