Old 01-11-2013, 09:12 PM
GTO's Avatar
GTO GTO is offline
You're ruining a good thread here! Get another room! LOL!
Runner Up Q16 Norwalk 2013!
  #382
Old 01-11-2013, 09:54 PM
Originally Posted by john marcella View Post
F-that, bring it. What ya got?
Sorry John cant knock a guy with a nice silver blue 68 Firebird.
A few pics of my cruiser just before I sold it 10 yrs ago. At the time I thought it was too nice to make a race car out of... talk about take back moments...It could have made a great race car and I'd be done building by now...damn.
ID:	309319   Click image for larger version
ID:	309320   Click image for larger version
  #383
Old 01-11-2013, 10:20 PM
blueghoast's Avatar
Originally Posted by Jeff Kinsler View Post
When i spun the tires.
Just teasing ya LOL
Can't take nothing away from you guys for the performance level
you guys are at. Even that farmer guy with the red lemans 8-flat
on the juice Lmao.
8-Sec cars are Bad Ass. 7's too.
GT.
  #384
Old 01-11-2013, 10:45 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Originally Posted by mike leech View Post
You gonna go boating with dino?
I always new you were a smart one Mike
[email protected]. 3460#s
  #385
Old 01-11-2013, 11:10 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
I dont check in for a few days and next thing you know someone farts in my thread and a fist fight breaks out. Cant leave you guys alone for a minute ��
I am still at work but will post in a few
  #386
Old 01-12-2013, 02:38 AM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
... LMAO !!! ...
  #387
Old 01-12-2013, 11:00 AM
That was a real nice F-Bird, Bruce.
Tom Vaught
  #388
Old 01-14-2013, 12:06 AM
Since the 11 degree heads arrived here we had planned to offer a CNC package complete ready to bolt on. We are still on that track. We plan to use Reher-Morrison to accomplish the CNC work. In addition these ports/chambers were developed in consultation with Darin Morgan.
Targets:
Flexible design allowing use on CID ranges 440 – 541
2.300” – 2.350” intake dia; 1.650” – 1.680” exhaust dia
300ft/sec through intakes at .600” lift with 2.300” valve with minimal velocity gradient
Small, fast burn, efficient chamber (approximately 50ccs)
Intake port size and location allow use of cast intake manifold; Victor, BOP and Tiger.
3.20 sq inches minimum but with additional porting can reach 3.60 sq inches.
Shaft rockers with approximately .600” - .700” offset on intakes
Short valve length for minimum weight (stainless or Ti valves)
History:
We delivered a roughed out intake and exhaust port to Darin back in January ‘12. He liked the intake but worked a few hours on my exhaust. Chambers are right at 50ccs. He used a 2.300” intake, machined 45 degree seats and reported some very nice flow figures. We made the decision to go final and trace them. He called me a few days later and said that he had discovered a problem with the bench so the numbers were off by a few percent but did not have any new flow numbers. The heads were in line for tracing and he would flow them after they came off machine…and we would need to develop a different exhaust port for the end ports. Well…time went by and finally Norwalk ‘12 was here but not the heads so one of our crew picked them up on his way so we could show the progress. They were unboxed in Lenders lot on that Wednesday. When we got back here I worked on the end exhaust port and then returned them to Darin for tracing and cutting…they are still there. He told me a few days ago the CNC machine is down. No need to post flow numbers we have to make excuses for later.
Manifolds:
Head velocity is excellent and will support use of larger manifolds namely BOP or Tiger intakes. Both are great options with a good beginning runner area and plenum volumes for higher RPM/larger cubic inch applications. Also we wanted to maximize manifold choices so the port size/shape is within the Victor casting (might have to weld the bolt recess on the end ports) and possibly the Northwind casting (but do not have one to try at this point.) Tiger will require milling of manifold and head but it will be a great choice.
Pricing:
Working on pricing and we will be very competitive with other offerings.
Availability:
Working on ‘em… A very nice build is in progress with these and will post as info is available.
ID:	309656   Click image for larger version
  #389
Old 01-14-2013, 01:16 AM
cgeise's Avatar
cgeise cgeise is offline
ty for the update
  #390
Old 01-16-2013, 09:12 AM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Talking
Jim. Keep us in the loop. Will be nice to see some finished ports.
  #391
Old 01-17-2013, 01:29 AM
potent,
Wish I had taken more pics to show the CNC work thus far. Looking forward to the final product as they are showing much promise with the sizes, shapes and flow volumes. Thanks to all for your interest.
  #392
Old 03-19-2013, 01:41 AM
Some progress...at least they are back in our hands for the next phase.
If you read some of my earlier posts we ran into an issue where the end exhaust ports required a totally different port than the center exhaust ports. Now a standard o port header flange will line up nicely even though Edelbrock moved the valve centerlines.
ID:	316774   Click image for larger version
  #393
Old 03-19-2013, 02:24 AM
john marcella john marcella is offline
Wow you are thin between the intake ports at the flange. <<Not knocking , just saying.
How thick are you to the machining for the plug socket? <<This spot really pissed me off.
I had to weld the tops of ex ports at the flange because there was not enuff material to even seal up a 2 inch header , with bolt holes in the stock location.
Just went after my heads agian, ported the whole dam things all over agian.
John Marcella
Marcella Manifolds Inc.
[email protected]
ph. 248-259-6696
  #394
Old 03-19-2013, 11:20 AM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
Looking good Jim,
Any worries on plenty of material left for cycle durability? Or is there still lots of meat left? Max effort VS durability...
John
PS
On a different note finally got the Goat going... Maybe I can get to the Lemans next...
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
  #395
Old 03-19-2013, 09:30 PM
John M, The divider wall in the intake port is progressively thicker as you move closer to the head bolt. We will mill the intake flange on the head approximately .500" (I believe you milled yours also) and thus we will end up with about .160" of divider wall thickness. We will run the Tiger intake with this set...plus we are looking at milling about .250" from the flange of the manifold for proper fit. And yes we were thin at the spark plug access hole on the end ports so we added some material before tracing to allow adequate thickness in the cnc ports. Test port was then welded and smoothed. Looking at exhaust flange thickness at the roof of the exit for some possible material add there.
John K, How goes it? No structural issues with these. Darin has studied and measured these and gave the thumbs up so we went forward. Looking forward to seeing your Lemans out and about...
  #396
Old 03-20-2013, 12:35 PM
cgeise's Avatar
Can some one explain what Manifold is "SUPPOSED" to fit the Pro port, untouched? Is it a Victor ?? .500 off the head and another .250 off the intake is a lot. Anyone know if Edelbrock is working on a Manifold for these heads. As I type this I remember the thick plates I had to use back in the day so the victor would fit the Tigers -- I dont remember how thick it was though -
  #397
Old 03-21-2013, 12:40 AM
In post #4 and #388 I show a mock up of a Victor intake on the pro ports on an IAII block. The bolt holes line up nicely. Thus the reason we tried to keep our ports within the casting of the Victor. The BOP will also "fit" between the heads and bolt holes will line up (depending on the bolt hole option you get from Wade). When attempting to test fit the Tiger intake to these heads, the Tiger runners are longer resulting in a different flange position. Basically the Tiger intake fits the Tiger heads. We found about .750" will need to be removed from Pro ports, Tiger intake or a combination of both. Since the Pro ports have a massive flange we chose to mill most of the difference from the there. The flange on the Tiger intake is approximately .450" thick so removing .200" or so is no big deal. We studied both the BOP and the Tiger intakes and for this set we chose the Tiger.
  #398
Old 03-21-2013, 11:58 AM
cgeise's Avatar
thanks
  #399
Old 10-27-2016, 12:12 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
any updates
  #400
Old 10-27-2016, 01:11 PM
cgeise's Avatar
to date it is my understanding that Edelbrock has discontinued them
