Old 04-21-2013, 08:31 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Originally Posted by Hooter View Post
Par for the course, my dyno session now bumped to the following Saturday. I swear I'm gonna make it out this year......
did you ever get the engine with and i quote from greatgto "the best e-heads out there" to the dyno?
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #122
Old 04-21-2013, 09:39 PM
Rob B's Avatar
Rob B Rob B is offline
He dyno'ed it saturday and already has it in the car. I'll let him post his results.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
  #123
Old 04-21-2013, 10:10 PM
cool!!
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #124
Old 04-22-2013, 06:55 AM
Hooter's Avatar
Hooter Hooter is offline
The motor made 838hp at 6800 and 709ftlbs at 5300. This was with no vacuum pump(had issues with it) and running too thick oil(100 psi oil pressure). This motor was not built as a max performance piece, but more for durability. It only has a 770 lift cam(std journal)and the compression is under 13:1. I'll run 110 fuel(cheap and readily available), not turn it to the moon, and hopefully have long head gasket life. The motor is in the car already and I'm calling about getting the converter restalled today. With the addition of the vacuum pump and lower oil pressure, I'd like to think it should pick up another 25-30hp conservatively. Hoping to get it in the 8's this year, but more importantly just make some laps with our nostalgia group and have some fun.
67 Bonneville ragtop
  #125
Old 04-22-2013, 07:27 AM
mysticmissle's Avatar
Hooter would you mind, reminding us of the engine displacement and head flow?
  #126
Old 04-22-2013, 07:32 AM
Hooter's Avatar
535 and I believe the heads flowed close to 400 at 0.800.
  #127
Old 04-22-2013, 08:03 AM
60man's Avatar
60man 60man is offline
Cool...good power.. I'm with you Brad on lower CR........My next build is going up in cubes(541) & down in CR !! This 14.58 CR is more than I want to deal with.....never had gasket issues at 13.5...
Good luck on 8's...
CYA at Norwalk...
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
  #128
Old 04-22-2013, 08:59 AM
Where was peak torque? Victor intake?
  #129
Old 04-22-2013, 09:01 AM
Kevspontiacs@aol.com's Avatar
[email protected] Kevspontiacs@aol.com is offline
hogan sheetmetal i believe
  #130
Old 04-22-2013, 09:04 AM
Rob B's Avatar
I think it was a Preformer RPM....
  #131
Old 04-22-2013, 09:15 AM
Hooter's Avatar
Peak torque(709) at 5300. It's Larry Quinns old Hogan intake with Edelbrock AFB's that's designed to look like a old bathtub SD intake.
  #132
Old 04-22-2013, 09:18 AM
Cool that's with dual quads nice. Gd luck and thanks
  #133
Old 04-22-2013, 09:21 AM
Hooter's Avatar
Thanks. We can now run Holleys in our class, but I don't have the funds to switch over this year. Will run the AFB's and see what it does at the track.
  #134
Old 04-22-2013, 09:24 AM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Well, it looks like the best E heads ever made are close to 200 HP shy of King Kinsler's E heads.
I wonder if Jeff would have ran in the 8s with a set of those heads?
Sorry Hooter, all the best to you.
[email protected]. 3460#s
  #135
Old 04-22-2013, 09:26 AM
LiL Jack's Avatar
Good luck on 8's...
CYA at Norwalk...
My compression is close to that and I am on nitrous and can go 25 passes on a set of head gaskets.
King Kinslers were more then that and he runs a whole season with his.
  #136
Old 04-22-2013, 09:35 AM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Glad you were finally able to get things moving hoot. Let me know when you are ready to hit the track
  #137
Old 04-22-2013, 09:41 AM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Hooter, glad to hear that you'll be back out on the track. Nice numbers too !!
Old 04-22-2013, 11:46 AM
Region Warrior's Avatar
Dam.
Thought you where talk'n bout the engine for the 65 other nite
Forgot to ask, how Arnies sound?
  #139
Old 04-22-2013, 12:05 PM
60man's Avatar
Holley's were worth 43 HP over my AFB'S/Comp. 750's on a Gutsram 2x4.
ECM member.
MANDRA
  #140
Old 04-22-2013, 12:40 PM
WOW!!!
