Old 04-25-2013, 08:11 PM
Originally Posted by russ467 View Post
How much bigger is the snout diameter on the crank to withstand that much force from the procharger?
I'm guessing the set up he has also acts as a crank support. If so, a Pontiac snout is fine.
Old 04-26-2013, 07:21 AM
bad69bird's Avatar
bad69bird bad69bird is offline
Thanks Brian, will look forward to it, as usual!
All of my previously Steve Morris dyno time was based on F-3 139 unit. Never really saw a 135 unit run. I also have heard that the new 136 had a lot of potential. Think that Procharger HAD to step up after Chris Alston jr ran quicker with a crank drive Vortech Supercharger in the Nova vs the F3-139 unit they previously used.
Hope to see the car/engine at Norwalk in August.
Tom Vaught
Tom that's the goal is to have the car at Norwalk.
Russ I believe it is the standard pontiac snout. I know mine is. I replaced mine after 300 passes on it because upon inspection by Moldex (crank was in there to be cut and inspected) they discovered that there were a few stress fractures around both keys (it is dual keyed for the supercharger). They cut the snout off and replaced it with another one. When I spoke to Joe he said he thought it was from peddling the car and the stress it puts in that area. My understanding is that the pontiac snout actually isn't a bad snout to have (go figure for once its not a bad thing to have a pontiac. LOL) because the snout size is slightly smaller than a BBC but bigger than a SBC.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
Old 04-26-2013, 07:23 AM
bad69bird's Avatar
Scott if I had to take a SWAG, I'd say it does too.
