Closed Thread
Old 06-30-2013, 08:52 PM
lemans411's Avatar
lemans411 lemans411 is offline
Originally Posted by LiL Jack View Post
So if it doesn't make 1K HP and be the first CV1 motor to make 1K HP it won't be sweet?
if that thing doesnt make 1k hp i'd light it on fire! lol
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
  #62
Old 07-01-2013, 10:19 AM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
... LMAO ...
  #63
Old 07-01-2013, 11:56 AM
... well guys, unfortunately i have seen that the resident moron on PZ which would be Goober () is now claiming the valves in my CV-345/RacePlate heads for this 572 have had the valves moved to a different location ?? ...
... incase anyone gives that man an ounce of credit (which i hope they don't) i am simply setting the record clear, the valves in these heads for the 572 have NOT been altered or moved in anyway shape or form, and they do run the max-offset we can run with the CV-1 cylinder head ...
... i'm sure there are many that aren't up to speed with how he runs things on that forum, and we don't want his lies being taken as fact concerning this engine and it's parts ...
... back to topic, sorry ...
  #64
Old 07-01-2013, 12:28 PM
mike leech's Avatar
mike leech mike leech is offline
Good info Bill.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #65
Old 07-01-2013, 03:53 PM
You are implying that the valves have not been moved/changed from a stock CV-1 head diameter and position that are out on the street currently?
You just posted that the "have NOT been altered or moved in anyway shape or form, and they do run the max-offset we can run with the CV-1 cylinder head"
So which is it, "not moved" or "moved to max offset position" and are not a different diameter? Help me out here.
Tom Vaught
  #66
Old 07-01-2013, 05:21 PM
Tom Vaught
... i'm not implying, i stated that the valves have NOT been moved in this head, (or any other CV-1 combo for that matter, ReTool head included) meaning the guides are still in the standard CV-1 location, meaning, not moved at all, diameter is not relavant to location of the valve over bore center ...
... the Max-Offset is referencing the pushrod location through the head, meaning we are at the maximum amount of OffSet we can use in this head, hence the offset shaft rockers and offset Keyed lifters in the photos ...
  #67
Old 07-01-2013, 05:47 PM
bankbook's Avatar
bankbook bankbook is offline
Looks like you spent alooooot of time polishing your crank-Jerkey!
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
  #68
Old 07-01-2013, 06:03 PM
J.C.you's Avatar
J.C.you J.C.you is offline
If a guy bought a set and moved the valves around, for instance where his builder wanted, or you did a set with modified valve angles, what difference would it make?
Bill, NO one listens to gomer.
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
  #69
Old 07-01-2013, 08:11 PM
tiacguy's Avatar
tiacguy tiacguy is offline
[QUOTE=Tom Vaught;4963640]????????????
Tom Vaught
In the out of the box head the pushrod passes through a small groove cutout past the intake port. By moving the pushrod over (offsetting)this groove can be welded up to utilize all the ports realastate. If Im understanding Bill correctly.
  #70
Old 07-01-2013, 08:15 PM
lemans411's Avatar
Tom Vaught
Aren't you an engineer? Lmao I'm just a lowly dealer mechanic and I took that as valves are in stock location and they are using the maximum offset rockers and or lifter that they safely can run. Its written in English lol.
-Rob
68 gto
  #71
Old 07-01-2013, 08:42 PM
I was just trying to get a clarification on what he posted. He posted that the guide position and angle did not change if I read his post correctly. So I have my answer.
Yes I am a engineer with 35 years experience doing engineering work on boosted systems, I am not a valve-train engineer so I ask questions. So you assumed that was what he meant.
I asked what he meant, I got an answer, big difference.
If you assume stuff in engineering typically it will bite you in the ass down the road.
Tom Vaught
  #72
Old 07-01-2013, 09:16 PM
lemans411's Avatar
Tom Vaught
I'm glad you got your clarification. It just seems like you we're trying to make something out of nothing that's all. But... what do I know I'm just a dumb mechanic.
-Rob
68 gto
  #73
Old 07-01-2013, 11:11 PM
Don't give me that crap, I worked in my uncle's Pontiac dealership every summer for 3 years on the floor as a line mechanic. Some of the smartest people I have met were line mechanics. Smart means little if you can't apply it, so I am not buying your excuses.
Tom Vaught
  #74
Old 07-02-2013, 12:22 AM
lemans411's Avatar
Tom Vaught
Lol I'll take that as a compliment. No excuses just not claiming to be a genius that's all. Not my prerogative I guess.
-Rob
68 gto
  #75
Old 07-02-2013, 12:31 AM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
I think I would pay cash money to see you post a picture of that monster motor bolted to a slim jim.
65 Bonneville Brougham 4DHT
65 Grand Prix 2DHT......now parts
65 Catalina 2+2 2DHT
65 Catalina Safari 4DSW
  #76
Old 07-02-2013, 10:11 AM
... slim jim ? ...
... but I might consider cutting off a finger to have it in my Camaro right now !! lol ...
  #77
Old 07-02-2013, 12:17 PM
I work with a lot of very high IQ people every day in Research.
That does not make me one. I just work with them and harder than some of them.
Tom Vaught
  #78
Old 07-02-2013, 12:36 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
Wink
Looks, works and runs the same are two different things!
That goes for just about every Carb builder out there, they all have different ways.
That main body looks like it comes from Bo Laws.
Dave Polichena
  #79
Old 07-02-2013, 12:51 PM
Dave, Bill says that he makes them himself, (or at least he implied that).
Tom Vaught
  #80
Old 07-02-2013, 01:06 PM
cgeise's Avatar
cgeise cgeise is offline
Im so confused - A tunnel ram on a street head ?????????
Closed Thread
