Old 12-07-2013, 10:21 AM
andyprice andyprice is offline
Default '65-'66 Rear Axle Interchange Question
I always thought that big-car rear axles were essentially the same from '65 to at least '70, but recently had someone tell me that a '66 axle is wider overall than a '65 axle. Doesn't sound right to me. Can anyone shed any light on this? Thanks!
Old 12-07-2013, 11:07 AM
Deadhead's Avatar
Deadhead Deadhead is offline
Same. Check the other threads in archives. Entire assembly is identical '65-6. Axles will pull out and stick in to either one. '65-70 internals swap except for '69 GP.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
Old 12-09-2013, 01:06 AM
70ra455's Avatar
70ra455 70ra455 is offline
same ...
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console
1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats
2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather
Old 12-09-2013, 10:53 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Yep 65-66 direct swap.. 67, 68-70 housings vary. gears swap freely 65-70 though
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 12-09-2013, 12:01 PM
Rapdron's Avatar
Rapdron Rapdron is offline
Thumbs up Rear Axles
Hi Larry
Not trying to hijack this thread, just wanted to thank you for the lead on the 3.08 posi carrier & gears.
Worked out GREAT
Thanks, Ron
Another Red Light Nightmare
1966 Martinique Bronze 2+2 428 tri-power auto, black top & bucket seat interior, pass recliner, ATC, Cruise, AM FM, Reverb, Wood wheel, tilt, ps, pb, pw
1966 Catalina, Barrier blue with a white vinyl top, tilt, AC, ps, pb, bucket seats with console 68 428 4 bolt, 4 speed M20 and a 66 tri-power project.
Semper Fi
The Following User Says Thank You to Rapdron For This Useful Post:
Old 12-10-2013, 02:56 PM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
FWIW: the pinion seal shows a different part number for the 65 and the 66 to 70. I've never compared the seals to see if there is a machining difference in the carriers or not...
65 Bonneville Brougham 4DHT
65 Grand Prix 2DHT......now parts
65 Catalina 2+2 2DHT
65 Catalina Safari 4DSW
Old 12-10-2013, 06:44 PM
Heybuck's Avatar
Heybuck Heybuck is offline
That's interesting. I pulled the 3.23 open rear out of my '66 GP and installed a 2.56 POSI out of a '65GP.
The pinion seal started to leak some time later and my diff guy was having difficulty getting a seal. I would assume he was looking for a '66 seal and I never told him it was a '65 diff. He eventually solved the problem but its something to keep in mind for the future.
Ian
To laugh at men of sense is the privilege of fools.
The Following User Says Thank You to Heybuck For This Useful Post:
Old 12-10-2013, 08:21 PM
Bill Hanlon's Avatar
Rock Auto calls for SKF 19310 for '65 and SKF 19273 for '66. They are definitely different. Here are the specs:
http://www.rockauto.com/catalog/more...228&cc=1350234
http://www.rockauto.com/catalog/more...254&cc=1350111
The Following User Says Thank You to Bill Hanlon For This Useful Post:
