Old 01-23-2014, 11:12 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Default Good news from the machine shop today
Finally got the call I was waiting for from the machine shop where I dropped off my engine. He said everything looks excellent! All of the oil galleries are clean. The crank is in great shape and doesn't need to be turned. So I ordered my new bearings today all standard size. Also all of the cylinders measure at 0.001" taper. My deck height is currently at 0.020 and he will deck it to 0.005. Also all of the pistons look like new. All he has left to do is deck the block, polish the crank and brake the glaze on the cylinders.He said he's going to try to have it all finished by the end of next week. The only thing I need to get yet is a new dipstick tube. I'm going to order the stainless steel one from our host.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/[email protected], .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 01-23-2014, 11:58 PM
66bonne's Avatar
66bonne 66bonne is offline
Happy happy happy.
Jim
Old 01-24-2014, 12:00 AM
67gtospud's Avatar
Yes! Lol he had called and asked if I could stop by the shop; I was expecting the worst. But I was looking at all the old bearings while he was dealing with a customer and everything looked great.
Old 01-24-2014, 12:18 AM
Firebob's Avatar
Firebob Firebob is offline
How much is a polish of the crank?
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 01-24-2014, 12:28 AM
67cruiser 67cruiser is offline
Not to sound, well,crazy but just how can he tell if oil galleys are clean unless he removed the front & rea plugs???
Old 01-24-2014, 01:57 AM
67gtospud's Avatar
He did remove the front and rear plugs.
Old 01-24-2014, 01:58 AM
67gtospud's Avatar
With all the work and labor my total is 300 so for just polishing the crank I'm not positive.
Old 01-25-2014, 09:01 AM
67gtospud's Avatar
I ordered a stainless steel dipstick tube from our host yesterday so I should have everything I need by the time my block is done. I will be doing reassembly and am wondering If I should use blue lock tight on the threads of the rod studs upon reassembly?
Old 01-25-2014, 09:17 AM
Machine Shop Bill like that means a 1-piece oilpan gasket from Butler's sounds affordable.
Old 01-25-2014, 10:31 AM
67gtospud's Avatar
I thought about one but seeing as how I'm well over on an already tight budget I'm going to use the complete gasket set I already have. I do however need to get another set of valve cover gaskets since I'm adding a valve cover spacer.
Old 01-25-2014, 10:33 AM
make sure you run a good oil pump 60 psi.
Old 01-25-2014, 10:58 AM
Torquewar's Avatar
Torquewar Torquewar is offline
Nice to hear good news on a tear down and a fairly simple reassembly.
The one piece gasket is really nice but with some patience the stock type stuff will work. I really like to use Permatex (Right Stuff) seals very nice.
I personally dont use any thread locker inside a motor. If everything is clean and threads are straight then use a good calibrated Torque wrench and your good to go.
Old 01-25-2014, 02:39 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Cruiser, you sure seem to have a thing about oil galley plugs not being removed. It seems as though any thread having to do with oil galleys, you accuse shops[myself included] of not pulling oil galley plugs out. You obviously have had a bad experience in this area.
Spud, don't use Locktite on your rod bolts/nuts. If you have ARP bolts/nuts, then use ARP Ultra moly lube. If using stock bolts/nuts, use 30 weight motor oil. Torque them to specs, then go over them after they are all torqued down. None should turn anymore before reaching torque. If they do, they are stretching and need to be replaced. If the bolts/nuts come loose, it wasn't because you didn't use Locktite, but rather because they were not torqued down.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
The Following User Says Thank You to gtofreek For This Useful Post:
Old 01-26-2014, 01:04 AM
67gtospud's Avatar
I will be using the stock studs and nuts for the rods as well as stock bolts for the heads and mains. Will 10w-30 be alright for lube as that is the weight I will be using for oil.
Old 01-26-2014, 02:16 AM
Squidward's Avatar
Squidward Squidward is online now
Congrats! I love to hear a happy shop story!
Old 01-26-2014, 01:27 PM
gtofreek's Avatar
10-30 would probably be fine.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 01-27-2014, 10:55 AM
67gtospud's Avatar
thanks! im looking forward to some official forward progress lol
Old 02-02-2014, 08:41 PM
67gtospud's Avatar
I got the block back Friday. Saturday afternoon I received the new dipstick tube from our host. I wish it would've been a tighter fit than it was but with a little high temp rtv it went in snug. Double checked all of my oil clearances on rods and mains and all are 0.0015-0.002". The rotating assembly all went together smooth as did the windage tray, lower dipstick tube and oil pump. I'm still waiting on my cam and lifters which I'm not too happy about as its been just over 2 weeks now. So since I'm waiting now I went ahead and bagged the engine where paint should no go and primed and painted it and set the already painted parts on the block and everything looks great. So I guess I'll update again once my cam and lifters arrive
Old 02-02-2014, 09:36 PM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
Awesome! I always liked that part of the build. Getting new paint on the block and seeing how its gonna look. Grats!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 02-02-2014, 09:48 PM
67gtospud's Avatar
Thanks! It's finally a part of the car that's coming together
https://www.dropbox.com/s/jmp9bhct3nu4gx3/IMAG0019.jpg
https://www.dropbox.com/s/y5b3kx9709d69bn/IMAG0020.jpg
