Old 03-02-2014, 02:38 AM
transam1972 transam1972 is offline
Default RH DUCT REMOVAL
one last thought BOB,..you may need to loosen up the entire duct if the right side one is hard to get out..as it fits inside the center one and connects to the right hand dash vent...I probably pulled all 3 pieces at once but I would try to remove just the problem one first and see how well it goes...if I recall 1972 drivers side with a/c is unique..possible that is one year only and it changed to a different design
  #342
Old 03-02-2014, 07:49 AM
Bentwheelbob's Avatar
Originally Posted by Pepi View Post
Here is where I discussed the issues I had with the reproduced duct along with photos. Nothing lines up at all.
http://forums.performanceyears.com/f...op+duct&page=2
Pepi - Can't get the link to work. Can you check it and repost if possible.
Glenn - thanks for your suggestions.
  #343
Old 03-02-2014, 09:03 AM
Held for Ransom's Avatar
http://www.forums.maxperformanceinc....d.php?t=689157
Page 2.
  #344
Old 03-02-2014, 09:37 AM
njsteve's Avatar
njsteve njsteve is offline
The main, right hand duct was a horrible design. Believe it or not, that was the nicest duct I have seen in a while. The factory molded in a half circle area on the front that employed two star washers and two long screws to retain it in place. But since it is internally unsupported and there is a 1/2" gap between the top and bottom, the moment the screws were tightened, it crushed and shattered the surrounding ABS plastic. Unless you can slide something inside that area and glue it in place to support the outer flange area, there is no way to fix the existing problem. I can't remember, but I may have done that with the duct on the black car.
The ducts don't seal well together to begin with since all the foam stick-on insulation long since turns to dust. Home Depot/Lowes sells really inexpensive stick-on door seal foam tape in various sizes that works well to reproduce the original duct-to-duct seals.
Even the SD I now have has cracks in that same mounting area, And I was the first person to ever remove it when I replaced the original heater core last Fall.
  #345
Old 03-02-2014, 09:42 AM
njsteve's Avatar
Removing the right kick panel is nearly impossible with the heater core in the car due to the depth of the internal duct that contains the air flow door and diaphragm. There is also a large amount of factory installed, tan, body dum-dum that seals it into place that you have to wrestle with.
I had to review my old photos and it looks like I never removed that right kick panel when I did the heater core.
ID:	355143   Click image for larger version
  #346
Old 03-02-2014, 10:51 AM
MPD wanted me to tell you this thing has more duct tape than his race car used to have at the end of a long weekend.
Console out, glove box out, duct out, kick panel still hanging in.....It's not giving up easily.
  #347
Old 03-02-2014, 10:55 AM
Pepi's Avatar
Pepi Pepi is offline
Thanks HFR, I don't know why that link didn't work, I copied from another posting, must have missed something at the very beginning or end.
Yes, the one HFR shows is it on page 2, I clicked it and went to page 2 then copied it so lets see if this works...
http://www.forums.maxperformanceinc....=689157&page=2
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #348
Old 03-02-2014, 10:59 AM
Pepi's Avatar
Yes, if they would have filled in the duct area where the screws go so you cannot compress it, they would not crack. That is where if someone would make a good repop'd duct that actually fits and lines up, then improve on the design and fill in that area. That would be awesome.
  #349
Old 03-02-2014, 12:37 PM
njsteve's Avatar
LOL. I used the black duct tape to seal up the outside of the duct connections at each flange when I was getting the A/C system up and running. These cars always had bad air flow to the upper A/C ducts in the dash. I was trying to improve the flow and reduce the air flow leakage... That was before I discovered the Home Depot foam seal tape for inside of each duct. The worst culprit is the main flange of the heater box to the main distribution duct. The factory used a 3/4" thick foam seal. Once that turns to dust, all the air flow leaks out to the floor.
Here's the 73 when I did the heater core and you can see that its seal had decomposed into oblivion leaving only the original outline of the sticky tape.
http://forums.maxperformanceinc.com/...ct#post5054228
As for that kick panel, you may want to try a heat gun. That body dum-dum turns to concrete when its cold (and 40+ years old). The inset portion of that panel goes in quite a way, maybe about 5 inches or so, and at the deepest point is where the ring of sealant was placed during factory assembly. The sealant is on both the flange and the outer face of the panel - where the red is on the following photo:
Name:	kick panel rt ac.jpg
  #350
Old 03-08-2014, 05:52 PM
Default Taillight lens restoration
Well I am waiting on a few more pieces for the kick panel and interior project, so I decided to clean up and polish the taillight lenses. I used a 3M headlight restoration kit and they came out fantastic. The kit include a foam sanding pad with velcro on one end to hold the sanding discs. The other end is bare foam for applying the final polish. It includes sanding discs of the following grits - 500, 800, 1000, 3000, and it also includes a liquid polishing compound. Everything is hand applied as opposed to being applied with a drill or rotary tool. I wasn't thrilled after applying the final polish with the liquid polishing compound, so I did a final polish using Griots Machine Polish 3. This final step made a big difference.
While I was at it, I also replaced the taillight bezels. I purchased repops from OER and was pretty pleased with the quality. They claim to be triple chrome plated and seemed to be as heavy as the originals, but the casting quality on the back side was not as nice as you might expect. The chrome finish was probably a 9 out of 10. There was one big problem though in that the holes for the studs were metric instead of SAE. You have to remove the studs from the old bezels and reuse them, so this presented a problem. It was possible to re-tap the holes to the proper size, but it seems like a big oversight and they will hear about it. Here's a bunch of pictures....
  #351
Old 03-08-2014, 05:59 PM
The Boss's Avatar
The Boss The Boss is offline
Oh my!
Today was so nice I spent a few hours working on cars myself!
And go racin' in the street.
  #352
Old 03-08-2014, 06:23 PM
njsteve's Avatar
Very Nice!
An FYI for anyone else using the repro bezels: Be gentle when installing them. They don't have the same curvature as the lenses and the center bars tend to be too wide due to casting flash, for the inset area in the lens. If you tighten then down too quickly they will crack your original lenses. Best thing would be to heat up the lenses under some hot lights and then install the bezels. Slowly tighten the nuts in a criss-cross fashion, one turn at a time, so they have time to conform to the bezel.
  #353
Old 03-08-2014, 06:24 PM
njsteve's Avatar
Oh my!
Yeah, right....I spent several hours chopping and carrying ice blocks out of my driveway so I can get to my garage where the cars are.
  #354
Old 03-08-2014, 06:54 PM
Very Nice!
Steve's advice is sound. The housing attaches to the bezel (sandwiching the lens in between) with three small hex headed screws and that is the initial point at which the bezels start getting pulled into the correct curvature to match the lenses and the housings. I only partially tightened these three screws. When you insert the taillight assembly into the tail panel there are 6 studs that go through the tail panel into the trunk and fasten with nuts that have rotating attached washers. As you tighten these down the bezel is pulled more fully into the correct curvature. I am still slowly torquing these down and also tightening the three screws that hold the housing to the bezel. I didn't need to use heat, and the bezels were clean of casting flash and fit the lenses well. The original bezels that I removed were also flat, so the lack of curvature is not unique to the repops.
  #355
Old 03-08-2014, 08:00 PM
Sunny and 73 degrees here in California, but the reservoirs are all empty...
Bezels and lenses look nice.
  #356
Old 03-09-2014, 05:37 AM
70RAlll 70RAlll is offline
Bob ... you had mentioned this thermal vacuum switch that is located in the air cleaner. The originals were black. couldn't sleep tonight and was killing time searching ebay ads.this came up and thought of you..check it out..correct color black vs the green or white newer ones:
http://www.ebay.com/itm/68-69-70-71-...item4d19c7e647
  #357
Old 03-09-2014, 07:15 AM
Thanks. He has an eclectic mix of parts for sale.
  #358
Old 03-09-2014, 10:17 PM
Got a few things done today. Blasted the honeycomb I got for the spare, blasted the jack shafts for the Black and Red cars, and installed in the positive battery cable clip that Glenn was kind of enough to send to me. The jacks cleaned up well and I look forward to getting them back. I took Bill's advice and after media blasting I sanded the shafts down with 320 grit wet/dry. They look nice.
The Black Car came with a G78X14 space saver spare. Since the car has 15" wheels and I am going to be using a full size spare, this space saver is in need of a good home. If you need it for your project, it yours for the shipping cost - no resellers please. Here's a few pictures.
  #359
Old 03-10-2014, 12:02 AM
Hey Bob.. didn't 1972 Firebirds use the washer fluid cap that had the port coming from the center vs 90 degrees out the side??I know 70 and 71 did. The original style,port in center, is reproduced. You have to buy one for a 1969 Firebird,exact same as the originals, just doesn't have the part number embossed on it. You appear to be trying to tidy up any parts missing/incorrect.This would be an easy call to Ames or PY's. Just confirm it has the center port. Pretty sure the one I saw the guy bought from Ames. I have NOS ones, but they are pricey and quite frankly.. the repo I saw, well 99% will never know the difference.. looking nice..
p.s. I think I have a set of 73 dated NOS tail light lenses if you care..may even have a single 70 dated one, need to check.. know I have some, just need to keep enough for me.. PM me if need be..
  #360
Old 03-10-2014, 12:08 AM
Heck..I just checked and their new repo cap is only $4.50 and it has the correct "Stepco" embossed and the part number embossed on the cap.. so much for NOS being pricey.. You should add one of these in your next Ames order,assuming 72's used this design.. I think the engine compartment looks better with this correct part.. AMes lists it for 69-71, but I still think this was used in 72.. If your car's body was built in 9,10 or 11 of 71 I bet for sure it used this style cap..
