anyone here run a M23 tranny from autogear? If so hows it holding up? what kind of power do you have and what gears and car ?
468 poncho powered 66 cutlass 77 Trans http://s1059.beta.photobucket.com/us...rnout.mp4.html |
I'm guessing you made a typo, because I can find nothing about this on their site.
I do recall seeing it on the AG website. Essentially a beefed up M22 with AG parts, case, midplate, etc. and custom gear ratios to choose from.
The M23 is a dragrace option that has a thicker first gear and I think a replaceable gear on the cluster gear. I got one of the M22's with everything except that option but haven't finished the car yet-can't wait either dammit !
John |
I had to dig around on their site to find it but yes there is such a thing I have talked to them just wanted to see if anyone here has run one for awhile and how its holding up. Talked to Nate at Autogear sounds like a good tranny but never hurts to ask around. They have been out for awhile diff ratios available and stronger straighter cut gears from Italy supposed to shift better with their side plate that has needle bearings in it. super case and steel mid plate and yes the cluster gears can be changed without replacing the whole cluster. Sounds like a direct bolt in except the driveshaft may have to be shortened 1" on some cars
Thats it John
I have the M22 Drag Special, which is the same as the one you're speaking of I believe.
[URL="http://www.5speeds.com/newm22.html"]http://www.5speeds.com/newm22.html[/ URL] I opted for the wide ratio version with a 2.56/1.88/1.37/1.00 ratios, with a 3.90 rear gear. So far so good, but I've only put 2500 easy miles on it. The only bad thing about it, is that it's very quiet, unlike the original M22. I wish it was noisy. Tony
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac (Dealer# 07-679) 70 Formula 400/auto |
Let's try that link again http://http://www.5speeds.com/newm22.html
I just had a couple emails between myself and a AGE tech advisor, here's a neat tibit of info that's worth sharing;
I only have m22 super case. Be sure to get the 1st gear bushing with grooves cut in it for better lubrication. If it is only street driven I would get the roller bearing 1st. My 1st gear with a smooth bushing seized on my main shaft last week on a 1/4 mile run. It took a 40,000 ton press to remove it from the shaft! Going with a grooved bushing next. Autogear says roller bearing 1st flattens the roller bearings from drag racing.
I just ordered one today! they are having a sale 10% off it should be done next week he said ship UPS ground
Got my new trans from Autogear sat put it in the car sofar it runs good. You can see by the pics how much stronger the case is built
http://s233.photobucket.com/user/sur...df6b5.mp4.html |
Cool. I've been thinking about this transmission also instead of a 5 speed.
They got right on it had it in 10 days
Tony, could you elaborate on the gear ratios you chose and also cost?
Thanks much & enjoy, Sully |
Sorry I didn't see this sooner, I don't visit the street forum often.
Regardless, if you are mostly street I think you made a good choice. I had an Autogear m-22 based trans...supercase, iron mid plate, thicker gears, etc. I had it behind a 474 that makes 600 hp/TQ with a DFX Centerforce and 3.90s with drag radials. Street and strip. I use a old hurst ramrod vertigate shifter. Trans has held up well. I shift at 6200 and launch at 3600. I do powershift it at the track. The drag radials are not ideal for a strip manual but I wanted the trans to live so it gave me a little slip with the firm clutch. The power the engine was producing in a 3600 car was the ragged edge of the trans limit. Good luck and have fun banging gears. |
Thanks for the feed back Dan good to hear its holding up my 468 is right there also but I have 331 gears. Sully I went with a a wide ratio Call them up and tell him you heard from me here Nate will help you figure out what works best with your setup. their number is 800 634 3001 They are really good guys and will take the time to talk to you Thanks again Tony
Love my M22Z in the 71, rockcrusher whine is awesome...
