Old 07-12-2014, 05:45 PM
mike76 mike76 is offline
Default would you use main cap bolts of unknown origin?
Just wondering
Old 07-13-2014, 11:07 AM
track73 track73 is offline
Here's what I would do. After checking for cracks, install them and see how good or bad they fit. If they are deemed acceptable get the block line bored.
Old 07-13-2014, 11:39 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Shouldn`t need a line bore for bolts.
Old 07-13-2014, 11:43 AM
PunchT37's Avatar
I would have a good look at em.. Check the head to see if fools mistreated them, check the thread condition, and, if you can find the specs, check the bolt length to see if they`re not stretched beyond their yield.
Course, new bolts ain`t high $ either.
Old 07-13-2014, 12:26 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Were they actually main cap bolts, or just some bolts you want to use for main caps? I would not use a bolt that was not designed for main caps.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 07-13-2014, 01:21 PM
These are a factory set of 4 bolt main cap bolts with the shoulder under the head. I bought these from a PY member some time ago . In appearance they look good but, with anything so old I'm wondering ( short of magging) if they would suit a 525-550 hp street/strip engine w/o issues. The block was lined honed years ago using the original caps and bolts .Those bolts were lost and these are a replacement. Thanks, Mike
Old 07-13-2014, 01:29 PM
Factory hardware is of high quality.
I doubt they've been torqued down more than a couple of times at the most during their life.
I'd use 'em in a heartbeat, just like I'd use the original main bolts on my '64 421 HO rather than replace them with new aftermarket bolts.
