Old 11-07-2016, 02:50 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Congrats, you guys are killing it!
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 11-07-2016, 02:01 PM
78w72 78w72 is offline
congrats! 10's are beyond impressive for your set up... what was the temp & wind conditions? & what tires & psi are you running?
Old 11-07-2016, 02:54 PM
Garry Sr Garry Sr is offline
Here's a good for anyone that likes to street race.....
Street Racing isn't like cheating on your wife, Those are the stories you'd be stupid to tell.
Old 11-07-2016, 02:56 PM
6D9 6D9 is offline
Congrats on the new best and getting into the 10's! Its a good feeling for sure.
1969 Camaro
491 BBC/TH400/GV OD/3.50
Old 11-07-2016, 03:07 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Good job! Very impressive!
Go fast, see Elvis!
Old 11-07-2016, 04:37 PM
Cliff R's Avatar
Cliff R Cliff R is offline
Nice runs! It's always great with these proven big torque 455 engine combo's when you can run "race" car numbers w/o a lot of gear or converter.
This is the best time of year to do it, as we start making a LOT more power than in the hot/humid months. The biggest obstacle to overcome at that point is getting the power to the ground on a colder track, and judging by the wide range of 60' times from your runs you were working really hard at it, congrats!......Cliff
Old 11-07-2016, 07:51 PM
ta man ta man is offline
Thanks Cliff..I'm using a different launch technique that seems to help,plus a good burnout and the new et pros work well.I don't have an extreme range of 60's anymore..I used to just blow the tires off at times.I'm pretty happy getting in the mid 1.5's for a 60ft for a stock suspension car with just a set of cheap 3 way shocks.
Old 11-07-2016, 07:35 PM
Colin70TA Colin70TA is offline
Awesome job Ernie! The gains you made are extremely impressive and show your ability and patience when it comes to this fine tuning. I don't think there are many people that could pull off what you have done, kudos to you!
1970 Trans Am, numbers matching, White, Auto, A/C, Owned since I was 15.
1973 Trans Am, numbers matching, Brewster Green, Saddle interior...Sold :-(
1978 Trans Am 400-4spd, non-numbers matching 400, Low compression daily driver, [email protected] 1/8 mile....Sold :-(
Old 11-07-2016, 10:50 PM
Cliff R's Avatar
I found the ET Street Radials to be very difficult to hook up on cool/cold tracks, but they hook like racing slicks in the hot/humid months. The reason for this is that engine power is down some and the track is simply a LOT stickier.
Even then they require a LOT of burn-out and you've go to be all over them to keep the pressure right. Anyhow, nice to see that you could get it all together and bust into the 10's, keep up the good work!.....Cliff
Old 11-08-2016, 07:07 PM
Ultraflows are really good mufflers. Fairly quiet also. My 78 TA ran identical time/mph open headers to 3" Dr. Gas X pipe, 3" Ultraflows and 3" torque Tech tailpipes even with the extra weight of the system. Open header runs had no system behind it on the car at all.
Old 11-08-2016, 08:55 PM
ponjohn's Avatar
ponjohn ponjohn is offline
TAMAN - what rpm to cross the stripe at? Where in the 1/4 do you shift into high gear?
Old 11-08-2016, 09:23 PM
Can't give u an exact rpm or distance...at the stripe I think I'm at a little over 5000rpm on the factory tach..I have no clue where I go into drive?Maybe 1/8 th mile...I focus on the tree and launch,check the tach shift,check the tach shift...watch for the pylons a the stripe and make sure I don't let up till thru..If I do a little math I could figure out where I go into drive...at 660ft 98 mph with a 3.08 gear and 28 tire..
Old 11-19-2016, 10:19 AM
My 78 weighs in at 3750 with me and Prostar wheels but to slow it down for the roll bar rule added the spare back in and DOTs on heavier 15x8 snowflakes. Unfortunately none of the tracks have had the scales on since I did that.
You are looking great!
Old 11-19-2016, 10:22 PM
77 TRASHCAN's Avatar
Ernie, I'm sure you know there's an aftermarket air cleaner available, originally d signed by a member here, Larry Navarro. Branded WFO air cleaner, similar to stock set, made to be used with an open shaker. I bought one years ago, have not used it yet. I think Butler sells them if Larry doesn't. Larry?
Shut it off
Shut it off
Old 11-19-2016, 10:31 PM
Yes I owned one a few years ago.WFO is a good solution for the street.It helps to solve the magic trick trying to run a stock shaker on a Torker 2 with a one inch spacer. You eventually sacrifice filter size or have the filter top too close to the carb.
Old 11-20-2016, 03:49 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
For you shaker guys. Im still using this setup. Its working ok for me:
http://forums.maxperformanceinc.com/...d.php?t=757533
Ive since convered to a holley and it still works
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
Old 12-21-2016, 05:28 PM
A few changes for next year starting with this.I'm also upgrading the rearend I'm leaning towards 3.42's which will still make the car very highway friendly but I'm not sure yet.
Old 12-21-2016, 10:18 PM
69FIREBIRD76MM's Avatar
Default new best
What camshaft are you using with your new motor?
Old 12-21-2016, 10:41 PM
Most likely sticking with the current cam.We will see what happens or what dumb idea I might have.Things have a tendency to snowball.
Old 12-25-2016, 03:53 PM
400 Lemans's Avatar
Roadpaver to the front. I remember Darby picking up with it. With that low 1st gearset and adding 3.42's you got the same combo.
