Old 10-08-2014, 05:13 PM
67cruiser 67cruiser is offline
Default W.T.B. 63 lemans Roller car with Ford 9 inch
Just trying to see responce i get. send picture,s, closer to WV the better.
Old 10-08-2014, 07:54 PM
tom s tom s is offline
OK.have to ask,why a 9in and not a 12 bolt or a dana 60 or a big pontiac?Tom
Old 10-09-2014, 10:01 AM
63Banshee's Avatar
63Banshee 63Banshee is offline
I have one in TX. If you'll consider it, send your contact info for pictures.
Old 10-09-2014, 07:46 PM
ok, id be happy with a 12 bolt or a Dana also. I figured its what everyone was putting under the 63,s right now.
Old 10-30-2014, 01:27 AM
63Banshee's Avatar
Lemans, some less than typical body repair needed, new driveshaft made for TH400 to 9 inch, 9 inch Ford locker w/ new custom axles, 4 link and coilovers for rear suspension, completely rebuilt stock front suspension, all new brakes, tires never driven on, sheet metal not shown is good, a lot more to offer with this car. Selling only because a body I sold (twice) that is better suited for my project plans came back around (I bought it again) and I don't need this car anymore. 5500 complete out the door. PM me if interested.
ID:	380284   Click image for larger version
ID:	380285   Click image for larger version
ID:	380286   Click image for larger version
Old 10-30-2014, 02:02 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Sounds like yuor trying to buy mine.. 63 LeMans 2 door with built 9" 31 spline full spool 3.70 gear leaf springs in the middle of waiting to weld down spring mounts. Real Van Winkle Dallas car needs floor and tunnel mods for V8 conversion ,
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 10-30-2014, 04:07 PM
Glenn Sedig Glenn Sedig is offline
Default 63 Lemans
Are you looking for a race car or street/strip car?
Old 11-15-2014, 03:56 PM
street- strip
Old 11-17-2014, 02:44 PM
street- strip
Thanks, My 63 is setup for racing with 9 inch/4 link/front struts/cage/etc
Old 11-17-2014, 04:05 PM
Glenn, no motor or trans, correct???
Old 11-18-2014, 11:55 AM
At this point no motor or trans. I have 2 engines and transmitions that would work well in the car. One will run in the 10's the other in the mid 9's. Car has an excellent rust free body that has been prepped and ready for final blocking and paint. Again this has been built as a race car. It could be a street/strip with some changes.
Old 11-18-2014, 03:11 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default Sedig 63
Glen's car is very straight and well constructed. Has many high buck parts. Would make a great drag or pro street car.
ID:	382330   Click image for larger version
ID:	382331   Click image for larger version
ID:	382333   Click image for larger version
Old 12-25-2014, 11:30 AM
Ok, im curious, Whats the absolute lowest price you would take for it.??? Car of my dreams but i know i can,t afford it.
Old 12-29-2014, 02:49 PM
Default 63 Lemans
Well, My 2 son in laws have convinced me that if I foot the bill they will do the work needed to get the car done so they can race it this spring. I will probably need to supply a truck and trailer also to get to the races. It would probably be cheaper in the end to give you the car. If I can get $16500 out of the car I will sell it to you. Probably seems a little high but most of the hard to do stuff is done. SEE INFO BELOW FOR THE CAR.
Here's a build in progress. Includes 9-inch Ford 4-link rear end (4.56 gear) with Strange brakes, 35 spline axles, center section and spool. The front suspension is Strange struts, brakes and rack and pinion steering. The body and sheet metal are in excellent, ready-to-paint condition. The design and engineering of the chassis are complete and the roll cage, chassis, floor, brake and gas pedals are all installed and final welded. The chassis and roll cage are NHRA Certified for 8.50.
