#981
I received a note from the person making the suggestion about the Bronze on Steel Valve Guide Installation suggestion to Don. I will leave it there as the person is a friend of mine. I will not respond to any other comments about the suggestion.
#982
Tom,
What material does Ford use for the guides in the heads on production vehicles with turbos? Stan
#983
Not Sure, Stan, but I can have you an answer by tomorrow evening.
Most of our stuff is Overhead Camshaft stuff which may not suffer the same valve guide durability issues as the previous Push Rod type engines. Tom V.
#984
While the production stuff may not be as high an RPM as some of the race stuff here (some of those stock OHCs do get up there) it does have to last much long before maintenance is performed. Stan
#985
PM to You Stan
#986
Don,
What are the Max target Flow numbers for the DCI Ram Air V heads for this build? 400CFM 450CFM or 500CFM Steve |
#987
At least 400 cfm because that's what they flow as cast LOL. Joking aside though I think with the 2.25" intake valve that we are going to use. We are shooting for around 440 cfm @ .800". I think the port opening is going to be more important than the actual flow number. I want the port openings at the pushrod tubes CSA to be big enough that it is not going to be the restriction. That area we are looking for 4.4"-4.6" of CSA at the pushrod tube cross section. I'm told that with a forced induction situation the cfm is not as critical as it is for a normally aspirated engine. I am really excited about getting the opportunity to work with this combo so that I can research and expand my knowledge level. I feel forced induction is going to be the way of the future because it's so street-able.
Happy Holidays!!! Don Johnston DCI MOTORSPORTS LLC. 330-850-5050 shop 330-628-3354 cell Designer of the DCI Tiger Heads and the NEW DCI Ram Air 5 heads !!!!!! |
#988
I've seen a few thin wall bronze guide liners chip, crack and come apart, but I've not seen a proper phosphur bronze valve guide break up. I have seen a couple fall out though! (due to poor machining or fitting).
#989
What wrong with them? I might be a buyer. Shaft system included?
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Tri power, 4speed, barn find 1966 GTO Ragtop 1969 GTO Judge RA lll, auto 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds Factory stock oval track car |
#990
The McCarty/BES/IndyCartel RA-V top end is NOT being overhauled, it's being retired. I'm swapping them out for DCI RA-V heads. Ed
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
#991
...so, what is included with the McCarty top end?
#993
Questions specifically related to what’s included can be asked in the For Sale section and for anyone really serious feel free to pm me with your number.
#994
Brothers Page where are you?
Carburetor building & modification services Servicing the Pontiac community over 25 years |
#995
We have the welds on what's left of the factory sub frame cleaned up.
#996
Nice, even a modded frame goes a good way under the car and full seam welding helps.
Looks like you have a good welder. We have some of the best in the Detroit area. Tom V.
#997
Sure makes it stiff.
#998
Can I stop by and weld on the chassis?
#999
You're welcome to come by anytime.
#1000
Looks Real Good!!! |
