Old 12-26-2014, 08:55 PM
All I can say is 2 things, WOW! and you have more self-control than most people.
  #82
Old 12-26-2014, 08:57 PM
GTO's Avatar
GTO GTO is offline
Cleaned the pistons and checked the ring grooves all looks OK. Dropped the crank into another block and spun it with a dial indicator. Looks like it's out by .001. I'll have it checked by the pro's before it goes back in. Rod bearings are nice too. Only thing out by a fair amount was the flywheel. It's an ATI SFI and pretty thick. Not sure if bolting the torque converter on would have straightened it. It's also out of round by about .010.
ID:	385533   Click image for larger version
ID:	385534   Click image for larger version
ID:	385535   Click image for larger version
Runner Up Q16 Norwalk 2013!
  #83
Old 12-26-2014, 10:27 PM
GTO's Avatar
GTO GTO is offline
Self control? Maybe. Block was 5years old and **** happens to race parts. I'll never know 100% what happened, so no use to flip out. If it was a problem with the block, I'm sure they didn't know about it at the time. It's the way they handled the problem when they heard about it. I appreciate that. ... Eric.
  #84
Old 12-26-2014, 11:29 PM
mike leech's Avatar
mike leech mike leech is offline
Its only amazing because he can hardly help himself from bashing, and it was not his engine. If it were a "different" block he would be blaming you for ruining an indestructible block.
On a side note.....on topic actually. Any chance it junked the converter? Sorry you went through this...been there.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #85
Old 12-27-2014, 12:07 AM
GTO's Avatar
GTO GTO is offline
I don't think so. Car still ran with no noises at all. I just lost pressure. I will check out this trany and converter also. The one that blew is already rebuilt and the converter was checked.
  #86
Old 12-27-2014, 10:30 AM
ponjohn's Avatar
ponjohn ponjohn is offline
How could the broken block trash the converter, misalignment?
  #87
Old 12-27-2014, 10:34 AM
mike leech's Avatar
trashed converter could break block......
chicken or egg? lol
EHTTFMF!
  #88
Old 12-27-2014, 11:36 AM
chicken or egg? lol
true... bent out of round flexplate could have hurt convertor or vice versa where internal convertor failure hurt flex plate.
Reading through all speculation posted so far, its clear that anything that affects/disrupts harmonic control can cause a failure of something that starts a chain of events that ends up ugly.
  #89
Old 12-27-2014, 12:02 PM
warriors revenge warriors revenge is offline
Send a message via Yahoo to warriors revenge
yeah that sucks.... vibration, detonation, and harmonics can do lots of damage. Yes very lucky it didn't let loose going thru the traps.... I don't recall hearing about an aftermarket block cracking like this, like T.V. said (especially on #4??) well, now you can make that Bitchin Pontiac coffee table that everyone would love to have
  #90
Old 12-27-2014, 02:23 PM
GTO's Avatar
GTO GTO is offline
Table's in the works! Glass top is being sourced as we speak.
  #91
Old 12-27-2014, 04:44 PM
On that "different" block all these things were brought up and you all said BS, no way it could do it.
Well at least it is put to good use.
  #92
Old 12-27-2014, 07:55 PM
77 TRASHCAN's Avatar
Converter gets crammed into pump, pump self destructs sending metal into converter, and trans....got the t-shirt....
Shut it off
Shut it off
  #93
Old 12-27-2014, 07:56 PM
I was wondering if the AP folks might want the old block....to look at, I would....
Shut it off
Shut it off
  #94
Old 12-27-2014, 08:31 PM
ponjohn's Avatar
I do as well...I thought he meant the opposite chain of events.
  #95
Old 12-27-2014, 08:54 PM
oh...
although I had a friend w/ a SBC super comp dragster have the opposite occur, still not sure how, exactly...
Shut it off
Shut it off
  #96
Old 12-29-2014, 01:24 PM
Tiger Paw Tiger Paw is offline
I'm going to suggest that you solid mount the engine in one place only. Rear mid plate with flexible mountings front and at trans. You may be inducing some forces inthat block through chassis twist.
  #97
Old 12-29-2014, 07:16 PM
If something let loose inside the converter;an out-balance converter could wreak havoc at RPM; sending several tons of rotating Cf loads into the Rear main. Even losing one of the "converter bolts".
