Yes, 8.8 is a good rear. It is 4.5" bolt circle if you can go that pattern, unless you redrill. We did a S10 with a 8.8, bought a extra short side axle, shortened the long tube, installed the extra short axle, worked out nicely. I believe the final flange to flange measurement was 47 1/2"s. Cost of donor rear at u pull it was 80 bucs and 20 for the extra axle. Add the pinion to u joint adapter for 50 more clams. Best bang for the buck. Also add this rear has the disc/parking brake setup already on it.
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Tri power, 4speed, barn find 1966 GTO Ragtop 1969 GTO Judge RA lll, auto 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds Factory stock oval track car Last edited by J.C.you; 07-23-2015 at 01:45 AM. |
