Old 09-18-2015, 10:39 AM
CanAmT/AGTO CanAmT/AGTO is offline
Default 71 Interior Paint
I have all interior panels for a 71 bird that need a facelift including dash.
Any recomendations for interior paint? Original Dark Blue
Ames lists the interior paint but only available in spray cans was hoping for something in a 2 part mix to spray as have found that to be more robust, any guidance would be appreciated.
I Bleed Arrowhead Red,
64 GTO 389 Tri Power 4spd Nocturne Blue Poly
70 GTO 400 4spd Palladium Silver
75 T/A 400 4spd Buccaneer Red
71 T/A 455 4spd Cameo White
01 T/A Bright Red 4L60E Ram Air WS6
02 TA Navy Blue Metallic 6 spd Ram Air WS6
Old 09-18-2015, 01:35 PM
2manyT/A'S's Avatar
I've used SEM Color Coat successfully.....but plastic can be fussier to paint than metal.....
Eye Candy......garage band?
Go full screen & turn it UP!
Old 09-18-2015, 03:05 PM
Formulabruce's Avatar
Any 2 part paint has a "glue" effect ( aside from a basecoat) and will "eat" some of the plastic.
>> 2ManyT/A's<< is on the right track ( nothing new there!! )
First Use a product like DX330 ( clean strip makes a cheaper one, paint pre prep) Do NOT use a soapy water based product in a plastic bottle at autozone)
Then use a "Adhesion promoter" ( I use bulldog brand by kleen strip) Follow directions, you only let it sit for a few MINUTES before your color.
Then apply your "made for plastic" SEM coatings AS the DIRECTIONS say. You cannot lay on huge wet coats.
Good luck!! I have done many with plenty of success.. On chalky panels its a crap shoot
" Long may we DRIVE !"
Old 09-21-2015, 02:39 PM
Baba O'Riley's Avatar
Baba O'Riley Baba O'Riley is offline
Concur with what the others said, do exactly what the SEM instructions say.
Color changes -- like black over light-colored plastic panels -- can be very hard to do. Even the SEM stuff chips easily, though not as bad as the cheap auto-store coatings. I'm actually thinking of experimenting with black epoxy primer on some plastic pieces to see if I can get a more durable finish atop that. (I'll start out with an old/broken piece, that way if it dissolves the grain or something it'll be okay.)
"A MAN IS ONLY AS OLD AS THE WOMAN HE FEELS."
-- Groucho Marx
Old 09-28-2015, 08:46 AM
LOADED 70 JUDGE LOADED 70 JUDGE is offline
I have used ppg epoxy primers on plastic interior panels with great success. It is really good as a base if changing colors
Old 09-28-2015, 08:52 AM
I should have mentioned that I use a base coat paint with hardener as a top coat if I can get a good color match. No clear just base coat with a hardner. the sheen is just about right. the base coat is more durable than spray cans although I do like the sem rattle can paints.
Old 09-28-2015, 12:18 PM
L70J -- are the base coat and hardener SEM products? And have you tied this both on plastic (sail panels, etc.) and vinyl parts?
-- Groucho Marx
Old 10-01-2015, 07:01 AM
I used ppg base coat. I have used it on plastic not vinyl. Ken
Old 10-01-2015, 12:41 PM
notime's Avatar
notime notime is offline
10% hardener is how you want to mix base coat. Mix your basecoat as instructed, PPG is 1:1 then add no more than 10% hardener, also, you have to use a particular hardener, ask the paint store which one.
WWW.SUPERCARCREATIONS.COM
Old 10-05-2015, 12:55 AM
68bird400HO's Avatar
Here is an older thread on the 71-72 dark blue SEM matched for me.
http://forums.maxperformanceinc.com/...light=SEM+6169
Old 10-05-2015, 02:19 AM
I just ordered some bright blue rattle can stuff from Ames.
Old 10-05-2015, 05:04 PM
Yep, Thanks exactly what I was looking for.
