Old 10-03-2015, 02:29 AM
bullheimer's Avatar
bullheimer bullheimer is offline
Default would i be cracked out to put a 400 into a running 62 lesabre?
good running buick nailhead 401. just stock grocery getter. crappy "one" speed auto. not a BOP and i don't have an automatic, but they aren't that much i guess. would need all new exhaust and fab mounts up. sure would smoke'm tho. just talking out my ass as usual.
I no longer have that beautiful 66 in my Avatar. whaaa!
When a cat is dropped it always lands on its feet. When buttered toast is dropped it always lands with the buttered side facing down. If a piece of buttered toast was attached to the back of a cat, when dropped, the cat/buttered toast combination should hover, spinning just above the ground, as it tries unsuccessfully to resolve the inevitable conflict of non-scientific certainties.
Old 10-07-2015, 11:13 AM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
Crack, No.. Drinking or weed, maybe.. Please re-phrase the question.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 10-08-2015, 11:24 AM
bullheimer's Avatar
car i have is currently as described above. would a sane person drop a brand new pontiac 400 engine into thi car? better?
Old 10-08-2015, 12:22 PM
please don't waste a running 400 Pontiac on it.
Old 10-08-2015, 01:10 PM
Dont see a huge advantage with a pontiac engine over a good running nail head with both in near stock form.
Old 10-08-2015, 02:19 PM
Transporter Transporter is offline
THIS^^^ nothing wrong with a nailhead, you should think about changing the tranny and let the motor alone.
Old 10-08-2015, 05:21 PM
Txbobcat Txbobcat is offline
Yes change the tranny
Old 10-10-2015, 02:59 AM
bullheimer's Avatar
boy if it were only that easy. yes the trans is the worst part ever. it is not BOP. only a nailhead specific trans will work w/o expensive adapter. only 65-66 trans are desireable too. i'll have fun finding one. i'm still just looking for stinkin wheels with a 3.5 inch center hole!
Old 10-10-2015, 12:21 PM
Early GM 1/2 tons had that center hole - but 6 lug...
It may be easier to get a full size 71-96 rim (or 5 lug truck) and open up the pilot hole: 3.06"Ø to 3.48"Ø in a lathe or mill.
PS - or simply turn down the axle pilot and drum hub to 3.06"Ø.
Old 10-12-2015, 12:34 AM
bullheimer's Avatar
Unhappy
open them up. thats what the last guy did.....with a blow torch!
