#461
GW, I have been thinking about purchasing a soda blaster and looking at one they sell at Harbor Freight. What brand blaster do you have and where did you buy it? As always excellent job and thanks for documenting your work.
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
#462
Don't know how the Harbor Friend deal would work but might be ok to do small stuff like window regulators, etc.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
#463
They look great. Never used a soda blaster but I know that I accidentally got a little sandblast inside my door area and thought I'd never get the grit out of the window regulator.
Greg Reid Palmetto, Georgia |
#464
Yikes $7K.....I'm sure the Harbor Freight blaster won't even begin to scratch the surface as it cost about $100.00-200.00 depending which one you buy. Well there goes that idea. Guess I will have to farm stuff like that out. Saving my money for the next big purchase which is a 2 post lift. Getting to old to lie on a creeper and slide under cars up on Jack stands. She's looking good GW!!! Can't wait to see her finished. She is going to be just drop dead gorgeous!
#465
Well spent all day redoing rhe windows that the "window" guy did. What a f-ing hack! Luckily did no irreversible damage. He did not install the guides in the doors so we had to remove glass and belt moldings to install. Too small of screws in belt molding so they just spun, part of belt molding tucked behind door, no stops or guides in rear quarters, brackets for door panels not installed, yada yada yada. Note to self, don't let other people touch your car!
On a side note anyone else notice how hard it is to find a good drivers side door lock remote control. The springs are either broke or their sloppy as hell.
#466
I've learned that lesson over and over again. I seem to get some grief in other threads, asking so many questions, and about how to do things myself .... built vintage race motorcycles for two decades .... literally 90% of the people you pay to do work on them makes a mess of it ... hence I end up with lathes, milling machines, welders, benders, etc, etc. etc. to do the stuff myself
#467
My tires need balancing right now and I'd planned to remove them, toss them in the truck and take them to the tire shop. I don't even trust anyone to do that much.
#468
Nice to hear that I am not the only one who does this!
#469
I do too, if at all possible.
I've seen to many tire installers simply hammer the lug nuts home with whatever the setting is on the closest impact wrench.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
#470
#471
How about some more photos and info on that headliner installation ... I hear they are a pain. Whatcha got there ... a bunch of little clips around the edges?
#472
What I got is someone who does this for a living installing the headliner.
He worked on it for 7hrs and still needs to come back tomorrow to finish. Looks like something best left to a pro.
#473
Makes you wonder how long it took at the factory? Certainly not seven hours.
#474
Pro x 7 hrs = I can't afford that.
So, I'll be doing it myself ![]() Are those a bunch of little note paper spring clips? http://www.staples.com/Staples-Black...oduct_SS271759 |
#475
I wasn't standing over him but he laid the headliner upside-down on the roof of the car and installed all the bows then did some trimming around them. Used a heat gun a lot and took his time and more then once said how it just wasn't cooperating. If I understood him right when we first talked, he charges around $500 to install the headliner. He makes his own sail panel pieces out of abs and I don't know if that's included or not. I wasn't about to question him about pricing too much as he came highly recommend and I know $500 for a headliner is in line with others I've heard about. That price does not include the price of the material.
#476
Lookin good!!!
DragStarLeMans |
#477
He finished the headliner today and it looks awesome! $500 labor and it included the sail panels. He spent at least 10hrs on that sucker and it was worth every penny!
I've been sanding like mad on all the bright work. This picture is after dents removed and sanded with 320. Only 9 more steps to go. ![]() Cordova top slated for Tuesday.
#478
A shop had a pro install mine. Looks like $%!* and I have to figure out how to fix it. The right pro will definitely do it correctly.
#479
Can't you just put that trim work to the buffing wheel after the dents are out?
Most of the SS will buff out beautifully on a wheel. |
#480
Nope. You have to file after you hammer out a dent then 150, 220, 320, 400, 600, 800 all by hand then 1000, 1200, 1500 all with a da. After all the sanding you get to the wheel for 3 different steps. Anyway this is what I found works for me, if you want a perfect chrome looking finish.
