Old 05-05-2016, 01:41 PM
superdutybob's Avatar
superdutybob superdutybob is offline
Cool
Originally Posted by Transamric View Post
To me these look like later Snowflake lug nuts.
The nuts Chad showed are the same that my '72 TA had. Unfortunately both my current '71's had aftermarket nuts in place, even though I bought them way back in the mid '80's.
IIRC, the 399683 capped nuts were used by every GM division except probably Cadillac. They were a royal pain to deal with because tire shops would often over tighten them using air guns, and next time you tried to remove them the right way with a socket the stainless cap would spin on the nut.
Snow flake lug nuts were flat top, maybe even a little concave as I recall.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #142
Old 05-05-2016, 06:36 PM
TA455HO's Avatar
TA455HO TA455HO is offline
I'd say it's clear...part number and tag too. That's documentation!
That's the casting number on the outside of the drum. Often, but not always, different than the part number.
Consider something like the water pump for the 1971. Assembly part number is 9790522. But it's made up of several individual parts. Impeller, shaft, bearings, seals and the main housing. The main housing might have a casting number like 482138, but if you try to use that number to look it up you typically won't get anything.
One of the more extreme examples is a carb. We might know it as part number 7041267, but it is made up of a few individual castings, jets, float, etc.. Actual stocking part number would be different than that.
You get the idea. I just didn't want you chasing your tail any more than any of us might usually do. Part numbers can refer to one or more casting numbers. In the case of the brake drums it is a one to one relationship.
Oh, and if Lloyd or someone refers to their MPC they might come up with a drum part number for 1970 and 1971 of 3841176. So you might be inclined to think that must be the part number for the 3993560 casting number. Unfortunately, not the case as the part number 3841176 has a casting number of 3841177 as seen here - and that is a pretty penny for each rear drum.
http://www.oldsobsolete.com/products...m-nos-3841176/
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
  #143
Old 05-08-2016, 04:42 PM
TA455HO's Avatar
Here's four of hundreds of small NOS parts I bought at the dealership that my Uncle Kenny worked at. These are dated 4/02/78.
Part number is
479854 10.240 All F SCREW, escutcheon to shift bracket. (8-18 x 4 1970 1972)
No box, but the picking tag has the part number and group clearly shown. You can see I have always been a bit detail oriented like all of you and loved Trans Ams. Even at this time they were likely bringing stuff in for me from other places since they rarely had things like this in stock.
  #144
Old 05-08-2016, 06:10 PM
TA455HO's Avatar
Nobody else has talked about these by part number other than a thread started by me in 2009 and no pictures from then so I thought I would at least post some pictures of these even though they are not assembly line correct numbers as Ric confirmed for me before. Only so much was available even by the time I was buying bits and pieces.
498159 7.243 All F BUSHING (lower) 13/16'' diameter shaft) 2 1970 1975 7-9
And that answers why these are so tight on the 7/8" diameter shafts.
  #145
Old 05-09-2016, 03:35 AM
Transamric's Avatar
Originally Posted by TA455HO View Post
Part number is
I've always puzzled over what the finish was on those screws. Seems like even the tiniest amount of humidity would start them rusting. Have just been painting them with a fairly flat black paint as a better than nothing fix. Any ideas on the finish?
  #146
Old 05-09-2016, 07:38 PM
TA455HO's Avatar
Hi Ric,
Yes, I have seen a fair share of rusted ones and always thought some seemed to rust rather quickly. And not just the top. The sides and threads all rust about evenly top to bottom on ones I have pulled. Sort of a complete rust. And then, I have pulled examples that look fine. I don't know everything about a single screw, but I know I have also seen both a longer and a shorter example.
I don't know if any of you have dabbled much in Fords or not, but they sure make the whole finishes thing a lot easier since they have almost every piece of hardware listed in their MPC along with the finish. Right in the part number as a suffix. You may have seen similar in some GM publications. In fact GM spec'ed the same finishes using the same suffixs with a few exceptions that I have seen Ford use. I know in at least a few cases where they got their hardware from the same vendor.
Just to mention a few, there are lots more examples than just these. But, out of these I think you can probably guess which one I think it is.
-S - Plain (often rubber and plastic parts not intended to be molded in a color)
-S2 - Black or Dark Gray Phosphate and Oil - 72 hour salt spray test
-S3 - Black Paint - 16 hour salt spray test
-S5 - Copper Plate - no specified corrosion resistance requirement
-S7 - Cadmium Plate - Soft Silver - 24 hour salt spray test
-S13 - Chromium Plate - Interior - Bright medium silver - Plated steel parts - 24 hour salt spray test
-S15 - Black Oxide - Jet Black - No corrosion protection
-S32 - Black or Olive Drab Enamel - 96 hour salt spray test
-S47 - Chromium Plate - Exterior - Performance requirements shall conform with ESB-M1P70-A
-S101 - Special
-SX - Wax Sealer - Honey Colored - Use of the letter "X" as a suffix to other Standard Part Finish designations indicates that a sealer, of compound wax or other thermoplastic material, is applied to screw threads over the specified finish - shall meet requirement of Engineering Specification ESB-M4G80-A
  #147
Old 05-09-2016, 08:08 PM
TA455HO's Avatar
9794055 3.270 All 455 H.0 GASKET, exhaust mild. (w/WC, WD, WL, WM, YE engs) 2 1971 1972 3-14
9794125 1.429 All V/8 exc. 307 GASKET PKG 1 1965 1971 1-29
9795217 0.027 All V/8 exc. 307 GASKET PKG 1 1965 1971 1-29
9796613 3.270 All 455 H.O GASKET, int. mfld. (w/WC, WL, YE engs.) 2 1971 1971 3-14
481200 3.726 All 4B.C ................. GASKET (w/Roch. carb.) 1 1968 1971 3-63
9799085 - The 1970 superceded part.
9797580 0.423 All 455-H.0 GASKET (w/WC, WD, WL, WM, YB, YE 2 1971 1972 0-25
488575 0.289 All 455 GASKET 2 1971 1975 0-14
9779068 0.519 All 455 H.O CAMSHAFT (S) (w/WC, WD, WL, WM, YB, eng.) 1 1971 1972 0-29
7041094 3.750 All A & F/455 H.O THERMOSTAT 1 1971 1971 3-84
9632733 10.266 A, B, F, G CYLINDER (uncoded) (B&S 590829) 1 1971 1971 10-4
3991767 10.266 A, B, F, G, H 1 1.80 CASE 1 1969 1975 10-4
3957093 10.267 All F ESCUTCHEON 1 1971 1974 10-4
485178 10.268 All F STRIKER 1 1970 1975 10-4
481542 10.254 All F EMBLEM PKG. (Firebird) 1 1970 1975 10-3
9796480 8.855 A, B, F, G exc. A.C RESISTOR, blower motor 1 1970 1975 8-42
9796452 10.242 All F SPRING, compt. door hold open 1 1970 1975 10-3
  #148
Old 05-10-2016, 01:48 AM
TA455HO's Avatar
Default One more for today
I'm not listing all possible applications for these parts. Just the one that covers my car. And certainly some are later service replacement parts.
479592 10.260 All F COMPARTMENT 1 1970 1975 10-3
3913468 3.023 All F BOLT, tank strap 3/8" - 16 x 3 3/8" 2 1970 1972 3-3
410431 3.028 All CAP (non vented) 1 1971 1971 3-4
5651702 3.110 F FILTER (IN TANK) 1 1976 1981 3-6
There was also an alternate cap gap other than 410431 - I've sold some of both to people and don't have any of the alternate left.
408679 was the alternate gas cap for 1971. Shaped a bit differently than this one in just about all regards. If anyone is interested I might be able to dig up a picture of one.
  #149
Old 05-10-2016, 06:38 AM
The Boss's Avatar
The Boss The Boss is offline
Did somebody set you loose in the warehouse with a shopping cart? Seriously, how did you come to own all of these rare & obscure parts?
And go racin' in the street.
  #150
Old 05-10-2016, 10:47 AM
TA455HO's Avatar
Hi Chris,
A variety of places over the years. When I was a kid I used to ask for specific small parts for birthday and Christmas presents. After I got out of the Army then it was a few things from Year One when they still had some NOS parts - not much from there, really. A few years later then my Uncle passed away and some things were on the shelves and in the cupboards at his shop where he worked after mechanics went non-union in the 1970s. That was where I learned many things from my Uncle. My folks would send me to his house for the summers, basically to get rid of me and have one less to deal with and my Unk was a good teacher and his only son, my cousin Steve, was off to college when I was still a young teenager so they had room at the house for me.
Two of the rarer parts I have that I haven't taken pics of yet - came from his shop - identical pieces to each other so I'm sure he bought them at the same time.
We would work on Firebirds, GTOs, Mustangs, all the way up to very large Ford dump trucks. He would take on anything old and get it running. My Uncle would make me do things by myself like remove the harmonic balancer bolt from one of the big dump trucks. His usual advice to a scrawny teenager was "What would you do if I wasn't here". Got me thinking outside the box at a very early age.
I was on eBay for a long time buying things for my wife like missing pieces of her dishware pattern when it dawned on me that it might be a source of parts so some things from there in later years.
And I have a few friends that were, or their parents were, in the business back then and can still get a thing or two from them or some of the other obsolete parts vendors through the dealer to dealer network (D2D).
Junk like that.
  #151
Old 05-10-2016, 12:44 PM
TA455HO's Avatar
My Uncle did not store parts well so the wrappers have yellowed over the years and are not in good shape, but I found these on a shelf as we cleared out decades of parts he had accumulated. So much old crap for 1940's to 1990's era cars. Tons of gasket kits for engine rebuilds, seals, bearings, etc. etc..
A few other things of interest, like the intake manifold gaskets, but these I remember jumping up and down when I came across them. Dated August 8th, 1970. One has never been out of the package but one side of the wrapper is the see through plastic so I can see the other one is the same date.
9755607 4.680 All F HOSE (rear) 1 1970 1973 4-18
  #152
Old 05-14-2016, 03:05 PM
TA455HO's Avatar
Nothing too amazing here, except for possible the last item is sort of cool.
I mentioned how Bill talked me out of an NOS stripe kit I had for a RAIV he was working on. The big pieces had been stored all rolled up and the backing had peeled away in a number of spots and I wasn't sure if they were viable so I decided to let him have them.
But, of course, he didn't need the hood decals so I still have them. Then a few other odds and ends. I wasn't sure what LD meant or if that gear was correct for my application without a little more research. Mike, or anyone else, if you know please feel free to chime in. I know you have more experience with the gearsets than myself.
484324 8.055 All F/Trans. Am.-- (8.147) DECAL, hood name (455 HO) (white) 2 1971 1971 8-4
404294 5.469 All B,F .................. SEAL 1 1971 1971 5-14
3984819 5.528 All F exc. LD ............ GEAR 2 1971 1971 5-18
5646418 1.745 All exc. T/6 or 307 GROMMET PKG. (type CV-295) 1 1963 1973 1-35
5651393 3.740 All 1 B.C. & 4 B.C N.L. STRAINER, fuel inlet-paper (Roch.) 1 1969 1975 3-79
GF427
6421972 1.745 All V/8 exc. 307 VALVE ASM. (type CV-679C) (pos. vent.) 1 1961 1974 1-35
6484966 3.410 All ELEMENT (w/closed c/c vent.) 1 1968 1975 3-22
FB-59
6485166 3.410 All F-V/8 Trans. Am ELEMENT (A-366C) 1 1970 1972 3-22
7026014 3.130 All N.L. ELEMENT, canister filter 1 1970 1975 3-8
7028131 3.130 All V/8 exc. 307 CANISTER, vapor 1 1971 1971 3-8
  #153
Old 05-16-2016, 06:48 PM
TA455HO's Avatar
A little update for today. Not exactly date coded rotors like Bill apparently had - but not too bad, either. I couldn't find those or the caliper pistons in the online MPC.
344023 5.002 All B, F/D.B SHIELD, splash LH 1971 1972 5-2
344024 5.002 All B, F/D.B SHIELD, splash RH 1971 1972 5-2
179-1140 - Caliper Piston - that's the Delco number
5463495 4.665 All D.B. exc. B BOLT, brake hsg. retainer 4 1969 1975 4-18
5468767 4.667 All D.B REPAIR KIT, front disc brake hsg. piston 2 1969 1975 4-18
5469178 4.665 All D.B. exc. H BUSHING, frt. brake hsg. ret. bolt (5/8" I.D) 4 1969 1975 4-18
5469497 4.669 All D.B SPRING, frt. brake piston return (*2) 2 1969 1974 4-18
5470497 4.665 All D.B. exc. H BUSHING, frt. brake hsg. ret. bolt (3/8" I.D.) 4 1969 1975 4-18
5471576 - Brake Rotor
477682 0.659 All V/8 exc. 307 BALANCER 1 1971 1974 0-36
  #154
Old 05-16-2016, 07:04 PM
Brewster's Avatar
Brewster Brewster is offline
Nice if I was working on a number one car I'd be knocking at your door right now. Cheers for showing and enjoying the items you have. Killer stuff for sure!
  #155
Old 05-16-2016, 08:06 PM
Norwood's Avatar
Norwood Norwood is offline
Old 05-18-2016, 10:14 AM
TA455HO's Avatar
Thank you Brian. I feel good that I've been able to share some, too. Seems like quite a few people here have bought some parts from me at one time or another. If I recall for you it was some upper control arm shaft kits like these. I hope they worked out OK for you. This isn't the same set, but very similar.
6259679 6.164 All F SHAFT PKG 2 1970 1970 6-2
6259679 6.164 All B, F SHAFT PKG 2 1971 1973 6-2
  #157
Old 05-18-2016, 10:15 AM
TA455HO's Avatar
Originally Posted by Norwood View Post
What have we here? Are these the BillyO rotors?
  #158
Old 05-18-2016, 10:58 AM
Norwood's Avatar
No they are the Norwood rotors lol.
  #159
Old 05-18-2016, 11:26 AM
4birds's Avatar
4birds 4birds is offline
Thumbs up
HA! Good one Craig.
  #160
Old 05-18-2016, 11:28 AM
Judge273's Avatar
Judge273 Judge273 is offline
Chad, thanks for sharing those photos as well!
Parts like those are just special to see, and it's a great way to document too.
Mike/Illinois
