#301
Back in the days when I used to street race all chevy guys were running 4.10', 4.56', & 4.88's, never really heard 3.08's on a street strip chevy. Except 1, My friend had a nice 1970 nova, inski roller 396, 3.08's, that thing will run 13. Flat at 106 on street tires he beat alot of well built cars.
#302
Maybe nothing to you.
But I have been to his shop. Seen really nice stuff. Instant Pontiac Hardon. Got some neat Race Pontiac V8 goodies put away. Stay tuned. NHRA NMRA Race Parts. |
#303
There is A Single & Twin Turbo Revolution taking place right now. 1,000-2,000-4,000 Hp on the street. Last edited by wheneaglesfly; 06-19-2016 at 02:21 PM. |
#304
I agree with you tho on the new era now with Hellcats out there everywhere. This has changed the game a lot now that your typical a-hole can just put drag radials on it and terrorize most anything on the street. Believe me, they are dying to spank us "old dinosaurs" at our own game as the ricers |
#305
I'm still waiting on the annular booster main body to arrive...that is the next project.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
#306
The Street Performace Single Turbo builds I have worked on so far are 600-650 Hp Theoretical baseline. Mild cammed as many like. Nice street manners. Superb torque. Feels 10-second fast on the street. Likely 11.2-11.5 at track. Lots of one off fabbing typical. |
#307
Yeah, I have to disagree that Pontiac's are the only brand that can 'do it', you guys must be in a different part of the country or something. Around here, there's everything, all have something fast.
Look at Buicks, 455s for starters, there's plenty of stout running GSs with the 3.08 type gear setups. Then there's the GNs, but we're talking about NA stuff for the moment, right? Olds 455s, have to keep in mind, they are 4.25 stroke from the factory, and although you have to spend a little more on the heads, they can be every bit as fast as Pontiacs. Fords, look at all the 460 combos out there, would be naïve to think they're not fast, and can't do it with highway gears, they have 557ci combos. Mopars? They have had way better heads than Pontiacs for YEARS, and stroker 440 kits that are 505 and 535 just like Pontiacs, bigger too, and Indy heads rock. My personal preference is BOPs, and I've been doing Pontiacs since the 70s. I like Pontiacs, and even if I'm slower, I'm basically going to 'do it' with a Pontiac. Not knocking the accomplishments, but need to keep it in perspective. .
#308
Guys with the REALLY fast street cars, they don't talk, there's no need to brag, but if you show cash... .
#309
I always root for underdogs anyhow. Getting ready to root on the Cavs against the Warriors and my other car is a 68 AMX. Can't get much more underdog than that.
68 GTO,3860# Stock Original 400/M-20 Muncie,3.55’s 13.86 @ 100 Old combo: 462 10.75 CR,,SD 330CFM Round Port E's,Old Faithful cam,Jim Hand Continental,3.42's. 1968 Pontiac GTO : 11.114 @ 120.130 MPH New combo: 517 MR-1,10.8 CR,SD 350CFM E's,QFT 950/Northwind,246/252 HR,9.5” 4000 stall,3.42's 636HP/654TQ 1.452 10.603 @ 125.09 http://www.dragtimes.com/Pontiac-GTO...lip-31594.html |
#310
"But I'd have to say in the last 10 years or so Pontiacs have risen to the top of the BOP heap..."
Also because many are willing to look past the 5000 rpm truck motor combinations ! .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE |
#311
If no gains look for less exhaust sytem back pressure tricks to try out then with Annular Booster 950 HP. |
#312
These guys are running around with 1,000 HP & no Roll Bars. |
#313
Idles smooth. HP Is decent at 360 Hp. Lots of torque @470 ft/lbs. Bought it only for $650.00. 10.25:1 Static compression. I run full ignition advance. 35 Degrees BTDC. Runs on pump gas 91 RM/2 With zero detonation issues . Stock iron heads too. |
#314
Checked the DA for the last 2 outings..May 20th 738ft June 18th 1999ft...I did the Wallace Calculator correcting the new best to the DA from May 20th..11.1 at 123.43
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 Last edited by ta man; 06-19-2016 at 06:30 PM. |
#315
You still haven't hit the ceiling with that combo yet! I wonder if you can get close to 11 flat with your current cam, converter, and gear. On paper, a non Pontiac guy would say that you're under cammed/geared. Many other street Pontiac guys do the same thanks to repeated tuning, dyno or track outings. What does that say about Pontiac?!
#316
TA Man could go to 3.42 gears and a little more stall like 3500-3800. Of course that means more traction would be needed. You're never done in racing and that's a good thing.
#317
Why mess with a perfect street performance combo?
A 400 stroker with a 3-speed auto, doesn't get much simpler than that. Runs 11.20s with 3.08 gears. Great out on the highway and the track too. Drive it anywhere, anyplace, any time. Not many guys ever achieve this, hopefully more will carefully study this thread and follow suit. This car is perfection.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
#318
In today's Muscle Car era........it's not his fast you are.....Its How You Sound !!!
#319
Fyi, there are guys running well into the 10's with 3.42 gear, most likely would still run tens with 3.08.
#320
Its Experimental Territory if he would like to purse 10's N/A with 3.08's.
3.23 , 3.42, 3,64( Old Buick GSX Gearset & Pontiac Fullsize 9.3 only), 3.73 & 3.90 would net easier results I think. 3.23& 3.42 fully streetable. |
