Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 07-11-2016, 01:29 PM
WARPed's Avatar
WARPed WARPed is offline
Default 94 Formula roller For Sale
Torch Red paint/Charcoal int current 8.50 certified weight with Pontiac IAII 505/CV-1s & TH350 3220lbs, MT ET Street Drag Radials 315/60 and 26” MT Sportsman up front. All is new in this car never run. Must see to believe how nice and well done. No cheese anywhere in this car.
Chassis
BMR all Cromemoly when available
Turbo K member
Adjustable upper and lower A arms
BMR/Flaming River manual rack
Sub-frame connectors
Extreme torque arm
Lower control arms
Pan hard
A/C delete plate
Wolf
Anti-roll
Cage 8.50 guaranty re-certification
Mini Tub kit
Rear coil spring adjusters
Strange coil overs front & rear
Aerospace disc front & rear
Wildwood master
Moser 9” housing
Strange center section, spool and 33 spline axles & 3.90 gears
Turbo Action sifter 3 speed w/CO2 system
Electronics
Headlights, tail/driving lights & power windows work
Race Pak UDX data logger dash
Line Lock
Biondo Mega 85 box
MSD Digital 7 (7530t) & matching coil
16 volt alt and battery
BeCool fans/shroud & Northern rad
VFN 5” cowl hood
VFN glass dash
Mid plate & front motor plate for Pontiac
oval 4” dual, x pipe, SpinTech and 4” tails out the back
System 1 oil filter system
Aluminum fuel cell
Mega 300 pump & filter
#10 line for both feed and return
Kirby race seats
Custom drive shaft 1350’s for TH350/glide
She is a bit dusty sitting in the garage for the past few years but will clean up very nicely $22,500 sorry no trades. It would cost you $45k+ to build one of these and a year plus wait.
Text me at 727 three 1 nine 39 zero zero
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 07-16-2016, 09:31 PM
WARPed's Avatar
There are many pics on my board showing the build, use the link in my sig. If you are not a member just let me know and I can help you if needed.
1994 Formula
Old 07-24-2016, 01:06 AM
WARPed's Avatar
bump
1994 Formula
Old 07-29-2016, 11:39 AM
WARPed's Avatar
ttt
1994 Formula
Old 08-07-2016, 06:58 PM
WARPed's Avatar
bttt
1994 Formula
Old 08-14-2016, 11:39 PM
WARPed's Avatar
still available
1994 Formula
Old 08-20-2016, 07:41 AM
WARPed's Avatar
Yes it is still for sale, I really want this to go to someone putting a real Pontiac in it and not a ho hum chebby.
1994 Formula
Old 08-20-2016, 11:50 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Curious, is that Bailey's old car?
Old 08-20-2016, 10:27 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
No KO bought that car.
Old 08-23-2016, 11:45 AM
WARPed's Avatar
No, this car I had built from the ground up.
1994 Formula
Old 09-01-2016, 06:14 PM
WARPed's Avatar
still available
1994 Formula
Old 09-09-2016, 11:23 PM
WARPed's Avatar
This is a steal compared to building one of these.
1994 Formula
Old 09-18-2016, 07:46 PM
WARPed's Avatar
still available
1994 Formula
Old 10-25-2016, 01:16 AM
WARPed's Avatar
TTT
1994 Formula
Old 11-18-2016, 02:27 PM
WARPed's Avatar
Still for sale
1994 Formula
Old 12-11-2016, 01:18 AM
WARPed's Avatar
Someone buy this so that I can get my old (Troy's) 69 GP back.
1994 Formula
Old 01-10-2017, 10:28 PM
WARPed's Avatar
ttt
1994 Formula
Old 06-15-2022, 12:59 PM
mysticmissle's Avatar
anyone know where Alex's car ended up? i see the motor is on py with new owner
Old 06-16-2022, 06:44 PM
Scott Stoneburg's Avatar
The car sold to a buyer in the Orlando area. I heard his plan was for a nitrous small block.
