#301
GTO George |
#302
No matter what some non racers say in order to run BIG numbers the better the flow the more HP YOU WILL make. Pro Mods DONT run e heads! Yes you can make GOOD HP with 330-350 heads, twin turbos will hide a lot of inadequacy of a head BUT it won't get you qualified at Indy!
GTO George |
#303
I (KRE) made almost 800 hp with a 455 and a 250 B & M street charger roots blower and ONLY 8 lbs of boost with 320 e heads! Big Deal! GTO George Last edited by GTOGEORGE; 04-02-2017 at 12:37 AM. |
#304
You drunk george?
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
#305
I'm making around a 1000 horse on my 421 turbo combo with 18 psi of boost, still using home modded factory iron heads and a flat tappet cam! I'm not using them just 'cos I'm a tight arse, there are benefits to an iron head. I'm turning the wick up this year shooting for around the 1200 hp mark, maybe 1400. I'd run out of my chassis tag if I fitted a nice pair of CV1's !
#306
Talk about comparing oranges to apples? I think you are drunk! |
#307
#308
That 482 must bad azz! It's probably using E-heads. |
#309
Explain.....I'm old! nothing I said was wrong.GTO George |
#310
I would NEVER compare a BAE hemi to a chiefs engine, that's just silly! GTO George |
#311
You did, saying he didn't qualify at Indy.
#312
He was the one that tried to qualify with obsolete heads! I thought it was silly, it's like taking a knife to a tank fight. With a better head he would had have a better chance.
GTO George |
#313
Soooo young George, which Pontiac head on a 482 cid engine would he have qualified with?
#314
I think it may have been posted on here before but what does a BAE head flow? And yes I realize flow numbers are only a small part of the equation
#315
George notice there is not 1 Pontiac motor in that class.
Yes Pontiacs are out dated junk, there is a place in a Pontiac guys hearts but in the big racing world we are as old and as out dated as you. |
#316
GTO George |
#317
KRE's Warp 6 head is the closest us Pontiac Races have to a Pro Mod head. Like I said before Pro Mods don't run e heads on their engines.....there is a reason for it.
Listen we will never ever really compete our bore spacing is too small it limits valve size. GTO George Last edited by GTOGEORGE; 04-02-2017 at 06:40 PM. |
#319
The billet Visner head is better then that Warp 6 head. It's a lot more to going fast in ProMod then a set of cylinder heads anyway. |
#320
So how much horsepower have these Warp 6 heads produced? |
