Old 10-08-2017, 08:54 PM
72projectbird's Avatar
Originally Posted by JonW View Post
It's amazing how someone who has never tried them is convinced they don't work.
x2.
I guess all the truck guys using them must be total morons?
Whatever, I use them and I see results.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 10-08-2017, 09:06 PM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
x2.
You go bro, you go!!
If you see results, who am I to argue?
I just don't get how. Maybe it's like a flywheel in that once you get enough rotational mass it just blends it out?
Bottom line is that the beads will never ever EVER stop rolling.
Regards.
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 10-08-2017, 09:50 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Why not just balance a tire in the conventional methods?
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 10-08-2017, 09:59 PM
STEELCITYFIREBIRD's Avatar
Special pellets, with antimatter (don't matter) properties....defy Newton's Laws of Motion.
Old 10-09-2017, 12:41 AM
242177P's Avatar
242177P 242177P is offline
Oh please. Laws of physics say otherwise. Might as well call it witchcraft.
Big tires sometimes need excessive amounts of weight to balance. So a shop screws around, finally finds a sweet spot, and it's completely ruined the first time it is taken off road.
FWIW, I don't see much merit...
Old 10-09-2017, 09:08 AM
lfdsteve's Avatar
I know it's beat to death so one more comment then I will let it go. As to the physics, IF you drive at exactly the same speed on a perfectly flat plane, like in a lab for example, the beads might eventually settle into a "place" where they stop moving but A there is nothing in physics that says this will be the lightest part of a tire and B as soon as this speed, or plane changes it will all shift and start rolling again.
What WILL happen according to simple physics is that the mass, aka the beads will eventually find the spot FARTHEST from the center of rotation but there is no guarantees that this is the spot needed to balance.
have a great fall.
Old 10-09-2017, 09:55 AM
glhs#116's Avatar
glhs#116 glhs#116 is offline
Paul, in the case of very large offroad tyres, according to the literature on the site, the issue is that the imballance on a large tall tyre is very far from the rim (tall sidewalls) so the amount of weight that needs adding to the rim is rather large (it has less "leverage" being closer to the centre than the tyre tread) and also dynamic imbalance is common on these tyres as tread gets damaged and mud gets lodged etc...
One of our members here testifies that he uses the product for his large tyre offroader and is satisfied.
Whether it is better than conventional wheel weights or not for street muscle cars is probably another question. But I think people are being a little quick to mock. If you saw the "how it works" on the site it's not that hard:
1. balls initially roll everywhere somewhat evenly
2. a heavy spot on a tyre causes the tyre and wheel to move in the direction of the heavy side
3. Newton's first law says the balls being free to move move in the opposite direction towards the lighter side
4. the faster the tyre spins the less the balls want to change position (stuck harder against the inside of the tread)
So, yeah, the physics makes sense or is at least plausible. Does it work? Is it worth the hassle and the risk of shooting yourself in the eye when you let air out of the tyre? Dunno. I guess that's why the post was made to discuss...
Sam
Sam Agnew
Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it.
Ministry - Jesus Built My Hotrod
Old 10-09-2017, 10:49 AM
JonW JonW is offline
The tires on my Lincoln were balanced, and the balance job was OK, but not great. In dealing with the wife's Mustang, I had to have the tires balanced 3 times. In the process, the wheels got damaged.. And of course, they don't remove the old adhesive when they remove the old weights, and you can see the old adhesive when you look thru the spokes of the wheel. Which means I have to pull the wheels off and remove the adhesive.
Since the Lincoln wheels were somewhat balanced,, I decided to skip the part where they damage the wheels and don't remove the adhesive and try the beads instead. In this case, the beads did remove almost all the remaining vibration. The nay-sayers can say what they want, but i didn't have to take the car to the tire shop, I didn't risk any wheel damage, I didn't have to pull the wheels off when I got home to remove the adhesive, and I improved the balance to the point where I'm happy with it. In addition, because of the beads, I'll likely not need to rebalance the wheels until it's time for new tires.
1963 GTO project
1975 LeMans Sport Coupe
