#141
I have the Ford Mustang/Explorer & GM Bolt Pattern on the rear (because I am using Explorer Rear Disc Brakes) and I have Front Hubs that have both the Mustang and the GTO Bolt Pattern on the front. I can use either the 16" Trans Am rims or the 18" Mustang Torque Thrust 2 Rims.
A Lot of flexibility there. The Axles use a threaded Axle Stud. Same deal with the Aluminum Front Hubs. Tom V.
#142
![]() Quote:
https://fabcraftmetalworks.com/
#143
![]() Quote:
Jeff |
#144
I have been watching this build. Seems appropriate for the conversation. Try and ignore the fact that he calls it a 67 and says it has a Buick motor twice. Still a nice rear setup IMO.
https://www.youtube.com/watch?v=cjDJvNQ_2AI |
#145
Have put circle track floaters in one project and am currently looking for one for my 80 T/A project. One drawback I see is that I can only find 31 spline axles for the floaters. I'm sure they are available from someone as the big boys run very short floaters in their pro mods etc.
Who cares about the horsepower wars, Indians win the torque wars. Roger |
#146
Spend some bucks and put in a "Dana 60" out of a 70 Challenger like I did in a 68 Firebird!
1972 Grand Prix |
#147
^^^what skullbucket said^^^
![]() Quote:
I also have Z06 rear brakes on a Ford Gt500 rear axle... yeah try that next Tuesday... ![]() ![]() I will hunt down pics if your still interested, its a pro touring deal I have a custom frame setup in the back. take that axle, I got for a steal brand new from Roush in Michigan. cut the mounts off, made my own. Slap this watts link on the back https://www.americanmuscle.com/white...link-0510.html grab some adjustable control arms, weld the mounts on the frame. https://www.americanmuscle.com/j-m-a...-red-0514.html https://www.americanmuscle.com/bmr-a...poly-0510.html Add a stabilizer bar http://www.maximummotorsports.com/Ad...2004-P546.aspx Last edited by mikes2nd; 01-18-2018 at 04:11 PM. |
#149
![]() Quote:
#150
![]() Quote:
#151
![]() Quote:
My 9" project has been a real pain in the a$$. I have spent more money on redoing it and still haven't been able to use it,and now the car is apart for bodywork. Last edited by gene simmons; 01-19-2018 at 12:22 PM. |
#152
I ran 11" drums with a 9" in my 'bird and had e-brakes. The cables you can have made to any length, any ends, but I recall using my originals, but that was years ago.
When doing a 9", I would think you would be better off just ordering it with 12 bolt GM ends, the hybrid ones from Moser use the big Torino bearing, so there's no loss, only benefits. Just like with any upgrade/mod, you need to think it through before you pull the trigger. .
#153
![]() Quote:
I don't know who does custom brake cables for GM to Ford. |
#154
![]() Quote:
http://www.controlcables.com/ Looks at the cable arm pics attached. All they are is a fork that captures the cable end. The cable housing just needs to not slip through the backing plate hole. Like I said, I'm fairly certain I used my original cables when I went from a 10 bolt to a 9". Back to the housing ends. Yes, many make the GM ends to go on 9" housing, but most you still end up with the tapered bearings. That's what makes the Moser ones different, because they use the large Ford Torino bearings. Who is doing the work on your 9"? I would be surprised if a shop wouldn't give you options if you ask them. Never say never. Why would you not ever want to go to disc brakes? If you are trying to maintain originality, why would you be doing a 9"? Regardless, there are brake kits for every common rear flanges out there, so it's not a problem anyway. For the front, there are kits that work with the OE drum spindles. When it comes to ordering a housing, it makes sense to order a GM end on a 9", so you're not limited to disc kits that are available for Ford ends (or drum for that matter). You get stuck with Ford ends having to find rotors (or drums) drilled for a GM pattern. If you keep the Ford bolt pattern on the rear, you end up having issues finding wheels that match front/rear. (Not to mention stud/nut sizes) Moser is the only folks who I am aware of that have the hybrid ends, but other rear shops do buy them from Moser an offer them. Always do your homework before you pull the trigger, or you will be doing it over again. .
#155
![]() Quote:
Because of intermediate cable lengths, sometimes the rear cable doesn't get the correct 'pull'. But you can adjust the intermediate cable, or buy a different length one. So if the rear cable is just not quite right, you may be able to compensate with the intermediate cable. .
#156
![]() Quote:
You should have a build thread going! .
#157
![]() Quote:
Let's make welfare as hard to get as Veterans benefits! |
#158
![]() Quote:
Now i need to decide on a brake setup that will utilize the e-brake cable,so the GM ends seem to be the logical step,since the stock ends need replaced. Its not likely i will go with rear disc,fronts maybe,i need to finish this project,in order to drive it once again. This 9" has been a pain for years,i had Qp build it before a lot of these new parts existed. I have the 35 spline axles with the large tapered roller bearings. Last edited by gene simmons; 01-20-2018 at 12:22 PM. |
#159
If you haven't bought the ends yet, look at these:
http://www.moserengineering.com/7900...lip-axles.item Not sure if those are the hybrid ones, since they look like they are for 10/12 bolt housing. (The tubes are different sizes from Ford 9"). But you can call and ask. I think they changed the design so it has a step in it, so it can fit different size tubes. You will have to change your bearings out, but it's worth it. I've heard the Lokar ones are not as good as most think, and have heard of issues with them. Anyway, you will get through this, and wish you the best in success! EDIT: The tapered bearings are not bad, but you have to shim them to adjust preload. That preload, if not right, directly impacts kickback, and if it's sloppy, you can get wander on the highway. .
#160
I haven't bought the ends yet,that looks to be what i need.Quick performance uses a lot of moser parts,they may have that part in stock,i will have to call and get specifics for my application.
Thanks Hwystr455,i appreciate that,it's a tremendous help,good information for the OP as well. ![]() |
