Anybody have a 3” exhaust with tailpipes and splitters on a 2nd gen trans am if so what kit ? And pics please
I've got 3 inch exhaust from my headers to a set of Doug's cutouts and to the X pipe. Everything from the X back is 2.5 inch. It clearly isn't a kit.
If you have any kind of performance setup, 3 inch is the way to go.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, [email protected] in the quarter...still tuning. |
Number 1 , you do not need 3" Exh back passed the mufflers unless your exceeding 650hp and number 2 , you will give yourself a hell of a hard time to fit 3" tail pipes back there and not having any rattles taking place at times!
Steve I beg to differ. My 2nd gen Torque Tech 3" fit great and no rattles. Unfortunately he retired a year or so ago and no longer makes F or A body pipes.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
got a full 3" kit on my 72 from pypes, everything fit great including the 3" tails... & zero "rattles."
Never have heard a complaint from anyone using a Ram Air Restoration system. It ain't cheap, but you get what you pay for, usually.
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
Complete Torque system on my '70 TA including Dr. Gas 3.5-inch in / 3.0-inch out X-pipe and 3-inch tail pipes. DynoMax 3-inch mufflers.
No issues. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) Best time 5.13 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 03-29-2018 at 10:15 AM. |
I believe the OP makes enough power ... If I didn't just need 3 inch tailpipes I'd order another kit from PYPES.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2,generic one inch open spacer 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 |
I disagree. There is plenty of dyno testing out there that shows 3 inch is better than 2.5 for pretty much any power level with these levels of displacement. There is plenty of room for it as well.
Anyone have a pic of the 3” Pypes system installed with the splitters on a T/A ?? I heard the you can’t run the splitters with there setup ...
I have what your talking about I think but can't seem to post it on here I can text the pictures to you if you want send me a pm
Ben |
Since I have a 9", I doubt I will get 3" tailpipes on it. If I'm wrong, someone please educate me.
You can't....also last I checked they discontinued the 3" splitters.
I had the Torque Technologies 3" tail pipes with my 9" and all fit well. |
Any other tailpipes that work? .
I should have a new set of 3 inch tailpipes next week. I informed the shop I'm dealing with there is a big market for these.
I talked to your guy and said I would wait and see how yours fit before I buy a set , are you planing on running the factory splitters ? Somebody said the 3” splitters are made anymore... I have a set that I think got from Pypes years ago but there on a set of 2.5 tailpipes I will have to try and save them ...
Even though it is overkill, I still documented a nice power gain with full 3" on my very mild 455.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
