Old 03-28-2018, 05:39 PM
er455 er455 is offline
Default 3” exhaust for trans am
Anybody have a 3” exhaust with tailpipes and splitters on a 2nd gen trans am if so what kit ? And pics please
Old 03-28-2018, 08:50 PM
Navy Horn 16 Navy Horn 16 is offline
I've got 3 inch exhaust from my headers to a set of Doug's cutouts and to the X pipe. Everything from the X back is 2.5 inch. It clearly isn't a kit.
If you have any kind of performance setup, 3 inch is the way to go.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, [email protected] in the quarter...still tuning.
Old 03-29-2018, 05:59 AM
Number 1 , you do not need 3" Exh back passed the mufflers unless your exceeding 650hp and number 2 , you will give yourself a hell of a hard time to fit 3" tail pipes back there and not having any rattles taking place at times!
Old 03-29-2018, 09:28 AM
Steve I beg to differ. My 2nd gen Torque Tech 3" fit great and no rattles. Unfortunately he retired a year or so ago and no longer makes F or A body pipes.
Old 03-29-2018, 09:40 AM
78w72 78w72 is offline
got a full 3" kit on my 72 from pypes, everything fit great including the 3" tails... & zero "rattles."
Old 03-29-2018, 09:48 AM
77 TRASHCAN's Avatar
Never have heard a complaint from anyone using a Ram Air Restoration system. It ain't cheap, but you get what you pay for, usually.
Shut it off
Shut it off
Old 03-29-2018, 10:07 AM
Steve C. Steve C. is offline
Complete Torque system on my '70 TA including Dr. Gas 3.5-inch in / 3.0-inch out X-pipe and 3-inch tail pipes. DynoMax 3-inch mufflers.
No issues.
Old information here:
Old 03-29-2018, 12:01 PM
ta man ta man is offline
I'd say anything over 550hp will lose power with 2.5 inch exhaust..my car picked up a tenth and a half and 1.5 mph dropping the 2.5 tailpipes.
I believe the OP makes enough power ...
If I didn't just need 3 inch tailpipes I'd order another kit from PYPES.
Old 03-29-2018, 12:30 PM
I disagree. There is plenty of dyno testing out there that shows 3 inch is better than 2.5 for pretty much any power level with these levels of displacement. There is plenty of room for it as well.
Old 03-30-2018, 09:11 AM
Anyone have a pic of the 3” Pypes system installed with the splitters on a T/A ?? I heard the you can’t run the splitters with there setup ...
Old 03-30-2018, 10:49 AM
Ben Ben is offline
I have what your talking about I think but can't seem to post it on here I can text the pictures to you if you want send me a pm
Ben
Old 03-30-2018, 11:33 AM
Since I have a 9", I doubt I will get 3" tailpipes on it. If I'm wrong, someone please educate me.
Old 03-30-2018, 12:18 PM
PAUL K's Avatar
PAUL K PAUL K is offline
You can't....also last I checked they discontinued the 3" splitters.
Go fast, see Elvis!
Old 03-30-2018, 12:21 PM
PAUL K's Avatar
Your wrong....lol
I had the Torque Technologies 3" tail pipes with my 9" and all fit well.
Go fast, see Elvis!
Old 03-30-2018, 01:00 PM
Your wrong....lol
That's good news, but the bad news is they're not made anymore!
Any other tailpipes that work?
Old 03-30-2018, 01:09 PM
I should have a new set of 3 inch tailpipes next week. I informed the shop I'm dealing with there is a big market for these.
Old 03-30-2018, 02:46 PM
I talked to your guy and said I would wait and see how yours fit before I buy a set , are you planing on running the factory splitters ? Somebody said the 3” splitters are made anymore... I have a set that I think got from Pypes years ago but there on a set of 2.5 tailpipes I will have to try and save them ...
Old 03-30-2018, 02:50 PM
Default 3” splitters are available
http://pypesexhaust.com/i-12200764-7...rod-tab-review
Old 03-30-2018, 03:18 PM
I have a set of 2.5 splitters I may put them on the end...I'm not sure..my car isn't as stockish looking as yours so I'm not that concerned if I use them or not..if I do use them I will open them up a bit more.
Old 03-30-2018, 05:19 PM
Lee's Avatar
Lee Lee is offline
A good muffler man should be able to make it fit nicely :-) Too bad there are not that many truly good ones out there. No rattles on mine.
Even though it is overkill, I still documented a nice power gain with full 3" on my very mild 455.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
