Old 08-29-2018, 12:42 PM
GTOGEORGE's Avatar
Originally Posted by Mark G View Post
You need to be rich to be competitive with a Pontiac...
You need to have money going that quick with any engine/car, trust me it ain’t cheap!
GTO George
  #42
Old 08-29-2018, 12:53 PM
Hooter's Avatar
Hooter Hooter is offline
Originally Posted by Jeff Kinsler View Post
I put the inserts in my E-heads beginning of last year and went from having some leakage start between the center cylinder in 10 to 15 passes to now going 50 to 60 passes without changing head gaskets. So I can verify that the inserts definitely work.
Also I will be running a set of the new tigers for next year and I dont think there is going to be a problem. They have water going between the two exhaust valves and I will have the inserts put in.
EHTTFMF
So, the new Tigers have water in there and the old ones did not?
67 Bonneville ragtop
  #43
Old 08-29-2018, 01:07 PM
scott70's Avatar
scott70 scott70 is offline
Originally Posted by John Langer View Post
Well it use to be 3-5 passes
Youve got to be a committed racer to put in that much time and money. I guess I'm lazy because I wouldnt want to invest that much time and money. It looks like those guys on streetoutlaws race on the weekends and work on their cars all week..I couldnt do it. These too many other things to do. I used to pull the motor and have it freshened every 3 ish years which I thought was a pain,,,lol. If I Had to pull the heads off every 10 runs Id say the hell with it. The slower ,low maintenance stuff is fine for me.Im sure you done it so much you could pull the heads and have them back on and valves set in a hour.
  #44
Old 08-29-2018, 01:29 PM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Originally Posted by Glenn Sedig View Post
The heat generated by 2 exhaust valves side by side in the center of the head softens the alum enough to cause the web between the center cylinders to deform down .002 to .004. The ridges in the head gasket also indent into the alum web by several thousands of an inch. The other webs with 2 intake valves side by side show no distortion or effects from heat. After the center web is pushed down, the head gasket has less clamping pressure in that area, which slows the disipation of heat causing the head gasket to burn and allows combustion pressure to pass between the cylinders.
All of the heads I have put inserts into regardless of the brand have had this same problem.
On my engine with over 15:1 compression I have had no problems. When tearing it down, the area of the gasket where the insert is, shows no sign of heat or leakage. The insert is pulling the heat away from the area so that the insert in the web does not get hot enough to deform. The copper alloy insert will also take much more heat that is generated in the web area before it gets soft enough to deform.
Jim is right, the problem is too much heat. So the answer is to get rid of some of the heat or find something that will hold up to the heat. Adding water holes will get rid of some off the heat and the copper inserts will hold up to the heat.
One or both of the fixes can be a solution. With that said we will still have problems in the center web area on high hp heads because of the heat and the thickness of the web.
Glen, Give me a call 540-967-4836 or 703-615-5027
Steve
67 Firebird 3440 lbs, Pump gas 537 IA2, tiger heads, 4.86 rear, 32 x 17.5's, full interior, 4 mufflers, street shape 1.36 60', [email protected] 1/8 mi. 5.67@123 on small shot.
  #45
Old 08-29-2018, 03:08 PM
Hooter's Avatar
Glenn - what's the going rate on a set of e heads to have this done? My motors coming out this winter. May have this upgrade done on them.
  #46
Old 08-29-2018, 03:14 PM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
X2... may be interested in the future myself
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
  #47
Old 08-29-2018, 03:17 PM
slowbird's Avatar
slowbird slowbird is offline
It would be nice if AP would state what the difference is with the new casting vs the old casting to help fix the heat issue there
  #48
Old 08-29-2018, 07:10 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
I'm not a tiger expert but I think the original tigers did not have water between the center cylinders and new ones do.
Langer or Dwight can chime in.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #49
Old 08-29-2018, 09:09 PM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
That’s why some switched over to the Shafiroff 1000 hp motors for 15kthat you can run forever.
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
  #50
Old 08-29-2018, 09:12 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
I would rather put Head gaskets on a Pontiac every 10-15 passes then put a Chevy in my Pontiac.
[email protected]. 3460#s
  #51
Old 08-29-2018, 09:56 PM
John Langer's Avatar
John Langer John Langer is offline
How would you even know whats under the hood? Don't you fly in professional tuners???
  #52
Old 08-30-2018, 01:14 AM
I did a BBC 1030 hp in my 63 Tempest for two years in Super Street 10.90@158 but sold it and went back to the 467. Having Butler build me an aluminum 535 this winter so I’ll have another go at it.
  #53
Old 08-30-2018, 01:50 PM
Glenn Sedig Glenn Sedig is offline
Default Tiger Inserts
I get $675 to make the inserts, machine the heads, and install them. Tony at BES will also machine your heads and install the inserts. You will need to check with Tony for price.
  #54
Old 09-01-2018, 03:33 PM
LPI's Avatar
LPI LPI is offline
Default clamp load test
Do you mean this test?
Softened chambers, insert washers, clamp load, coated pistons, camshaft, headers and water.
Oh, if you follow the manufacturer's instructions...then go buy a Chevy
ID:	492036   Click image for larger version
Name:	Test 1 6_30_2013.jpg
Holy cow Tom that's a dirt road...
www.luhnperformance.com
  #55
Old 09-01-2018, 04:07 PM
Dragncar Dragncar is offline
Interesting photos. It looks like the top pic is darker around some of the bolt holes. Is it just the pic or is there a actual difference. First time I have seen this stuff BTW.
Thanks.
  #56
Old 09-01-2018, 04:28 PM
Mark G Mark G is offline
Could you do my E-heads this winter
  #57
Old 09-01-2018, 04:32 PM
GTO George
This is not my first rodeo George ..
  #58
Old 09-01-2018, 08:17 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Nice work LPI thanks for sharing.
Go fast, see Elvis!
  #59
Old 09-01-2018, 08:21 PM
p4msi1's Avatar
Mark is cool.........
  #60
Old 09-03-2018, 10:00 PM
Does the ram air v head solve the head gasket problem since the exhaust are separated ?
