Old 12-01-2018, 10:41 PM
aaronman aaronman is offline
Default 539 Dyno Results
Dyno'd my back-up engine today. Bracket engine built to go 500 passes. Some details. 539 IA2, 13:7:1 Compression, 380cfm KRE HiPorts, Non-offset T&D 1.65 Shaft Rockers, Isky EZ Rolls, 1250 Dominator, Victor, 2.25/2.125 stepped headers, Comp Cams 285/292 @ 112 with .774/.751 lift, Q16. Special thanks to Bill Meyer for building this engine.
Old 12-01-2018, 10:53 PM
Great numbers for a ( as described) bracket motor! Clearly not max effort but great numbers... that motor will live with very little maintenance....check lash and go...
Old 12-01-2018, 11:01 PM
Scott Stoneburg's Avatar
Sweet. Thats a nice back up.
Old 12-01-2018, 11:18 PM
grandville455's Avatar
Nice numbers aaron!! Who ported the hi Ports?
Darby
M/T 275/60 ET SS Drag Radial
Old 12-02-2018, 12:45 AM
Nice Aaron.
Old 12-02-2018, 08:38 AM
Some additional details to help others. Hi Ports are out of the box from KRE 64cc heads. KRE has a 380cfm CNC program. Victor intake was port matched to the head. Wiseco 4.365" gas port pistons. 4.5" forged crank. Callies Ultra Rods. 7/16" tapered pushrods. Milodon 30355 pan & Melling 60psi pump. Motor made 860hp on Sunoco Supreme 112. 884hp on VP Q16.
Old 12-02-2018, 09:05 AM
Nice!
Bill makes some good engine combos.
Old 12-02-2018, 09:50 AM
Half-Inch Stud Half-Inch Stud is online now
> 1.5 HP/CID is looking real good
Old 12-02-2018, 11:16 AM
That will find a weak link behind it. Hope it gives you a long trouble free life
Old 12-02-2018, 11:29 AM
PAUL K's Avatar
PAUL K PAUL K is online now
Good job!
Go fast, see Elvis!
Old 12-02-2018, 06:37 PM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
Can someone please explain how Q16 makes more power then Sunoco 112? What if any changes need to be made to the carburetor?
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 12-02-2018, 06:42 PM
goatless's Avatar
goatless goatless is offline
Bud Lyons? I haven't heard that name in ages.
Q16 is oxygenated- it contains more oxygen per unit than "normal" gasoline. The extra oxygen allows you to burn more fuel, so need to increase volume.
1966 GTO
Old 12-02-2018, 07:09 PM
Bud Lyons's Avatar
Thank you.
Old 12-02-2018, 08:26 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Nice combo.
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 12-09-2018, 01:14 AM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Awesome!! Congrats.
Old 12-12-2018, 11:02 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
What was done to the Victor?
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 12-12-2018, 10:19 PM
Victor was port matched to the heads and plenum cleaned up. Super Sucker 2" 4 hole space was worth 12 hp.
Old 12-13-2018, 03:12 PM
Thanks man.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 01-31-2019, 11:28 PM
Outstanding
Old 02-01-2019, 12:04 AM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Originally Posted by adam woodmancy View Post
Outstanding
I heard Aaron and his wife were crushing it down in Florida not long after this dyno session took place!
Nice job Milton Family!
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
