Old 02-05-2019, 12:33 AM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default 301 draw thru turbo on a 350 Pontiac?
I asked this in the street section, probably should've done it here. Has anybody here ever taken a 301 draw thru turbo and modified it to work on a bigger motor like a 326/350 stock Pontiac?
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
Old 02-05-2019, 09:00 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
I remember one on here doing a twin setup with these units... username Firechicken ???
I also think he used it on cast rods/piston deal and made a pile of scrap metal.. LOL
Old 02-05-2019, 10:37 AM
Johnny406's Avatar
I'll look that up, I was thinking that a pair of these would fit (with help) on a Offy dual quad intake.
Old 02-05-2019, 12:15 PM
firechicken's Avatar
firechicken firechicken is offline
Twin 301 draw thrus in a 3800lb TA with 068 cammed 400 and 6X heads went 10.50s 15 years ago.
Same turbo setup runs 9.70s today on a KRE Dport headed 455 and driven 40 miles to the track.
There are much easier ways to do this these days...
The Following User Says Thank You to firechicken For This Useful Post:
Old 02-05-2019, 12:28 PM
Johnny406's Avatar
That setup is fascinating, I can't imagine how complex the throttle linkage for that setup is. What carbs are you using?
Old 02-05-2019, 05:58 PM
Carbs are 800 cfm brpv qjets used on T type Buicks.
Old 02-05-2019, 06:28 PM
unruhjonny's Avatar
that's a pretty cool setup!
I can't help but think that if you could somehow do it so that an intercooler is put in the mix that with even one turbo and not too much boost, you would see substantial gains...
Sheesh, the replies (that I saw earlier) in the other thread were terrible.
1970 Formula 400
Old 02-05-2019, 06:30 PM
GTOGEORGE's Avatar
How much boost?
GTO George
Old 02-05-2019, 06:52 PM
72projectbird's Avatar
Its so strange looking.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 02-05-2019, 07:30 PM
RUDOLFSSON's Avatar
!!!! As cool as I remembered !!!!
Where's the picture of the carnage in the oil pan... am I remembering correctly ?? LOL
Old 02-05-2019, 10:15 PM
Originally Posted by GTOGEORGE View Post
How much boost?
GTO George
Hey George it took 18lbs to break into the 9s with these little turbos in bad air. That's with a 224/224 HR.
I did grenade one engine pretty bad but not from boost. An overpowered clutch and resulting rev to 7500 on the 1-2 shift with no rev limiter was the cause. I guess the boost was responsible in a way...
Old 03-10-2019, 01:22 AM
Johnny406's Avatar
I was finally able to pick up the 301 turbo stuff I bought a few weeks ago. My idea was to run two of these turbo units in-line on top of a Offy 2x4 intake. I mocked it up a bit with what I have on hand. I hate to say it but this briefed better in my head before I had the turbo. For some reason I thought the 301 manifolds would work on a traditional Pontiac.
Name:	301 turbo.jpg
ID:	507590   Click image for larger version
Name:	301 setup.jpg
ID:	507591   Click image for larger version
Name:	301 exhaust.jpg
ID:	507592   Click image for larger version
Name:	301 turbo exh 2.jpg
Old 03-10-2019, 08:32 AM
Aaron65's Avatar
Aaron65 Aaron65 is offline
It's a great thought! Your post had me thinking about my '74 350 with 7.6:1 compression...there have to be a lot of them out there just begging for a cheap turbo swap and a set of better pistons.
1974 Firebird Esprit
1953 Buick Special Riviera
1963 Riviera
1963 Thunderbird
1965 Mustang
1965 Skylark Sport Coupe
1965 Dart 170 Wagon
1965 Corvair Monza Convertible
Old 03-12-2019, 04:33 PM
Years and Years ago, I had a pair of JR Round Port Headers that adapted a D-Port head to a Round Port Header. That header system was extremely easy to install/take apart and it used a pair of exhaust manifold 3/8 inch adaptor flanges that bolted on to the head first.
Then the Headers bolted on.
So when the 301 Turbo Engine came out I ordered two of the passenger side manifolds and
it also had the extra bolt at the top of the center exhaust ports, like the JR Headers.
So I just copied what JR headers did and made adaptor flanges to match the heads and the Pontiac Turbo manifolds and bolt positions. No issues with making them work. Problem is the manifolds are not out there any longer.
After that exercise I was able to purchase a pair of factory 1963/1964 Experimental center discharge manifolds that went upward with the exhaust to the RAJAY Turbo Flanges.
Those manifolds were later sold as part of a set of Turbo parts to Randy Williams before he died.
SO Johnny406, it is possible to make those manifolds work on a normal D-port head with a bit of fabrication.
Old 03-13-2019, 07:27 AM
charlie66's Avatar
great idea . hope you go forward with it!
Good luck!
My Half AN Injun.....
Old 03-13-2019, 09:48 AM
Interceptor's Avatar
Interceptor Interceptor is offline
Thinking about that dual-quad manifold, I wonder how it would work with 2 4bbl EFI units and twin turbos? I REALLY miss my Turbo Buick sometimes!
70 GTO Restomod -- 400/200-4r, nothing to see here
70 Firebird -- 455/400
69 Mach 1 -- 390-C6
07 Escalade EXT
Old 03-13-2019, 06:31 PM
67GTO4SPEED's Avatar
67GTO4SPEED 67GTO4SPEED is offline
A know a guy is using older Pontiac heads and a modified intake on a 301 Turbo TA and he drilled and tapped the center holes (7/16 - 14 I think he said) and loctite'd a bolt in the hole and had them surfaced. They seal with no issues.
'67 GTO 400 HO - Ram Air - 4 speed - 3.55 Safe T Track, A/C, PS, red fender liners
'78 Lemans - Drag car project
Old 03-13-2019, 06:50 PM
agree
SHOULD NOT BE AN ISSUE.
"Skip" (Dudley) McCully (PONTIAC ENGINEER who worked with Tom Nell and Herb Adams) did the swap to a 455 with dual Turbos many, many years ago.
The Draw Thru Carbs are the hard items to find.
Tom v.
Old 01-29-2026, 09:59 PM
Lamans63 Lamans63 is offline
I'm new to the forum. I got a great deal on two 301 motors one already built. I'm building a 63 La Mans on an upgraded frame. (already got the tunnel and disk breaks ect.) I still have the original 326. I also got two turbos and might need some advice. This is my retirement project.
The Following User Says Thank You to Lamans63 For This Useful Post:
Old 01-30-2026, 09:41 AM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
Super excited to see how this goes!
69 Firebird - Angry Bird
455 with 84mm Torqstorm
