Old 05-06-2019, 09:07 AM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
Originally Posted by GoatZillaRacing View Post
I have a complete set and now a bare head to sacrifice. I'm going over it with Dave Wilcox this weekend then back to the shop to slice and dice.
Reporting soon and also in a magazine article.
After several very knowledgeable cylinder head experts reviewed these heads, including Dave Wilcox and another Mountain Motor Pro Stock competitor that creates his own castings and billet blocks/heads/intakes. Everyone loves these heads! I heard many times that this or that was nicer/better than Edelbrock.
Not bashing Edelbrock. Nothing but respect for all they have done for the hobby.
I now have a bare head and a pair of complete heads and thanks to Mike, a cut up early Edelbrock to compare. Time to fire up the saw and let the slicing begin!
We will also bolt the complete as cast set on the 400 and test them on the 220" Dyno. There are many gain to be made on the as cast set but we want to test them "right out of the box". We may touch a few things up later as most of you would undoubtedly do, but we want to show results of a virgin set first.
Stay Tuned!
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
  #102
Old 05-06-2019, 08:59 PM
t money t money is offline
Can some one tell me the MLS gaskets part number is. I looked on there web site. Could not find.
  #103
Old 05-06-2019, 09:56 PM
grivera's Avatar
grivera grivera is offline
GZ-where is your shop located?
Will Rivera
  #104
Old 05-06-2019, 10:41 PM
High Performance Injuns/Arrow Injuneering
1632 E Northfield Dr #500 & #1600
Brownsburg IN 46112
Directly across the street from Don Schumacher Racing
Randy Repp
  #105
Old 05-06-2019, 11:06 PM
Default Slice 'n Dice
Why destroy a brand new $700+ head? Because we want to offer our customers Quality and Affordable Reliability. I have more slicing to do and will be publishing the results in an upcoming magazine article.
So far these heads are exceeding expectations and that's exactly what we want to do.
ID:	511726   Click image for larger version
ID:	511727   Click image for larger version
ID:	511728   Click image for larger version
ID:	511729   Click image for larger version
Randy Repp
  #106
Old 05-07-2019, 08:27 AM
ho428's Avatar
ho428 ho428 is offline
Now if we could only get someone to make a decent street quality and price "replacement" block.
  #107
Old 05-07-2019, 03:29 PM
While I would like to see a thicker deck surface, there is nothing wrong with the casting quality in that head!
Dr. Thomas Sowell
  #108
Old 05-07-2019, 05:06 PM
While I guessed at the deck possibly being 1/2" or so, it's actually the same 5/8" as an Edelbrock.
Randy Repp
  #109
Old 05-07-2019, 05:13 PM
Mike Davis's Avatar
Agree, after blowing 2 of them up this year...… need a few spares.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
  #110
Old 05-07-2019, 05:59 PM
This mean we've got to wait to see a cut through an intake runner?
Looks like plenty of meat above chamber at exhaust. I'm wanting to know just how much the chambers can be opened up.
Clay
  #111
Old 05-07-2019, 07:19 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Is the deck surface considered to be the area inside the rectangle?
  #112
Old 05-07-2019, 07:20 PM
ponjohn's Avatar
Aftermarket blocks?
  #113
Old 05-07-2019, 07:22 PM
Yes, and narrowest space being at the water jackets.
Clay
  #114
Old 05-07-2019, 08:54 PM
Good! If you consider the reactivity of aluminum with coolant, a thicker deck ensures your ability to mill the deck without losing strength. Head gasket life with these heads(when proper finish requirements are complied with) should be excellent.
Dr. Thomas Sowell
  #115
Old 05-07-2019, 09:00 PM
Clay
This means you'll need to wait until Thursday or Friday when my new sharp band saw blade arrives! Intake section is next. I want to cut the entire deck off and expose that section view too.
Randy Repp
  #116
Old 05-07-2019, 09:05 PM
Hi Mike,
I met with a gentleman last weekend that builds his own blocks/heads/intakes in both cast and billet and runs competitively in Mountain Motor Pro Stock. Great things are on the horizon!
Randy Repp
  #117
Old 05-08-2019, 01:40 AM
Dragncar Dragncar is offline
Everything is looking pretty good so far Randy ! Any talk of someone making a set "wide port" ?
  #118
Old 05-08-2019, 01:48 AM
Not going to happen unless they are cast overseas at any price close to what the other brands go for.
A RAV block would not be a bad starting point.
Or make one with a deck that looks like a PMD block, sbc style lifter valley with about .125 more meat around the lifter bores, mains are the same thickness as the current aftermarket blocks, extra rib down the pan rail like a 59 block,duel bell housing pattern, siammesed bores. And priority main oiling like a BBC.
That ought to do it !
If they are cost prohibitive to go with the same grade iron as the IA1-MR1 then at least as good a grade as the PMD Ram Air blocks would do the job.
I can dream right.
  #119
Old 05-08-2019, 07:23 AM
Mike Davis's Avatar
Aftermarket blocks?
Mine were factory blocks.
421 CID
  #120
Old 05-08-2019, 07:43 AM
Dave already mentioned that. i'll most likely send him a section to play with.
Randy Repp
