Old 08-11-2019, 06:16 PM
racerboy's Avatar
racerboy racerboy is offline
Default Fried engine harness (I think)
I think I know the answer to this but figured I’d check with the experts. I had to remove the alternator from my ‘70 today (to access fuel line) and during reassembly I pinched the wire loom between the alternator bracket and intake. When I went to put the negative battery cable back on, there were sparks everywhere and smile started drifting up along the loom down to the starter. Ugh. My question is:
Can I repair the engine harness by simply cutting off the part that got pinched or do I need to replace the entire harness?
Not sure if it shows up very clear in the photo but there is copper showing in the red wire.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 08-11-2019, 06:35 PM
cnc's Avatar
cnc cnc is offline
I would expose the harness and take a good look at it.....I would repair it, if it seems to be just that area.....
But I would solder the repair joints no butt connectors.....then shrink tube each repair joint...then tape over it...
If it's the original harness then it may be time to replace it wires do become brittle after 40 years.....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 08-11-2019, 06:50 PM
racerboy's Avatar
Thanks. It is a newer M&H harness. About 7 yr old. Maybe 1000 miles on it. I noticed that the tar wrap appears to have white residue on it all along the way harness back to the starter. Is that from heating up too much when I connected the battery?
Also, do you think I damaged my starter solenoid?
Old 08-12-2019, 05:17 AM
Geoff Geoff is offline
Looks like you pinched the alt wire, shouldn't be any starter related damage. Unrap the harness covering & check how far the burned section is, as the other poster said. If the copper wire is not burned or fused, it can probably be taped up [ insulated ] & re-used. Depends how long the juice was applied, smoke may just have been the insulation smoking, no wire damage.
Old 08-12-2019, 09:18 AM
racerboy's Avatar
Thanks Geoff. I’ll do just that. Unwrap it for a section and see how much damage I’ve done. I guess I get to wear a dunce cap now.
Old 09-03-2019, 01:35 PM
racerboy's Avatar
So I followed the suggestions offered here and was able to ‘save’ the harness by repairing it, but I think this was a temporary fix. I wasn’t able to solder the thick red wire. I’m new to doing electrical work but no matter how long I held the soldering gun on the wire, it never got hot enough for the solder to melt. I was holding the soldering gun tip at the bottom of the spliced wire (I think that’s correct way) and then touching solder to top of splice. I thought it was supposed to wick through but nothing happened. I know the gun was hot enough because if I touched the solder to the tip of the gun, that melted it. Any suggestions?
Old 09-03-2019, 02:35 PM
Bill Hanlon's Avatar
[QUOTE=racerboy;6058275I know the gun was hot enough because if I touched the solder to the tip of the gun, that melted it. Any suggestions?[/QUOTE]
Make sure the locking nuts or set screws that hold the tip to the soldering gun are nice and tight.
Old 09-03-2019, 04:20 PM
OG68 OG68 is offline
It may take awhile for the wiring splice to get hot enough to melt the solder. The whole length of wire acts like a big heat sink that pulls the heat away from the splice. The bigger the wire, the harder it is to heat up. Eventually it will.
A lot depends on the size of your iron and its wattage output. Pencil tip irons will take a long time to heat up the larger wiring.
2007 Cadillac SRX
Old 09-04-2019, 12:29 AM
Use a propane torch to solder your connections. It will heat much faster. Just be careful to shield things around the area so you don't damage something else.
Old 09-04-2019, 03:22 PM
I realize that many believe, and in the past have been advised, to solder connections, but, it is better to use quality non-insulated butt connectors, crimped with a quality crimper, and use shrink tubing.
If you want to blaze me on that statement, watch this before you do:
https://www.youtube.com/watch?v=faLn-SjVfwY
The Klein Tools crimper is the 'correct' crimper to use:
https://www.kleintools.com/catalog/c...ated-terminals
Home Depot carries Klein Tools crimpers.
Use nickel plated non-insulated barrel terminals like these:
https://www.waytekwire.com/products/...=Nickel-Plated
They are rated for high heat, but I use them across the board.
If you want to use open ended connectors, such as the Packard 56 series, use the appropriate terminals and crimpers, also available from a variety of auto wire warehouses and Summit. The Casper one is fine and inexpensive:
https://www.summitracing.com/parts/c...CABEgK4vPD_BwE
Terminal Supply has 101 videos that are great on crimping:
https://www.youtube.com/watch?v=LXDedfvmI_0
Only use GLX or TLX wire, especially under the hood, no parts store cheap 'primary wire'. It can't tolerate the heat.
https://www.wirebarn.com/GXL-Automot...Foot_c_29.html
For those wires, I would unwrap a few inches, stagger the cuts and butt connectors, shrink wrap them, then use the same type of harness wrap that the existing harness was wrapped in. That too is available at Waytek Wire.
I did a ton of homework prior to wiring my entire car, customizing it, and it's also using an EFI setup. I wanted to make SURE I did it right, and did it only once.
Old 09-04-2019, 08:16 PM
Boiler Boiler is offline
The below is good information. I spent almost 40 years working as an engineer, engineering manager and program manager for a automotive tier one wiring supplier.
I use open barrel splice clips, followed by just a touch of solder in case I didn't get a gas tight crimp and then I cover with a heat shrink.
Old 09-04-2019, 08:29 PM
racerboy's Avatar
Appreciate the advice. Unfortunately, none of the photos from your post are appearing (at least not on my phone). Is this the crimper you were suggesting:
Old 09-04-2019, 09:03 PM
Cardo's Avatar
Cardo Cardo is offline
No. This is it. https://smile.amazon.com/Non-Insulat...s%2C235&sr=8-1
Old 09-04-2019, 10:24 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
I would have contacted M&H to find out how much they would have charged to fix it.
As someone who has to cut/strip TFE, PTFE, ETFE and Kapton insulated silver plated and nickel plated copper wires all day long, a single splicing would be a treat.
Also what solder type are you using? As a J-STD-001 solder certified person, it sounds like you haven't been using flux to help with the solder flow or you're using RoHS compliant solder (no lead). They also have solder filled butt connectors nowadays.
So long, farewell.
Old 09-05-2019, 01:09 AM
Chris65LeMans's Avatar
I was wondering why it is so much harder to make the solder “flow” today then I remembered as a kid!
Old 09-06-2019, 08:32 AM
There are exceptions to every rule/guidance, and if you watch the Holley video, towards the end, when they cover the soldering, you will understand better why in general, crimps are recommended over soldering.
Basically, depending on the actual application, it's a matter of achieving a 'quality' solder joint. Without the proper training, materials, and tools, the chances of creating a quality solder joint is greatly decreased. It's much easier to consistently achieve a proper joint using crimp stuff. But of course, you still need to have the proper materials and tools. (as well as some minimal training/practice.)
HFR, no doubt you could pull off a quality solder joint!
Old 09-06-2019, 08:51 AM
I do like the ratcheting crimpers that accept an assortment of dies, it's a good way to start with quality crimping. As you have other crimping needs, you just buy the dies, and don't have to buy a whole new set of pliers.
Once you've used the ratcheting crimpers to make spark plug wires, you will never go back to using premade, long/short, all over the place plug wires. Or mess with the silly plastic tools that come with the wires.
The MSD one is a quality unit, but it is a touch pricey. It looks like a Panduit, but not sure.
https://www.holley.com/products/elec...ls/parts/35051
You can see the available dies here:
https://www.holley.com/brands/msd/pr.../wiring_tools/
I use these to do large gauge crimping, like for battery terminals and such. Works great, and inexpensive:
https://www.amazon.com/Amzdeal-Crimp...=fsclp_pl_dp_3
Old 09-11-2019, 09:21 PM
racerboy's Avatar
I ordered the Klein crimpers and the non-insulated connectors from Waytek. I wasn't sure how to order the wire (seems like you have to buy a lot fo any given gauge). Will send some pics once the parts come in and I make the repairs. Appreciate all the help!
Old 09-11-2019, 09:29 PM
racerboy's Avatar
This is probably a dumb question, but is there a tool that can accuratley tell what gauge a wire is?
Old 09-12-2019, 08:00 AM
No, there's kind of no need, you can pretty much tell by looking at the wire core thickness itself. If you wanted, you could use small lengths of know gauge wire with one end stripped for comparison.
Keep in mind the wire cover thickness varies greatly, and total diameter really can't be used to judge the wire gauge.
Also, 'cheap' wire uses a lower grade or coated cores (higher resistance, easier corrosion), and they don't always meet the standards for the gauge of wire they advertise on the package. Which is why they don't mark the wire cover with the gauge.
