Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 04-24-2020, 05:29 PM
ddella22 ddella22 is offline
Default Race parts stash
Performance parts Like new
Located in Charleston SC
455 rotating assembly, 60 over Ross forged pistons (XL421P), GRP billet aluminum rods (33976), stock 455 crank 4.210 stroke 3.25 main (496455). $1450
72 455 block with billet 4 bolt main caps and ARP studs, broken lifter bore, had a high lift solid roller and no brace will sell just the caps with or without the block I just thought someone may be able to fix it $300
Moroso deep sump oil pan 8qt capacity with pickup $175
Victor edelbrock intake, dominator flange $295
Billet thermostat housing $25
SCAT SFI approved flexplate $50
Front Engine plate $45
Aluminum valley pan no pcv $40
Roll master double roller timing chain, multiple key ways $75
Comp cams solid roller cam 306C-R8 QB4813 $75
Hedman Hustler Round port headers from 70s Ventura $150
I will add some more performance parts as I pull them out and get pics
ID:	538319   Click image for larger version
ID:	538320   Click image for larger version
ID:	538321   Click image for larger version
ID:	538322   Click image for larger version
Old 04-24-2020, 05:49 PM
duke455's Avatar
duke455 duke455 is offline
How much for the caps and studs ?
Old 04-24-2020, 06:40 PM
$300, just throwing the block in for free if you wanted it but I realize shipping the block is expensive so I’ll pull the caps and ship them and junk the block if need be
The Following User Says Thank You to ddella22 For This Useful Post:
Old 04-24-2020, 06:44 PM
Rob Roy Rob Roy is offline
Any pics of engine plate? Thanks in advance
Rob
Old 04-24-2020, 06:51 PM
Rob
Pic attached
Old 04-24-2020, 08:24 PM
CatalinaMike CatalinaMike is offline
Is the timing chain new? Pics of the flexplate and thermostat housing please. Interested in all 3
Old 04-24-2020, 08:34 PM
Everything had 8 passes on it until the lifter bore broke, pics attached
ID:	538338   Click image for larger version
Old 04-24-2020, 09:34 PM
catalina_dream's Avatar
catalina_dream catalina_dream is offline
Default Info Request
Any pictures of the rods and pistons from the other side? Maybe a close up of a rod and piston? Is the crank standard? Part number? Oil pan and pickup pictures? Whose pickup?
Thanks - Kevin
1972 Firebird
462, 6X heads, RA4 cam, iron intake, Cliff's Q-Jet
3925 race weight
Best of 12.88 @ 105 so far
Old 04-24-2020, 09:45 PM
Thanks - Kevin
Pm me your cell # and I can send over the pics
Crank is cut 10 on main and rod journals 496455 is the part number
Old 04-24-2020, 11:40 PM
blueghoast's Avatar
Intrested in the cam, got any specs on it. Post the card if you can.
GT.
Old 04-25-2020, 06:55 AM
duke455's Avatar
PM sent on the caps
Old 04-25-2020, 09:00 AM
GT.
Sorry I don’t have a cam card, all I have is the numbers off the end that I posted and that it’s a comp cams
Old 04-25-2020, 09:35 AM
PM sent
1972 Firebird
3925 race weight
Old 04-25-2020, 12:33 PM
Victor intake, flexplate, and main caps all sold
Old 04-25-2020, 10:48 PM
HoneyHush HoneyHush is offline
I will take the cam if blueghoast doesn’t
Old 04-25-2020, 11:56 PM
From what I found the cam is 275/278 .050 with 688/693 lift with 1.65’s. On a 104
Old 04-26-2020, 07:34 AM
PAUL K's Avatar
PAUL K PAUL K is offline
The R8 should mean the cam is. Solid Roller ground on a 108 LSA
Go fast, see Elvis!
Old 04-26-2020, 09:44 AM
If it posts the pic here is the cam. Hope it is a 108 because 104 is tight but it a drag race cam.
Old 04-29-2020, 10:17 PM
blueghoast's Avatar
Go ahead on the cam buddy.
GT
Old 05-01-2020, 03:09 PM
Front engine plate sold
