Old 05-28-2020, 01:53 PM
3fastgtos 3fastgtos is offline
Default Gutsram advice
Building a 500” Kauffman high port engine. Pretty big roller cam, 12:5 compression, 400 cfm heads. Most likely will run my old 850s or maybe new 1050s on the Gutsram.
Besides matching the ports any other advice on getting the most out of the manifold?
SD
Old 05-28-2020, 02:04 PM
slowbird's Avatar
slowbird slowbird is offline
Open up the run entrance at plenum as much as you can. The divide wall can be thinned quie a bit. Personally i don't like the peak in the plenum floor, i'd remove it and make floor flat. Other than that there isn't much that can be done. You can't make the runners at the plenum big enough and you can't make the plenum big enough. But it'll still make big power and due to things being small it'll accelerate nice in the car.
PAUL K's Avatar
PAUL K PAUL K is offline
An engine like that will probably benefit from a spacer underneath the manifold top to increase plenum volume.
Go fast, see Elvis!
Old 05-28-2020, 05:17 PM
Mike Davis's Avatar
X2 I made a delrin spacer for the Gutsram I tried and it picked up .09 in the 1/4 in back to back test over no spacer and just the flat top. Still did not run as fast as the original TR, but I am running a baby engine.
What I have found with both intakes on my engine is they both like shear plates.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 05-28-2020, 09:14 PM
Elarson's Avatar
Elarson Elarson is offline
We had a hand-me-down sheetmetal tunnel ram on the Grocery Getter and it was notorious for stalling at the end of a big burnout. It had a pretty big plenum.
We switched to the Gutsram and problem solved.
So I guess my general thought is to use spacers or something like that (not permanent) so you can try different plenum volumes till it's optimized.
FWIW,
Eric
Old 05-28-2020, 09:21 PM
Thanks for the advice guys.
SD
Old 05-29-2020, 10:40 PM
slowbird's Avatar
Look at mine, it isn't finished but shows how the center divider can be thinned (maybe don't go quite that much).
