Old 12-27-2021, 03:01 PM
DANTIP DANTIP is offline
Default 30 Amp fuse holder
My '72 Trans Am without A/C has the 30 amp fuse holder attached to an alternator wire. I thought that was for A/C cars only.
A few years ago Restore a Muscle Car sold a very similarly equipped original 4-speed T/A without A/C. Attached is a photo from the sale that clearly shows it too has the 30 amp fuse holder.
I hope someone can help determine why they were on these cars.
Name:	Screen Shot 2021-12-27 at 2.00.19 PM.jpg
ID:	580758   Click image for larger version
Name:	Screen Shot 2021-12-27 at 1.27.50 PM.jpg
Old 12-27-2021, 05:58 PM
indymanjoe's Avatar
I thought it was for the high speed in the fan/climate controll.
I am the Thread Killer!
The Following User Says Thank You to indymanjoe For This Useful Post:
Old 12-27-2021, 06:06 PM
OG68 OG68 is offline
Electric grid rear window defogger?
Old 12-27-2021, 07:49 PM
giles's Avatar
giles giles is offline
My 71 is a non-AC, blower defogger car with original engine harness and has a white 30 amp fuse holder. Ignore the black fuse holder in front of the valve cover. That’s a battery tender wired to the alternator + terminal.
Old 12-27-2021, 07:51 PM
Formulabruce's Avatar
Not on a 10si..
This car has a ac engine harness probably. Look behind pass head for more unused wires
" Long may we DRIVE !"
Old 12-27-2021, 11:25 PM
John V. John V. is offline
I learned about the 30A fuse holder on my '73 in this thread.
https://forums.maxperformanceinc.com...34#post6200434
I suspect it will answer your own question. There is a linked thread within it that may also provide answers. Mike (Held For Ransom) was a big help to me understanding it.
Old 12-28-2021, 12:19 AM
padgett's Avatar
padgett padgett is offline
30A (white, twist top) is probably a standard harness and for the AC that is not there.
Web Site
Old 12-28-2021, 10:34 AM
Default 30A fuse holder
I've been working with American Autowire to figure this out. I learned from the '72 GM service manual that the "A" body harnesses contained the 30A fuse lead that exits the engine harness back near the TCS connector. However, the service manual schematic for the "F" body does not show the wire/fuse assembly. So, my non A/C 72 T/A did have the connector that exited the harness back by the TCS connector but was obviously never used (dirty and the plastic on the end of the connector looked a little melted).
BTW, my harness had a tag on it that read "0484" "RL". I strongly suspect the 0484 is the last 4 of the part number (perhaps 8910484??) and the RL would be a build sheet code. If anyone has more info on the "0484" part number or a build sheet that contains "RL", I'd like to learn more.
