Old 05-08-2017, 12:14 AM
dreamn69 dreamn69 is offline
Default Wanted EGR backpressure valve 1978 400
I need the backpressure valve from a 78 400. My Formula's is missing.
1972 Formula 455HO
1979 W72 Fire Am
1975 455 4 speed TA
Old 05-08-2017, 07:33 PM
77 Canamman's Avatar
1978 manual trans 10006987
1978 auto trans 10004749
https://www.hiltopautoparts.com/prod...55-ci-engines/
https://www.hiltopautoparts.com/prod...00-ci-engines/
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 05-09-2017, 10:11 AM
1972 Formula 455HO
1979 W72 Fire Am
1975 455 4 speed TA
Old 01-10-2022, 12:23 AM
Jhankins Jhankins is offline
Default 1977 GP 400 EGR back pressure valve
I am also looking for an EGR back pressure valve for my GP. It has an auto trans. I see that this is an old thread but anything for sale?
Old 01-10-2022, 08:34 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Do you need one for concours resto, or do you just need functionality? Because I'm pretty sure most, if not all current new EGR valves now integrate the backpressure transducer into their mounting base so you don't need the separate transducer, anymore.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 01-10-2022, 01:24 PM
nUcLeArEnVoY. I just need it to function! I'm not doing a full resto. I'll look into a new EGR valve. Thank you for the info.
Old 01-15-2022, 05:10 PM
starlightblack's Avatar
starlightblack starlightblack is offline
Will need a tiny tack weld to re-attach tube but came off a running car
Yours for just shipping
ID:	581984   Click image for larger version
ID:	581985   Click image for larger version
ID:	581986   Click image for larger version
"Spend all your time and money on that Pontiac GTO pile" - The Go-Gos, 1981
Old 01-15-2022, 06:51 PM
starlightblack, thanks for the offer, mine's detached in the same place! I will try and repair mine first. Thanks again!
The Following User Says Thank You to Jhankins For This Useful Post:
Old 11-03-2025, 10:58 PM
Calidude Calidude is offline
I have one of these and it had what looked like JB weld on it, I tried doing same again but would stick and pressure blew it off.
Mine is a 1976 and looks different than the ones above
I also see one on eBay and looks like it has some kind of plate in a revised design.
I have a fluxcore gas less welder has anyone tack welded these or will it damage? Did they come brazed?
Appreciate any help
ID:	659966   Click image for larger version
ID:	659967   Click image for larger version
Old 11-04-2025, 09:38 AM
burd burd is offline
Try the guy in California. He has, use Amex just in case, he’s sleazy.
Why you want to use an egg, get rid of it.
Old 11-04-2025, 09:50 AM
Picked this up, it’s so nice I’m keeping it , all og, too heavy to ship anyway. Even had the choke shield.
Old 11-19-2025, 02:46 AM
Whiteturd Whiteturd is offline
Anyone else know how to repair what Calidude has as I have similar.
Brazing or welding?
Will that hurt it or how were these attached???
Someone is selling one for loads of cash on eBay at $275 that seems way high
Old 11-19-2025, 10:20 AM
That’s not loads, these parts aren’t cheap.
SWAP MEETS.
