Old 03-02-2022, 01:27 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
My usual wait time has been about three weeks from BAM.
How did the Mopar lifters work for you?
Fitment was good in all areas. I had to order new pushrods so we haven't made any smoke yet. I will report once I make some passes on it.
Dave Polichena
Old 03-02-2022, 05:56 PM
Dragncar Dragncar is offline
BAM with DLC coating is the best bang for the buck.
Here they are. The DLC coating, what is it ? Looks like a steel bushing with a coating. How does it hold up ? 1090$ here.
https://vincentperformance.com/shop/bam-b-2030-16-bb1/
They make a std bronze bushed lifter. 940 $
https://vincentperformance.com/shop/bam-b-2030-16-bb4/
And a needle bearing lifter. 695$
https://vincentperformance.com/shop/bam-b-2030-16/
USA made. I did not see a .903 lifter on this website.
Old 03-02-2022, 09:29 PM
RAIV55 RAIV55 is offline
Isky red zone, Crower enduremax, and BAM all are good choices. Like dealing with Brad. He will do specials on request. Just got some .903 +.005" with .180" intake offset for SBM.
Monty Frerichs
B&M Machine
Box Elder SD
Old 03-03-2022, 03:49 AM
It looks like DLC stands for"'diamond like coating". Some sort of carbon coating. A lot of the name manufacturers are making lifters using it now.
Old 03-03-2022, 04:37 AM
chuckies76ta's Avatar
Originally Posted by guidos View Post
I run .904 morel bushed, I also have wideport heads so I have an offset as well. Work great for me, no issues and I put a few street miles on in a year!
Well, If Richard can run 7000 plus miles Street and Track and not have any issues with lifters, then I would say your probably pretty safe with Morel. No?
950 Quickfuel.
Old 03-03-2022, 05:34 AM
Originally Posted by slowbird View Post
If you run a bushed lifter wheel you better make darn sure you have plenty of oil going to them
Just my experience from running these lifters. Crower # 66494X903E-16
The Crower lifter were using are HIPPO oiling They also incorporate a .010 groove on the side for oiling from the oil band to the oil supply hole for the pushrod. It's just for additional oiling all through the lift range.
The hole for the bearing or bushed wheel is feed from inside the oil band. They are cross drilled and one side is plugged. This definitely has to be check if cross drilled on new lifters. The side facing the lifter bore is plugged during manufacturing. Thank you Mike for pointing this out. From what I understand these lifters are edge oil oiling and is based on clearances in the lifter bores or in my case the installed bushing. We don't run any Restrictors in block or pushrods. So far so good.
ID:	585293   Click image for larger version
950 Quickfuel.
Old 03-03-2022, 09:34 AM
bpenrod bpenrod is offline
I'm sure someone has mentioned Bam.
Old 03-03-2022, 10:40 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
BAM has 2 bushing options, Bronze and Solid Steel DLC. Brad mentioned that there are multiple dragweek guys running the Solid Steel.
Name:	BAM Solid Roller Lifter Options.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 03-03-2022, 04:31 PM
I have run .030 with needle bearing solid roller for years. You get more oil through that than you would think.
.040 restrictors might be a good way to go since its not a street engine.
Old 03-03-2022, 04:47 PM
grandville455's Avatar
x2! I was told a minimum of .100 right from Morel when running a bushed lifter
Darby
M/T 275/60 ET SS Drag Radial
Old 03-03-2022, 04:59 PM
I can always drill them out to .100. Or just pull them out.
Old 03-03-2022, 10:19 PM
slowbird's Avatar
slowbird slowbird is offline
It's almost like i knew what i was talking about lol
The Following User Says Thank You to slowbird For This Useful Post:
Old 03-04-2022, 07:53 AM
I'm having a duh moment. What is the .100 your referring too?
950 Quickfuel.
Old 03-04-2022, 08:45 AM
I fat fingered a reply that ended up on the shaft rocker topic. I'm trying a .062 hole size on my 525 with .903 bushing type crower lifters. Will see how it goes.
Old 03-04-2022, 01:50 PM
The whole size in my lifter bushing to feed the lifters
Darby
The Following User Says Thank You to grandville455 For This Useful Post:
Old 03-04-2022, 05:53 PM
I am thinking .060-.080 myself.
I was told .030 was too small for std non pin oiled Comp rollers. 10+ years later still good.
When priming the engine I was amazed how much oil shot out of the .030 hole.
Took over 10 minutes of priming and slowly turning the engine over to get oil everywhere I wanted.
I figure I need to restrict oil to the top end at least some and the HP heads have good drain back.
Old 03-05-2022, 01:41 AM
This is the best price I have found so far on the BAM lifters with DLC coating.
1000$ Going with them from this guy.
Name:	Screenshot 2022-03-04 at 21-38-11 AOL Mail (16084).jpg
  #38
Old 03-05-2022, 07:27 AM
Steve C. Steve C. is offline
Dragncar
Instead of buying new lifters why not have Crower rebuild your current lifters ?
And they can add the Hi Pressure Pin Oiling option.
https://www.crower.com/rebuilt-your-roller-lifters
Old information here:
  #39
Old 03-05-2022, 10:11 AM
I run a bit more oil pressure than some do.
  #40
Old 03-05-2022, 10:17 AM
I think I'm around .080 feed hole in the bushing. I primed the engine with the lifters removed and there is lots of oil comes through those holes in the bushings.
May I ask what oil pressure your running? Thanks
950 Quickfuel.
