Old 08-19-2022, 01:05 AM
Dragncar Dragncar is offline
Like I mentioned, I know other ways may work, but I follow the directions with the gear sets, and the service manual, and have never had a problem doing that.
It's kind of hard to argue with the directions and the service manual, and not going to 'tell' anyone to do it other than what they choose to do. If others have done it a different way, and had success, then it is your choice to do it another way than I do.
When you go dot to dot, it's much easier to align, because you can actually see the teeth aligned. If they are not together, you stand a much great chance of being off a tooth.
The service manuals are wrong and should be changed. They leave room for error when they do not have to. People who do not know better put their engine together dot to dot then they install the distributor up on # 1 thinking they are doing it right.
So they try and break in their sft cam and the engine does not fire right up and we all know a quick fire up is essential to braking in a sft cam.
So the engine pops and sputters and by the time they figure it out and flip the distributor 180 all the lube is smeared off the cam and the cam goes flat.
Seen it happen.
Dot to dot put the distributor up on # 6. Or tun the engine one full crank turn lake Darby says and put the distributor in the correct spot on #1.
The manuals have screwed up a lot of engines if the person doing the initial fire up was a novice.
